Veteran's Trike axle help
redneckrickard
redneckrickard is offline
PostPosted: Sat Jun 03, 2017 6:53 am    Post subject: Veteran's Trike axle help Reply with quote
Hi guys I am in the process of putting an automatic transmission in a vet's trike so his wife can drive it I'm looking for any pointers I believe I have what I need to couple the 010? auto Trans to the 1600cc air cooled engine but just realized the "axle stubs" on the different are larger than the ones from the manual can I change the ends on the half axles or what should I do???
vwbug72501
vwbug72501 is offline
PostPosted: Wed Jun 07, 2017 4:54 pm    Post subject: Re: Veteran's Trike axle help Reply with quote
Is the new automatic from a type 3(fastback/squareback) or from a type 2/4(van)?
There are several aftermarket cv flange adapters and stub axles available. They are type1, type 2, and 930. A little time in the forum should clarify the issue. The type 3 auto trans has unique uneven length axle shafts.
Welcome to the "mix and match" world of VWs!
