JCTTIM Samba Member
Posted: Fri Feb 13, 2015 10:21 am Post subject: Cylinder head Identification |
021 101 371 S
I thought these were 914 but I was told the 4 studs on the intake disqualify them. Looked at 3 pages in archives and found nothing with this part #. The Intake valve looks to be about 46.5mm .
I've been asked if these would fit a LIMBO Camper 2000cc CJ prefix, Australian VW? I thought I was a guru holy moly
Any help would be greatly appreciated. Thank You |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Fri Feb 13, 2015 11:03 am Post subject: |
Those are 1800 heads. They could be 914, 411/412 cars or bus. The part numbers for the 1.8 heads on all of those vehicles are the same. They all have 4 intake studs.
Only the 914 2.0L has three studs. Its part number is 039 101 371A. Ray |
JCTTIM Samba Member
Posted: Fri Feb 13, 2015 11:25 am Post subject: heads |
Thanks Ray. I'll check some Porsche sites and some other heads I have from my pile. I thought they were 2.0 914 and was told no. Now I have that info. Much appreciated. |
SGKent Samba Member
Posted: Fri Feb 13, 2015 12:58 pm Post subject: |
this is from another website
Quote: |
The 021 101 371s head is from a "AN" 1800 cc 412/914 engine |
which agrees with what Ray said _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Feb 13, 2015 2:09 pm Post subject: |
Those do look like pretty big valves in the picture. its entirely possible that the 1.8 heads were flycut to run on a 2.0 engine. That still does not make them 914 2.0L.
The 2.0L 914 had larger chambers and different spark plug angle...and possibly slightly different intake angle. Ray |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Feb 13, 2015 2:50 pm Post subject: |
I wonder if Tcash has collated all this information into one thread?
Bleyseng Samba Member
Posted: Fri Feb 13, 2015 3:58 pm Post subject: |
These are Porsche 2.0L heads. The heads in your picture look like huge intake valves maybe 48mm which is too big. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Feb 13, 2015 10:10 pm Post subject: Cylinder heads |
I have an engine for my bus with the S heads that were New old stock that i sent to Adrian @ www.headflowmasters.com to be upgraded with seats & valves along with some port work to get them a little closer for work in the heavier bus.
Pic on page 3 in my gallery photo's
Your 021 101 371 S HEADS will also need to be reworked since the picture of the head in the foreground has a Bad exhaust valve&seat
But if you spend the money and have them reconditioned they will work well
with the right compression ratio setup.
these heads have the largest chambers @ 55 - 56 C.C.'s so the build will require a Compression ratio of 7.3 to 8.0 for the street driven daily driver
Dished Pistons and a deck of approx: .065 in.
The Stock Valves for these heads are 41 mm int. & 34 mm ext.
Adrian replaces the seats and installs 42 x 36 and YOUR seats &Valves look Larger in the photo's so it would be a good idea to post the measurements . _________________ V.W.owner since 1967 |
Posted: Sat Feb 14, 2015 2:23 pm Post subject: |
I am using the AMC1800 heads with my engine and use the 914 2.0L USA pistons with the smaller dish. I am running a tighter deck ht too (.045) to achieve a 7.8 to 1 CR. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
