Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Feb 14, 2015 5:15 pm Post subject: Mysterious? leak |
I drove from Los Angeles to Salt Lake City (833 miles) over three days in my '87 poptop non galley camper without any problems except for poor gas mileage. Used cabin heat intermittently during the trip. Replaced a burned out taillight bulb and checked fluid levels in SLC. Coolant was down a bit (above MIN) and replenished back to MAX. The vehicle sat for four days without being used. When I went to start it this morning I noticed a small wet spot under the driver's side trailing arm. The bolt head was wet and the fluid felt slippery without any distinguishing odor. Later that morning I went to fill gas and moved the moved the #2 lever from mid to off during the drive. After filling gas I noticed a larger wet spot under the front of the vehicle and drips from the spare tire cover. I checked coolant level and there was no significant indication of loss.
I am assuming that I have a small leak either in my front heater core, the control valve, or the hose connecting the two. I also assume the the trailing arm bolt head wetness was somehow fluid that had gone downhill from the front. The Bentley shows the control valve with a notation "from cylinder head" and I also assume that the hose connecting the valve from the cylinder head could be the source of the leak. I assume that the position of the valve might influence the rate of the leak, but haven't driven enough to form an opinion in that regard.
It is Saturday and I believe Monday is a holiday. I don't plan to do much driving in the next few days and will be doing a search for Vanagon repairs in SLC.
What are TheSambans opinions of my assumptions? What are their experiences with a leak of this mysterious nature and what are their recommendations for coolant repairs in SLC?
Aloha
tp |
Terry Kay Banned
Posted: Sat Feb 14, 2015 11:33 pm Post subject: |
<<<I noticed a larger wet spot under the front of the vehicle and drips from the spare tire cover.>>>
Hose, coolant tube, heater valve, radiator.
Time to drop the spare tire clam shell & take a look upward--could only be one of 27 different things-- _________________ T.K. |
Posted: Sat Feb 14, 2015 11:37 pm Post subject: |
Thanks for the reply TK. I'll be under the camper in the morning.
Aloha
tp |
Posted: Sun Feb 15, 2015 12:20 pm Post subject: |
Went out to the '87 pop top this and saw the same small wet spot under the trailing arm and some fluid on the frame. Checked the coolant level and still at MAX. Dropped the clamshell and saw no evidence of fluid there. No evidence of fluid leakage from any of the cooling system plumbing. Started the engine and let it idle for about ten minutes with no drips anywhere. After about fifteen minutes a few drops appeared on the passenger side and along the frame under the radiator. Pulled the upper and lower grills and could see no leakage. Must be a pinhole leakage in the radiator or a leak at a hose connection.
I plan to do some driving and then crawl under for another look for the source. The leak is so small that I may not attempt any repairs until returning to SoCal.
Any recommendations for radiator replacement in Salt Lake City?
Aloha
tp |
Terry Kay Banned
Posted: Sun Feb 15, 2015 12:31 pm Post subject: |
Find someone that can get a pressure tester on the expansion tank, then take a look.
This might / could save you some time & money
You'd be awfully grumpy after having a radiator installed & wind up still having the post nasal drip.
Have it checked out first. _________________ T.K. |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Sun Feb 15, 2015 2:32 pm Post subject: |
My money is on the heater control valve. I didnt ever have to open mine up when i lived in florida except for bleeding. When i came up to a colder climate, i ran with it open all day and came out the next day to a wet spot in the same place. Found that the control valve was leaking only when open. Its next to the radiator fan above the clamshell. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Terry Kay Banned
Posted: Sun Feb 15, 2015 3:40 pm Post subject: |
Might be, might not be.
They all don't leak in the same place every time.
A pressure test on the vehicle would eliminate any speculation ---BOW!
Here it is!
No guessing, and " because Johnny's leaked there doesn't necessarily mean mine is"
Verify first then start throwing money at it. _________________ T.K. |
Posted: Sun Feb 15, 2015 4:26 pm Post subject: |
Terry Kay wrote: |
Here it is!
Verify first then start throwing money at it. |
i was following up...sort of a "when he tests it, my money is on...." _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sun Feb 15, 2015 6:01 pm Post subject: |
I think this is the front heater control valve. Correct me if I'm wrong. There have been no drops of coolant or evidence of a leak from anything in the tunnel above the clamshell.
This is the place where the coolant drops appear. Right at what I assume is the radiator frame and bolts. I don't know how to put an arrow on the spot. My MacBook Air is new to me. I see nothing coming from the hose, only a few drops on the metal.
After I found coolant drops after 15 minutes of idling I let it sit and cool down for a couple of hours and saw no further leakage. Took the camper for a 15 minute drive and no drops or wet spots.
I'm aware of the damage that can be caused to any engine from overheating due to coolant loss, but at this time I'm not really losing any significant amount. The tank is still at MAX. I'll be heading to Tahoe from Salt Lake City in about ten days and then to SoCal after a week in Tahoe. Until I find a source for a larger leak I'll be driving with an eye on the gauges.
Mysteriouser and mysteriouser.
Thanks for the replies.
Aloha
tp |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun Feb 15, 2015 8:00 pm Post subject: |
Just a quick plea to carry a square of cardboard or an old towel to put under it when you park to prevent killing someone's cat or dog. I had a scare a few days ago when I brought coolant soaked carpet inside to clean and it made a puddle quickly. We have pets. All is well but it's on my mind. If your car leaves only a little puddle it could kill a dog or cat and it's a painful death.
When my Van leaked coolant before I fixed it, I put a short cardboard box under the engine with an old towel in it. Prevents them from getting any liquid because the sides of the box go up almost touching the engine to prevent them from licking off drops as well.
Anyhow, be safe. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Feb 23, 2015 7:27 pm Post subject: |
800 miles later and replaced about 1/2 cup of coolant. No visible leaks anymore.
Aloha
tp |
bluebus86 Banned
Posted: Mon Feb 23, 2015 7:43 pm Post subject: |
Tom Powell wrote: |
Aloha
tp |
the coolant tank can be filled to max, but you can be low on coolant, you may well have an air pocket in the higher spots of the cooling system that wont make the coolant tank appear low. if you have a leak, do not assume that the system is still full just because the coolant tank is "full". You need to bleed all the air out of the system if you indeed detected a leak. follow the rather difficult bleeding procedure in the manual, raise vehicle front, rev motor, open bleed screw on radiator, bleeder valve on thermostat housing etc......
If you did indeed have a leak, and have not properly bleed the system you can be assured you have air in the system, do not think a full tank means you are ok, you likely are NOT ok. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Fri Feb 27, 2015 9:26 pm Post subject: |
I added a bit of distilled water to bring the coolant up to the MAX and drove from Salt Lake City to Tahoe. Checked the level at every gas stop and no drop in level. Checked the level still at MAX in Tahoe and drove to SoCal a week later Arrived in LA and the level was slightly above MAX. More coolant in the system than when I left SLC. Possibly due to checking a cold engine and rechecking a hot engine. Or possibly due to different slope of the parking spots. The coolant temperature needle never went out of the normal operating range when driving. No drops of coolant on the radiator frame or the trailing arm bolt when parked.
I believe that i have a self healing cooling system. The random particles in the radiator have gone to the pinhole leak and the system has cured itself.
If it works, don't fix it.
Aloha
tp |
Terry Kay Banned
Posted: Fri Feb 27, 2015 10:36 pm Post subject: |
<<I believe that i have a self healing cooling system>>
Oatmeal, tobacco, eggs, some flim flam magic sealer, maybe.
Never a self healer --ever--
It'll leak again--nothing cures itself on it's own.
It's just a fact of life in coolant leaks. _________________ T.K. |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Sat Feb 28, 2015 6:17 am Post subject: |
Ah, to be young again... _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
Posted: Sat Feb 28, 2015 8:03 am Post subject: |
seventyfo wrote: |
Ah, to be young again... |
I turned 79 in January and youth is a state of mind and thanks to good health just finished a couple of weeks of skiing in Utah and California with family and friends.
I don't believe in self healing systems either, hence the emoticon . But I also believe in "if it works don't fix it". As a retired airline pilot I am familiar with the merits of preventative maintenance. Vanagons are always subject to catastrophic faiiure in one form or another. The best system is a combination of awareness and a Plan B. I don't have a planned budget, but I do have time, tools, abilities, and cash reserves.
Thanks for the replies. I'll keep an eye on the gauges and check the ground under the vehicle every time I walk up to it.
Aloha
tp |
wcdennis Samba Member
Joined: July 20, 2004 Posts: 955 Location: Winston-Salem NC
Posted: Sat Feb 28, 2015 8:17 am Post subject: |
As for the self-healing concept: large temperature swings can change the properties of rubber and steel clamps. I can accept the possibility that a leak that showed up during extreme cold could heal itself in milder weather.
I would also ask, are you 100% sure the leak was coolant? Is there a possibility that water, in the form of ice or snow, was trapped somewhere in the frame and leaked out when the van warmed up? |
Posted: Sat Feb 28, 2015 8:36 am Post subject: |
wcdennis wrote: |
I first noticed the leak after the camper had been parked for several days in cold weather. That leak was noticed as a spot on the ground under the trailing arm. There was a drop left on the bolt head and I rubbed it between my fingers and smelled it. It felt slippery and without any odor. I didn't do a taste taste, but assumed it was coolant. A few days later I saw a spot under the front and saw drops from the radiator frame. No ice, snow or rain during the driving or parked periods. The weather had been cold enough at night to freeze water bottles inside the camper, but was mild and sunny during the day.
I think that thermal expansion/contraction is a very strong possibility and far more plausible than self healing.
Aloha
tp |
