Denture Dan Samba Member
Posted: Mon Jun 06, 2022 8:16 pm Post subject: 72 bus door lock mechanism |
Where can a guy find door lock mechanism. Thanks dan |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1272 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Mon Jun 06, 2022 8:37 pm Post subject: Re: 72 bus door lock mechanism |
i think it might be helpful to know which door you’re talking about. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Posted: Mon Jun 06, 2022 8:40 pm Post subject: Re: 72 bus door lock mechanism |
Both drivers and passenger doors |
Posted: Mon Jun 06, 2022 9:05 pm Post subject: Re: 72 bus door lock mechanism |
if you want used, you could start contacting vw junk yards: busted bus, avery’s, busco, interstate, and way out salvage ought to get you started.
if you want new, others with more experience will have to chime in on quality, price, source, etc. _________________ 1978 Champaign Edition 2 Westfalia
SGKent Samba Member
Posted: Mon Jun 06, 2022 9:39 pm Post subject: Re: 72 bus door lock mechanism |
I use Ken Madsen at TheBusco. Fast, reasonable and quality used parts. Be sure you ask for the correct year parts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Jun 06, 2022 10:05 pm Post subject: Re: 72 bus door lock mechanism |
Actually, I’ve recently learned that this most common problem is a broken spring. In fact, I sourced the spring and bought 10 or so to keep in stock. So, remove the mechanism, clean it in your heated ultrasonic cleaner, wash, dry, blow dry. Lube and install the replacement spring. Should last another 50 years _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
