Vsyevolod Samba Member
Posted: Sat Feb 28, 2015 6:34 pm Post subject: Seeking: Bolt for front brake caliper |
88 Westy 2WD.
This is the second time in 4 years this has happened... There are two big-ass bolts that hold on the front brake calipers. Hardened steel, metric, 22mm head, etc. I need a new bolt as the old one is somewhere between Seattle and San Francisco. No brake shop that I visited in SF had anything close. I'm back in Seattle now and my VW guy doesn't have easy access to them.
So... what is the actual size of this bolt?
And where do I find one?
And when I find one, do I just torque the bejeesus out of it?
Last time if memory serves, I found a Porsche Brake guy down in Georgetown who had one rattling around in a drawer.
TIA,
Stephen
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Sat Feb 28, 2015 6:47 pm Post subject: |
Those bolts are supposed to be torqued to 200 Ft. Lb. Were they torqued correctly in the past? Are the threads in the caliper carrier compromised?
http://www.ecstuning.com/ES470013/
'92-'94 EVs use the same bolt for the caliper carrier.
A dealer would know it by part number N90499301 if you find a friendly one that will order it for you.
Posted: Sat Feb 28, 2015 7:00 pm Post subject: |
No idea if they were torqued correctly in the past, methinks they weren't if this is the second lost bolt in the 6 years that I've owned this little baby. I torqued down the only remaining bolt on the front passenger caliper and made it back to Seattle from SF in one piece... I used my torque wrench but didn't bother at the time to see how tight I was making it.
Thanks for the part number and torque amount, absolutely brilliant.
Stephen
insyncro Banned
Posted: Sat Feb 28, 2015 8:33 pm Post subject: |
Mark is correct, torque to 200 ft/lbs, using red loctite and marking the bolt head with a red paint mark is advised. |
buildyourown Samba Member
Posted: Sat Feb 28, 2015 8:41 pm Post subject: |
Visit your local Tacoma Screw. They almost always come through for me.
I'll go check my parts bin... |
1vw4x4 Banned
Posted: Sat Feb 28, 2015 11:25 pm Post subject: |
The torque really doesn't matter much as long as they are even.
PM me your name and address and I'll send you one, as long as your
not in any hurry.
Vsyevolod wrote: |
Stephen
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
insyncro Banned
Posted: Sun Mar 01, 2015 9:43 am Post subject: |
61Scout wrote: |
Torque values should always be followed. At times even a couple pounds might be added as historical feedback from the field dictates.
Were talking brakes here, not bolting down the jump seat. Follow the correct procedures and form the habit of torquing fasteners to their proper value.
-Kevin |
Agreed.
No time for opinions and guessing when it comes to brakes.
Others may pay the price for negligence and laziness ......
Do it right or leave it alone and pay someone who will do it properly. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
Terry Kay Banned
Posted: Sun Mar 01, 2015 11:06 am Post subject: |
<<And where do I find one?>>
Let's see;
Your rolling cracker box was manufactured by VW I think.
Your best bet for locating any parts for it, just might be a VW parts counter.
Tried that?
Much too simple--I know-- _________________ T.K. |
Posted: Sun Mar 01, 2015 7:34 pm Post subject: |
1vw4x4 wrote: |
PM me your name and address and I'll send you one, as long as you're not in any hurry. |
Thanks guys for all the wisdom and advice. I ordered the one that Syncrodoka linked to and will torque it to 200/lb. Plus I'll go around and torque the other three to make sure.
My tech said that loctite is not used on these bolts. Is this because perhaps the heat degrades it? And what does marking the bolt head with red paint do? Just tell any wrencher that loctite has been applied?
And thanks TerryK for the condescension disguised as humour, or is it humour disguised as condescension? I do live it the town that has perhaps one of the largest populations of Vanagons anywhere. And local dealers (Carter) and VW parts stores (Campbell-Nelson) do not carry this bolt. As I mentioned earlier, the last time I needed this bolt, I found one rolling around in a Porsche brake repair guys bin.
My FLAPS didn't carry one, nor could they order it. And it's just too far out of a part for Tacoma Screw to carry. All good ideas though. VanCafe doesn't carry it, nor does GoWesty. Yet the BusDepot does. $3.00 + change and $12.00 for shipping... The place that Syncrodoka pointed me was $4.00 + change and $8.00 for shipping so I went with that.
And FWIW, I do own a Bentley. Though I've never been able to glean any useful information out of it in the hours that I put into it... That's just me though and I'm the first to admit it's my own failings as a mechanic. I think that it's been written with enough vagary to put off the weekend warrior while encouraging the pro wrencher. It gets a big WTF out of 10 in my book.
Stephen
1vw4x4 Banned
Posted: Sun Mar 01, 2015 7:44 pm Post subject: |
You can get a thread seal (loctite) to withstand the heat. If I was you I would inspect the parts well before reassembling them. This is fairly
unusual to have these fall out. If in fact there was any chance of this
happening the factory would have taken action such as a thread seal. If you do not have this problem again, fire the previous mechanic! LOL
Vsyevolod wrote: |
1vw4x4 wrote: |
Stephen
Posted: Sun Mar 01, 2015 7:47 pm Post subject: |
I think I have 4 of them in my bolt bin. IIRC, I replaced them when I did my big brake upgrade. |
Posted: Sun Mar 01, 2015 10:02 pm Post subject: |
Great, I'll call you when the next one falls out...
Stephen
