rlutterb Samba Member
Joined: January 10, 2006 Posts: 1391 Location: Carrollton Ohio
Posted: Thu Feb 12, 2015 1:50 pm Post subject: Likely cause of fuse blowing when wipers are on LOW |
What is the most likely cause of fuse blowing when I put my wipers on LOW. Running them on HIGH works fine, but on low, when the arms have moved all the way left and are just starting to jump back to going to the right, the entire electrical system of the car blinks off for a second, then the next time the fuse blows. Is it most likely the switch, wiper motor, or is there a wiper relay? _________________ 1973 Super Beetle
1978 Ford F-250
2020 GMC Sierra |
Greg in GA Samba Member
Posted: Thu Feb 12, 2015 1:54 pm Post subject: |
since it's not instantaneous, I'd say it sounds like the fuses are blowing because of a high load on the wiper motor. May need cleaning. Others will chime in to support or disagree with my hypothesis. _________________ 1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Thu Feb 12, 2015 2:16 pm Post subject: |
Greg in GA wrote: |
since it's not instantaneous, I'd say it sounds like the fuses are blowing because of a high load on the wiper motor. May need cleaning. Others will chime in to support or disagree with my hypothesis. |
X2
Highest mechanical load would most likely be at either extreme of travel. A good full removal of shafts to clean and lube would do wonders. Maybe scribe things before removal so they align on replacement. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1082 Location: wherever my baywindow takes me.
Posted: Thu Feb 12, 2015 3:00 pm Post subject: |
TomWesty wrote: |
Greg in GA wrote: |
X2
Highest mechanical load would most likely be at either extreme of travel. A good full removal of shafts to clean and lube would do wonders. Maybe scribe things before removal so they align on replacement. |
Yep! All of it! Arm shafts binding through their travel have long been notorious culprits when it comes to troubleshooting wiper problems. The more severe the bind the higher the load potentially on the motor. |
Posted: Thu Feb 12, 2015 5:27 pm Post subject: |
Interesting.....I had not considered that sine the arms paper to more freely and without any resistance. _________________ 1973 Super Beetle
1978 Ford F-250
2020 GMC Sierra |
grandpa pete Samba Member
