John, the Engineer - '77 Champagne Transporter Build/Travels
fogoo
fogoo is offline
PostPosted: Thu Mar 31, 2016 9:25 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
I don't know how I missed this one before. Nice work!
64 Single Cab
71 Bug.....sold
73 Bus......sold
75 Panel Bus - converting to Subi power http://www.thesamba.com/vw/forum/viewtopic.php?t=651073&highlight=
78 Kombi Camper
captincanuck
captincanuck is offline
PostPosted: Thu Mar 31, 2016 9:43 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
We should get this added to the "water cooled bay conversions" list. Yours to Steve
http://www.thesamba.com/vw/forum/viewtopic.php?t=537187
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
BusPriest
BusPriest is offline
PostPosted: Sat Jul 16, 2016 7:05 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Ok after a haitus, i am back at it again.
todays job includes figuring out why its pissing oil. I think its because the rear main seal but it could be because i used a gasket on the oil pan instead of RTV. i did the RTV yesterday, going to refill today and see what the result is. say a little prayer to allah its the oil pan and not the rear main.
1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest.
BusPriest
PostPosted: Sun Aug 28, 2016 7:55 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
How about an update. People like updates right??
Moved from Dallas to Austin
I originally put the rear main seal in there a little too far so it was peeing oil in a steady stream (not dripping but literally pissing). Replaced that guy.
So that seemed to solve my biggest issue. I have a brand new Bosch starter that's just not making thr cut. Thinking I need a hi torque starter bc it doesn't wanna start sometimes. If anyone has a cheap solution for this I would love to hear it!
The temp is running real nice w the roof rack radiator. This pic is cruising at about 50
And this speed pic is for skillz.
But I think I had a ground issue so the night ended like they all do. Lol.
Not a Priest.
BusPriest
PostPosted: Sun Aug 28, 2016 7:59 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Last picture should be this.
I want to say it's so amazing driving around. It's effortless. My pedal linkage isn't perfect yet so I can't rev it quickly but it still responds so well on hills and such. It's how these buses should be driven
Not a Priest.
BusPriest
PostPosted: Sun Aug 28, 2016 8:43 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Brake light issue:
Need some help here. Recently replaced the housing on the tail lights. just discovered im not getting any brake lights at all. the running lights on the tail are working, the side markers are working. the fuses all seem good and have the same reading on top and bottom.
When the brake pedal is depressed i am not getting any signal in the black w red wire in the rear. So i figure it must be the sensors on the master cylinder. Bentley says that wires 81 and 81a are the two outside wires/plugs on the sensor and the middle one is lik 17 or 14? its the power.
Bentley says turn car to acc. then unplug 81 and 81a on one sensor and check to see if brake lights work, then repeat on the other one. Well that didnt do anything. So i get under there with the multimeter and discover im geting power from one of the side wires/plugs and not the middle. so i try the same test with leaving that one in and other two unplugged. nothing.
These brake lights worked recently. is it possible that both sensors went out at the same time??
Not a Priest.
busdaddy
busdaddy is offline
PostPosted: Sun Aug 28, 2016 8:51 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Stick a jumper wire between the black and black/red wires in one of the plugs on the master cylinder and turn on the key, if the brake lights are on the issue is with the switches.
Слава Україні!
captincanuck
PostPosted: Sun Aug 28, 2016 8:58 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
BusPriest wrote:
Brake light issue:
The switches on the master are redundant correct? So one could hade been dead for years without you knowing, and now the second on has bit the dust. Just a thought.
Did you check with the ohm meter with someone pressing the brake or with the volt meter?
busdaddy
busdaddy is offline
PostPosted: Sun Aug 28, 2016 9:15 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
captincanuck wrote:
BusPriest wrote:
Brake light issue:
Yes and no, although only one switch is needed to activate the brake lights the dead switch would light the B light on the dash every time you stepped on the brakes, now if there were other previous wiring issues all bets are off.
Слава Україні!
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Aug 28, 2016 9:34 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
what starter are you using? if it's not the TDI one, the stock starter won't cut it.
I would suggest the adapter from RMW. I need to use those on the 091 transmissions. you can't get away with the keyhole mod on that starter
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
BusPriest
PostPosted: Sun Aug 28, 2016 10:24 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Ok I will try this.
Not a Priest.
BusPriest
PostPosted: Sun Aug 28, 2016 10:36 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
using a new bosch sr17x.
you think the the RMW adaptor and tdi starter is better than getting a hi torque starter? ok cool.
Not a Priest.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Aug 28, 2016 10:39 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
yes, the high torques are junk on vw's let alone a Subaru.
let me guess, it doesn't want to start hot, and sounds like a dead battery? the above mentioned set up will solve that
Jake Raby wrote:
Brian wrote:
BusPriest
PostPosted: Sun Aug 28, 2016 11:12 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Yep! Damn im tired of spendmoney on this thing! lol
Not a Priest.
BusPriest
PostPosted: Sun Aug 28, 2016 12:19 pm    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
BusPriest wrote:
Ok I will try this.
Pulled one plug off, jumped it, brake lights worked. Plugged it back in, pulled other plug and jumped it, brake lights worked. Does this mean I will need to replace both sensors?
Not a Priest.
BusPriest
PostPosted: Mon Aug 29, 2016 9:26 pm    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
So had an issue again the other night. The alternator is not wired correctly. Rewired it tonight and going to test it tomorrow by idling it while putting a strain on the battery.
Got brake switches ordered.
Went to order new starter and adaptor plate, learned that RMW and Westy Ventures are both currently out of stock for the next coming weeks. I guess this gives me time to rewire my interior toys.
So much fun to be working on the bus again.
Not a Priest.
BusPriest
PostPosted: Thu Sep 01, 2016 9:54 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
#burytheneedle
Not a Priest.
Kirk
Kirk is offline
PostPosted: Thu Sep 01, 2016 11:39 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Nice man! Didnt know you moved to Austin. Love this thread, always makes me want to convert my new late westy.
MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim
BusPriest
PostPosted: Thu Sep 01, 2016 12:03 pm    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
Thanks! And you should do it.
I'll sell you my adapter, flywheel, and 6 rib to help you start.
I'm already ready for Subarugears
Not a Priest.
Kirk
Kirk is offline
PostPosted: Mon Sep 19, 2016 11:20 am    Post subject: Re: John, the Engineer - '77 Champagne Transporter Build/Travels Reply with quote
I could be talked into most all that. Let me know.
Bear
Coble
Super
Oppenheim
Page 7 of 10
