pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 696 Location: Falls Church, VA
Posted: Wed Feb 18, 2015 10:35 pm Post subject: Point-y corner on both f. doors- hazard in parking lot |
I always tell my passenger not used to the wide swing of our doors to be careful not to dent or at least nick the paint on the car parked next to us. I'm pretty careful myself, but wondered if someone has devised a soft bumper to slip over the pointy corner to save adjacent cars. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10068 Location: N. Idaho
Posted: Wed Feb 18, 2015 10:44 pm Post subject: |
Check in stores that carry childrens stuff. You'll find self adhesive corner protectors that will probably work well, and since they're a kid safety item they tend to have liability associated and thus are better quality. We put a few things like that around our house when the kids were little. Corners of tile fireplaces, edges of wood stairs, etc.
Otherwise an auto upholstery shop sells a vinyl U shaped product designed to go on a sheetmetal edge. It has metal inside the vinyl so grips strongly. Would be a stout door edge guard for that. Something like "welting" I think? I have some from another project. Its a couple bucks a foot.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 13184 Location: Brookeville, MD
Gnarlodious  Samba Member
Joined: September 28, 2013 Posts: 1968 Location: Adobe Jungle USA
Posted: Thu Feb 19, 2015 7:06 am Post subject: |
I just put some silicone on them years ago and it has worked well. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD. |
Posted: Thu Feb 19, 2015 4:45 pm Post subject: |
Gnarlodious wrote: |
I just put some silicone on them years ago and it has worked well. |
Give a few details-- what kind of silicone, applied how-- Glue? |
Posted: Thu Feb 19, 2015 9:15 pm Post subject: |
I did a silicone blob 15 years ago on the deck of our boat against something chronically wacking it. Incredibly, it is still there after all that weathering with no sign of clouding or aging. It's clear silicone and I think it must have been some fancy high end Marine Grade. Find that, and he is right you can put a blob on the door corner and it will simply stay there.
Your door edge gaps must be tighter than mine. Mebbe because I took them off for painting and reinstalled all the panels myself. Hmmm, better start comparing my gaps to other Vanagons..... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX |
Posted: Thu Feb 19, 2015 9:51 pm Post subject: |
Nuttin fancy… just quality silicone. For best results use a soft (fine thread) piece of cotton soaking wet to shape the goo. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11499 Location: Santa Cruz, CA
morymob Samba Member
Posted: Fri Feb 20, 2015 5:53 am Post subject: |
A short piece of rubber tubing split dn one side add glue. |
Posted: Fri Feb 20, 2015 7:34 am Post subject: |
Yes, they don't cover the corner but the one that I had on the old van didn't either and it did a decent job of protecting adjacent vehicles in parking lots. I admit the solution isn't perfect if the other car is low enough for the front door to swing over a little. Training passengers to be aware of the door swing helps tremendously.  |
campism Samba Member
Joined: September 07, 2007 Posts: 3910 Location: Richmond VA
Posted: Fri Feb 20, 2015 7:49 am Post subject: |
You could mask the door corner edge and paint the area in question with several thin coats of plastic tool dip to build up a coated, cushion-y edge. The dip stuff is now available in several colors. _________________ '87 Westy in Wolfram Grey Metallic |
Home Team Van Samba Member
Joined: January 02, 2008 Posts: 465 Location: wilmington, nc
Posted: Fri Feb 20, 2015 8:18 am Post subject: |
I've seen something that looks pretty close to the trim pieces some folks use on their Vanagon gutters. _________________ _________________________________
82 Diesel Westy |
WandS Samba Member
Joined: January 05, 2007 Posts: 222 Location: Miami, Florida
Might try and work this option out from a Jeep.
It is an adjustable limiting strap. Wide open when camping, but you can set it tighter for day to day. Not sure how hard it would be to get out of the van, but just a thought.
_________________ 85 Westy Weekender with a Bostig Conversion. |
Posted: Fri Feb 20, 2015 8:20 am Post subject: |
A super simple solution would be to cut out a few 1" square pieces of bicycle inner tube, glue a couple of layers together, then attach (glue, rivet, screw, whatever) the layered bumper onto the outer surface of the door edge so that the edge of the rubber extends out past the door edge by a 1/4" of so. The rubber will fold under/around the edge of the door when pushed up against an object like another car. If you trim the rubber patches with some nice rounded corners and glued them to the door, it wouldn't look half bad either.
An alternative to letting the edges overhang a bit would be to cut a triangle relief section out at the corner that would allow you to fold the remaining flaps under/around the edge of the door where you could glue them down. The only issue with this might be the thickness of the rubber compared to the width of the door opening gap. _________________ Christopher
photogdave Samba Member
Joined: April 05, 2004 Posts: 2871 Location: Vancouver Island, B.C.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5610 Location: Crescent Beach, BC
Posted: Fri Feb 20, 2015 9:07 am Post subject: |
The Terrawagen Postal Flares do a great job of covering up that nasty point - and making your van look better at the same time!
Correction! The flares do not cover the pointy end of the door... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Last edited by Jake de Villiers on Mon Feb 23, 2015 9:08 am; edited 1 time in total |
