houseofboyd Samba Member
Joined: September 28, 2014 Posts: 613 Location: Flatwoods, Ky
Posted: Fri Feb 27, 2015 3:15 pm Post subject: Wiring Problem! Please Help! |
Don't know exactly what happened, but here's the situation. Right now, I have no brake lights and my drivers side headlight does not work, low beam or high beam. I've only found 2 loose wires. I've looked at the schematics until I'm blue, but they're greek to me. Hoping somebody can help. This is a '68 Beetle...I think my brake issue is related to the pics below. Any help will be appreciated...
Red wire, with small connector..comes up through the wheel well... where does it go????
_________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2103 Location: Milano, Italy
Posted: Fri Feb 27, 2015 3:46 pm Post subject: Re: Wiring Problem! Please Help! |
houseofboyd wrote: |
that's the signal wire for the brake warning light. it should go on terminal "K" on the back of the warning light itself. That's not normally directly related to the issues you are experiencing.
maybe one of the MC switches was going bad and someone removed that wire to avoid having the warning light on constantly when braking? _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Fri Feb 27, 2015 3:58 pm Post subject: |
Check the ground wire on the front left headlight |
sb001 Samba Member
Joined: May 19, 2011 Posts: 10399 Location: NW Arkansas
Posted: Fri Feb 27, 2015 6:32 pm Post subject: |
Ok, got the headlights to work...I actually feel like a bumbling idiot...dirty terminals in the fuse panel...removed the fuses, sanded the terminals, replaced fuses and the headlights work, both dim and bright lights, even the indicator in the speedo works now....so that problem is solved...now I need to figure out why the brake lights don't work.... |
Brake light switches run off the brake fluid pressure in the master cylinder- if your fluid level is too low the switches may not work. Does your pedal feel low or spongy? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Fri Feb 27, 2015 6:46 pm Post subject: |
sb001 wrote: |
Brake light switches run off the brake fluid pressure in the master cylinder- if your fluid level is too low the switches may not work. Does your pedal feel low or spongy? |
No, all new system...new master, lines, etc...I'm pretty sure they were working the other day...so I don't know what has happened...but the brakes are perfect.. _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
1968 VW Beetle
Posted: Fri Feb 27, 2015 8:58 pm Post subject: |
Well, it's fixed. Wish I could tell you exactly what I did to fix it, but I can't. It must have been a combination of things, but once I verified the brake lights worked by jumping them directly to a hot wire, put everything back and it started working....things that make you go hmmmmmmm. Now the only thing left to fix is the oil light. Sending unit is new, so I'm hoping it's just a bad bulb.....Anybody know of a way to test this with everything still connected? _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
1968 VW Beetle
volkswagen_bug Samba Member
Joined: November 04, 2008 Posts: 759 Location: Sumter, SC
Posted: Sat Feb 28, 2015 6:17 am Post subject: |
You didn't wrap the threads of your new oil pressure switch with Teflon tape or thread sealer did you? If so, take it off, because it uses the engine block as ground. Also, like you said, check the bulb in the cluster. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
"It’s better to give than to receive. Especially advice." -Mark Twain |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Sat Feb 28, 2015 6:35 am Post subject: |
Now the only thing left to fix is the oil light. Sending unit is new, so I'm hoping it's just a bad bulb.....Anybody know of a way to test this with everything still connected? |
Disconnect the wire to the sender, touch the wire to engine metal with the ignition in the on position, and the light should come on.
See above about the ground contact of the sender being through the threads to the case. And don't overtighten a sender. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Feb 28, 2015 1:51 pm Post subject: |
Looks like you're all set. _________________ 1968 Volkswagen Bug w/ 1600 Dual Port
