Where to order air-cooled exhaust system?
Broham
Broham is offline
PostPosted: Wed Feb 04, 2015 3:30 pm    Post subject: Where to order air-cooled exhaust system? Reply with quote
Hi all!
My exhaust system is pretty much completely rusted out and cracked, even. I have an '82 air-cooled 2.0 liter engine. The only site I saw that had something comparable was this, but it's on backorder.
http://www.rockymountainwesty.com/80_83_SS_Air_Cooled_Exhaust_System_p/rmw-1acx.htm
Where can I find an exhaust system (preferably stainless steel) and maybe even some new heater boxes (left and right)? I feel like I've exhausted (lol) all my options at this point.
jismay
jismay is offline
PostPosted: Wed Feb 04, 2015 4:29 pm    Post subject: Reply with quote
You might try:
http://www.averysaircooled.com/
https://interstateusedparts.com
Be aware that there is a big difference between the 1980 and 81-83 exhaust parts as well as additional differences between the CA and 49-state versions.
Brian
1970 Squareback with 1915cc dual 40idf
1979 Beetle Convertible
1980 Vanagon Westfalia
1989 VW Cabriolet
FNGRUVN
FNGRUVN is offline
PostPosted: Wed Feb 04, 2015 7:43 pm    Post subject: Reply with quote
Bus Depot is a good source for aircooled parts. Check California Import Parts(CIP1 I think is what they go by), as well. The Samba classifieds is a good source too.
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
Matt G
Matt G is offline
PostPosted: Wed Feb 04, 2015 8:07 pm    Post subject: Where to order air-cooled exhaust system? Reply with quote
The j-pipe will be the most challenging to find, the other pieces are still available if you decide to stay stock. (The federal version j-pipe is nearly extinct, but the California version can still be found used).
Bus Depot and other vendors also offer other solutions (extractor types) should you decide to leave the stock set up. Tangerine Racing Products used to offer a SS exhaust for type 4 buses, although that is no longer shown on their website. If it were me, I'd wait for the back-order to end and order the RMW model.
Good Luck,
Matt
Matt
'90 Vanagon GL
'81 Vanagon
'71 Bus
wesitarz
wesitarz is offline
PostPosted: Wed Feb 04, 2015 9:12 pm    Post subject: Reply with quote
California Import Products Ltd. Cip1.com
GreenMachineVW
GreenMachineVW is offline
PostPosted: Wed Feb 04, 2015 9:34 pm    Post subject: Reply with quote
I've used one of these for over 10,000 miles. It looked rusty as soon as the paint burnt off (about 100 miles), and has not changed since. Can't beat the price.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DD%2D2072
It is an EMPI, so you should be able to find it at many sources, maybe even locally.
t3 kopf
t3 kopf is offline
PostPosted: Thu Feb 05, 2015 2:46 am    Post subject: Reply with quote
I used that one when I had my air cooled. it has a descent exhaust note to it as I recall but yes the paint turns to rust in about a week of driving. it might not be a bad idea to use that one and get it sand blasted and powder coated before using it. that what I would do if I still had that van.
'90 Carat w/ '95 phase 1 EJ22 OBD2 conversion
GTV
GTV is offline
PostPosted: Thu Feb 05, 2015 6:00 am    Post subject: Reply with quote
IMO, those exhausts have decent ground clearance, pretty good looks (symmetry), and are inexpensive. However, the 1-2 side is not merged with the 3-4 side, making it no different than a dune buggy "dual cannon" exhaust. This hurts performance and makes it sound awful. I would invest in one of these:
http://shop.vintagespeed.com.tw/s.nl/sc.12/category.3234/.f
Just my two cents.
EMPI Power Rules!
Broham
Broham is offline
PostPosted: Tue Feb 10, 2015 9:05 am    Post subject: Reply with quote
Update!
Called RMW and they were super helpful. Apparently they manufacture them somewhat regularly and when I called, they had just finished three. I was able to order one today. I am, however, still struggling to have luck finding left and right heat exchangers. I was about to order some and my mechanic told me that some use a copper gasket and some use a metal gasket.
I've uploaded some pictures of the assumed gaskets. Can anyone tell me the difference and maybe a good place to find one for less than $500 a PIECE? Thanks so much for all the suggestions and help. I'll post feedback on the new exhaust when I get it going.
VWinVT
VWinVT is offline
PostPosted: Tue Feb 10, 2015 10:35 am    Post subject: Reply with quote
Don't want to muddy the waters, but are the heat exchangers a must have portion of the exhaust? My aircooled has the exchangers and the proper exhaust and it produces lukewarm (at best) heat in the dash. Perhaps if they are not needed (to keep the motor cool) then perhaps you could save yourself some time/money/frustration by simply removing them???
1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground.
MarkWard
MarkWard is offline
PostPosted: Tue Feb 10, 2015 10:50 am    Post subject: Reply with quote
Your mechanic may have been referring to the exhaust port gaskets where the heater boxes connect to the heads. Early 2.0 bus heads had oval exhaust ports and used a copper crush seal to seal the heater boxes to the head. Starting with the late busses and the aircooled vanagons, VW changed to a square exhaust port design that utilized more of a conventional type exhaust gasket. You can't fit oval port heat exchangers on a square port head or vice versa without some clever adaption.
Adios
Broham
Broham is offline
PostPosted: Tue Feb 10, 2015 11:41 am    Post subject: Reply with quote
Hmm..is that really a good idea? Is it necessary?
And that makes more sense, rsxsr. I'll take a closer look and see what I can find.
a2d2
a2d2 is offline
PostPosted: Tue Feb 10, 2015 1:16 pm    Post subject: Reply with quote
The heat exchangers do actually provide heat if everything else along the way is working properly. The amount it pumps out is dependent on the blower fan on the alternator (and therefore completely relative to engine speed) so it's not perfect but it's something.
I thought they were useless for years until I replaced and/or repaired the flapper boxes and cabling. Now I vote for keeping them.
1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.)
AlexWesty415
AlexWesty415 is offline
PostPosted: Mon Jun 29, 2020 7:41 am    Post subject: Re: Where to order air-cooled exhaust system? Reply with quote
Van Cafe has the best setup for $600 you get the whole system, they give you easy to understand instructions and NO WELDING required, which for someone like me who doesn't know how to weld, is pretty huge. It's also stainless Steel so no more rust. It's quiet and makes the van look that much cooler.
Vanagon 80-83 Aricooled Exhaust:
https://www.vancafe.com/RMW-2985101-p/rmw-2985101.htm
9.5isCanadian
9.5isCanadian is offline
PostPosted: Mon Jun 29, 2020 8:00 am    Post subject: Reply with quote
Just my two cents.
Ditto
I love mine. Great quality, looks awesome and sounds fantastic.
9 1/2 - missing a few pieces.
1987 Getaway Hightop M-plate
1980 Sunroof Vanagon
2020 KTM Adventure R
2012 Golf tdi
mightyart
mightyart is offline
PostPosted: Mon Jun 29, 2020 8:26 am    Post subject: Re: Where to order air-cooled exhaust system? Reply with quote
DO NOT get rid of the heat exchangers, they are not just for heat in a Vanagon.
They are helping cool the engine.
this is the cheap exhaust. The gaskets that come with it are junk, the round one is easy to get,it's just a header gasket. I made the ones for the heat exchangers out of heavy duty exhaust gasket material. a little more work to make the gaskets but not $500.00 bucks worth.
https://www.busdepot.com/vw7802026
My Art:
http://www.instagram.com/flynn8552/
