houseofboyd Samba Member
Joined: September 28, 2014 Posts: 613 Location: Flatwoods, Ky
Posted: Tue Feb 17, 2015 5:51 am Post subject: '68 Speedo Question |
I'm sure that I've read somewhere that the '68 speedo is a one off, first year for fuel gauge, but different than a '69+. The speedo in my Beetle works fine, other than a whine that I get after 40mph. Don't know if it's the cable or the gears within the speedo. And the gels have seen better days. So anyhow, I was thinking about picking up another to rebuild while I can keep my current speedo in the car....Can I use any year other than a '68 and still have it look and function the same? _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle |
johnny2013 Samba Member
Posted: Tue Feb 17, 2015 5:58 am Post subject: |
im using a 72 speedo in my 71 beetle, and works fine. _________________ 1971 orange beetle, 1200 engine, with weber 40 idf!!, 1971 beige beetle,1200, ALL STOCK,
both undergoing slow restoration. |
gt1953 Samba Member
Posted: Tue Feb 17, 2015 6:46 am Post subject: |
You are correct about the 68 speedo and fuel gauge. I have a 72 speedo in my 68 only cause I am using the extra indicator lamps for fog lights and such. Source out a speedo in the classifieds or fix the one you have. Lube the speedo cable first. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Brian Samba Moderator
Posted: Tue Feb 17, 2015 7:31 am Post subject: |
The whine is caused by small worn out gears.
Take yours apart, it's pretty easy to do. Lube up the little gears and see if that helps first. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Feb 17, 2015 7:52 am Post subject: |
I'm pretty sure you can get a hold of some new gears too. It's a whole lot easier than you'd think, and cheaper than buying another worn out speedo. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
