Jilly Bean Samba Member
Posted: Wed Oct 17, 2018 4:11 pm Post subject: 1981 vanagon air cooled runs but no power |
I have an 81 air cooled vanagon.
When my bus is idling in neutral and I goose the fuel the engine revs up like it should. When I put it on gear and give it more fuel it bogs down and won't move at all. Some times it runs fine. Once it coughed three times while I was driving. I put the clutch in and and it continued driving. It's at the mechanic now. He has replaced the distributor cap and rotor and now he is replacing the engine temp sensor. You got any ideas |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Wed Oct 17, 2018 5:42 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
Could the catalytic converter be falling apart and restricting exhaust flow? _________________ ☮️ |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Wed Oct 17, 2018 5:47 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
vacuum leaks? timing off? dwell not set correctly? whats your compression?
Cal emissions or federal? _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Phaedrus Samba Member
Joined: January 06, 2014 Posts: 500 Location: Washington
Posted: Wed Oct 17, 2018 5:57 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
Air cooled bus doesn't have a cat, unless it's the CA model. In which case, worth peeking at.
You'll probably get more help in the T4/Bay Window forums.
There are so many variables that could cause intermittent running issues. Kind of impossible to help via internet forums. I'd start with doing a full tune-up if it hasn't had one in ~6000mi. Pull the plugs, inspect/clean/replace as necessary. Check/adj the valves. Do a comp check while you're at, see what the health of the motor is. Check/change the points. Make sure all of your engine bay connections are tight. Replace fuel filter as necessary. Time the thing. Make sure your vacuum advance is working properly. If not, pull the advance hose, plug it, and time all in at 30-34 degrees, whatever makes her happy without pinging.
Don't just go randomly replacing undiagnosed parts. That's not what a mechanic does, or should do... and that can often make it harder to actually resolve the issue... See if it still is acting up after a proper tune. It's really hard to tackle something that's intermittent. I need to see/hear/feel the issue in order diagnose/resolve it... _________________ 1986 WBX (Tin Top Camper) |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2327 Location: Southeast Kentucky
Posted: Wed Oct 17, 2018 6:25 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
I agree it could be a number of things and likely a combo, thus the variables as Phaedrus mentioned.
The suggested tune-up is a good start but leans toward throwing parts.
My 83 Air-cool, purchased at a Dealer in Knoxville, TN, has a CAT.
The mechanic needs to check the Timing and Dwell (assuming it still has a point dizzy). Also, with the Timing light he can see whether or not the Spark Advance is working and working properly. In the scheme of things, a bad coil can be a culprit that's hard to nail down.... keep that in mind.
Typically, if the Temp sensor goes bad or loses ground, the engine will only idle.
Seems the Air-cool has the ground connections on the left side of the fire-wall just over from the Coil. Your mechanic needs to make sure those grounds are functioning properly. The fuel injection system is grounded there.
Yes, as suggested, check for vacuum leaks.
Keep us posted. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Posted: Wed Oct 17, 2018 7:23 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
If it is timed according to the book and the vacuum retard can is bad your timing is going to be way way retarded and the engine will run like a pig. Best to time it at 28° BTDC @ 3500+ rpms, with the hoses off and plugged. If the retard can will not hold vacuum do not hook the retard hose back up to the distributor, but use a screw or something to close it off permanently. |
Posted: Wed Oct 17, 2018 7:29 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
AndyBees wrote: |
The suggested tune-up is a good start but leans toward throwing parts. |
I hear you. I still believe that if it's been over 6000mi since the last tune up, this is the place to start regardless of what's wrong. What's the point of fixing a vehicle that has a poor baseline? I want to know what I'm working with. You can end up chasing your tail real quick with multiple random tune-up components failing. If OP is short on cash and/or isn't anywhere due for a tune, I'm with you--vacuum leaks, timing/distributor condition, electrical connections, temp sensor.
Wildthings wrote: |
This is great advice, where I'd start, if the tune is not due, or should be addressed as part of the tune. _________________ 1986 WBX (Tin Top Camper) |
weswsimpson Samba Member
Joined: September 29, 2015 Posts: 191 Location: Chicago
Posted: Wed Oct 17, 2018 8:31 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
I fought with the same issue for two years, missed out on camping with my boys for too long. I even swapped a carburetor for the fuel injection with no improvement. Spent thousands..... Finally I gave up and did a subaru conversion. Best decision of my life! Did it myself and cheaply. Search for "pokevan no more" for my build notes. I love the van now--hated it for far too long....
I believe that it was a worn cam, but decided not to waste my time to find out. The 80-83.5 are red-headed step-children to this group.... and there's not a lot of parts out there or knowledge. Even the transmission is unique to these years! I found much more support with the subaru-swap community.
If you persist with the air-cooled engine you might want to check out this group, I even had the expert scratching his head after messing with it for a day.... www.itinerant-air-cooled.com
Cut your losses and go subaru power! |
Posted: Wed Oct 17, 2018 8:58 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
Pokeman, the guy has an Air-cool and is asking for help. I doubt he's looking to do an engine conversion.
When I did my ALH TDI conversion, I used a 1980 DK tranny. Finding parts was as simple as contacting Weddle.
Except for the engine, practically everything else on an Air-cool is pretty much interchangeable with the other WBXers. As for the engine, parts are available for them too.
During the 7 trips I made to Alaska with my 83 Air-cool it performed well. I did have one break-down and knew I had problems before I left (long story) and knew better than to hit the road. Anyway, looking back on how it performed and my experience with the 1.9 WBXer and 2.1 WBXer, if I had my choice between the three to drive back to Alaska, I'd take the Air-cool hands down. A properly tuned Air-cool is a hoss. But, that's why I installed an ALH TDI in my 84, to make those long trips. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Wed Oct 17, 2018 11:39 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
[quote="AndyBees"]Pokeman, the guy has an Air-cool and is asking for help. I doubt he's looking to do an engine conversion.
Yep, I had an air-cooled that lacked power too.... I wish someone had "helped me" by advising me to ditch the under-powered engine and go with a Subaru, I would have been time and money ahead of the game. |
Posted: Wed Oct 17, 2018 11:45 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
Adjusting the valves is another important tune-up thing to do... but good luck trying to adjust them with those hydraulic lifters! If they sit for a while, they won't pump up.... then your adjustments are all off.... what a nightmare!
Read up about them here:
http://www.ratwell.com/technical/HydraulicLifters.html |
Posted: Wed Oct 17, 2018 11:49 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
it could also be the air flow meter.... oh, the nightmares are returning just thinking about it.... |
Posted: Wed Oct 17, 2018 11:58 pm Post subject: Re: 1981 vanagon air cooled runs but no power |
or a fuel filter full of rust... |
Posted: Thu Oct 18, 2018 12:26 am Post subject: Re: 1981 vanagon air cooled runs but no power |
weswsimpson wrote: |
If you follow the correct procedure you can easily adjust a flat hydraulic lifter. I have know people who got more miles out of a factory aircooled Vanagon engine than most people got out of a factory WBXer. |
Posted: Thu Oct 18, 2018 3:02 am Post subject: Re: 1981 vanagon air cooled runs but no power |
Nice thing about a Subaru conversion is you will never have another problem. Ever _________________ ☮️ |
74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Thu Oct 18, 2018 3:27 am Post subject: Re: 1981 vanagon air cooled runs but no power |
actually adjusting hydraulic lifters is super easy...Don't knock an aircooled engine, it sounds like you wouldn't have been happy no matter what, complaining about everything. _________________ 73 Thing
80 Vanagon Westy |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 699 Location: long Island new york
Posted: Thu Oct 18, 2018 4:16 am Post subject: Re: 1981 vanagon air cooled runs but no power |
Patients my friend, it takes time, that i can attest to! Mine is a 80, and after the rebuild it took 6 months to get it to the point of running awesome and driving it daily! And now when you drive past me, you'll know its me because I'm grinning ear to ear! You'll get it, your in good hands here, Our fellow Samba members got me to this point, and i thank them all ! _________________ Enjoy the ride....
72 bug
80 westfalia |
danfromsyr Samba Member
Posted: Thu Oct 18, 2018 7:35 am Post subject: Re: 1981 vanagon air cooled runs but no power |
wet air cleaner,
mice nest in air cleaner
water in fuel from bad seals on top of vapor tanks in wheel wells.
cracked S boot from throttle body to AFM
unplugged AFM
clogged fuel filter/bad gas
tired fuel pump not able to make pressure/volume
to name a few. _________________
Abscate wrote: |
Posted: Thu Oct 18, 2018 10:01 am Post subject: Re: 1981 vanagon air cooled runs but no power |
calo1956 wrote: |
Patients my friend, it takes time, that i can attest to! Mine is a 80, and after the rebuild it took 6 months to get it to the point of running awesome and driving it daily! And now when you drive past me, you'll know its me because I'm grinning ear to ear! You'll get it, your in good hands here, Our fellow Samba members got me to this point, and i thank them all ! |
This ^^^^^^ is what it takes! Putting down another member's vehicle/engine when they are asking for help is not what this forum is about, or is it?
Yes, there are a number of conversions to consider. Such a move can be a wash, a nightmare or a pleasure... seems I've read about all three. Mine has been a pleasure, even though I did have a few nightmare episodes along the way !
I think we can talk the OP through his problems. However, he needs to obtain a Bentley and begin to learn about his vehicle and it's power plant.
Process of elimination is the obvious approach without throwing parts at it. However, sometimes throwing parts ends up being part of the process.
The OP needs to make a list of all the things that have been suggested. Maybe give them to his mechanic. Hopefully, the mechanic has the skills to deal with them appropriately. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
metropoj Samba Member
Posted: Thu Oct 18, 2018 11:55 am Post subject: Re: 1981 vanagon air cooled runs but no power |
For me, the compression test is usually the first thing I'd look at before I start throwing parts and a mechanic's 'On the clock" time (money) at it.
After that, all the basics of ground wires, Vacuum hoses, etc. AT least you stand a fighting chance .
Good luck on the hunt. _________________ John.
86 TiiCo powered Westy. |
