Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Mar 03, 2015 12:23 pm Post subject: Washer no squirt |
My windshield washer will not squirt. The washer motor operates and I've cleaned the nozzles with a needle. There was an inch of scum in the bottom of the washer fluid tank and the end of the pump was scummy. I assume there is blockage in the tubing from the pump to the nozzle. I wanted to blow compressed air through the tubing up to the nozzles but I've been unable to remove the tubing from the pump. My plan is to cut the tubing from the pump, blow air, and install a check valve and some new tubing at the pump. Because of being unable to remove the tubing from the pump I have not been able to verify that the pump will actually move fluid. It may have internal blockage from trying to pump scum. I will verify that the pump moves fluid before using compressed air in the tubing.
If the nozzles or tubing are blocked with scum what are my chances of rupturing the tubing from the pump to the nozzles with compressed air?
Aloha
tp |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Tue Mar 03, 2015 12:43 pm Post subject: Re: Washer no squirt |
Tom Powell wrote: |
I would imagine that the chance is really good considering the age of the tubing and the relatively low pressures that the system was designed to operate under. Also, if you don't disconnect the hoses from the squirter jets, I would bet that the blockage just dams up at that point since the jet orifice is so much smaller than the tubing. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue Mar 03, 2015 1:53 pm Post subject: Re: Washer no squirt |
SCM wrote: |
Tom Powell wrote: |
I would imagine that the chance is really good considering the age of the tubing and the relatively low pressures that the system was designed to operate under. Also, if you don't disconnect the hoses from the squirter jets, I would bet that the blockage just dams up at that point since the jet orifice is so much smaller than the tubing. |
It would seem more sensible to blow air into the nozzles with the tubing off the pump. I've read some horror stories about the tubing to the nozzles being dropped into the black hole under the dashboard and/or tubing replacement.
Aloha
tp |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Mar 03, 2015 1:57 pm Post subject: |
Mine stopped working once with a nearly full tank; I primed the hoses from the nozzle end and it started working again. Worth a shot. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Tue Mar 03, 2015 2:01 pm Post subject: |
joetiger wrote: |
Mine stopped working once with a nearly full tank; I primed the hoses from the nozzle end and it started working again. Worth a shot. |
That's a good idea. I have a squirt bottle and I'll fill it with washer fluid as pump some in at the nozzles. Maybe I can push the scum back into the pump and grind it up. I'll be back with the results.
Aloha
tp |
Posted: Tue Mar 03, 2015 2:39 pm Post subject: |
VOILA
EUREKA
FABULOUS
This is the tool that did the job.
I filled a wash bottle with some windshield washer fluid, put some in the reservoir, squirted the fluid into the nozzles with as much seal and pressure that I could get, turned on the wipers and pulled the squirt lever. Fluid up and over the pop top.
thanks to joetiger for the help to a simple solution.
DUH:
Why didn't I think of that first before cleaning the nozzles with a needle, dropping the reservoir, checking power to the pump, attempting to remove the tubing, attempting to blow air into the pump by mouth with some heat shrink, giving up, putting the reservoir back in, ordering a check valve, and posting on TheSamba?
Aloha
tp |
Posted: Tue Mar 03, 2015 5:44 pm Post subject: |
Glad it worked out! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
LTBeck41 Samba Member
Joined: January 09, 2005 Posts: 44 Location: Jacksonville FL
Posted: Sun May 03, 2015 4:26 pm Post subject: Squirter Nozzel |
How is the squirter nozzle removed? Pry from outside or is there some darn clip under the dash? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon May 04, 2015 4:03 am Post subject: Re: Squirter Nozzel |
LTBeck41 wrote: |
Grab with pliers, 1/4 twist & pull out. Don't lose the tubing down the hole... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
