crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Thu Apr 13, 2017 11:35 am Post subject: Re: Turn signals not working |
What happens when the 4-ways are on? Try rocking the 4/way switch on and off 10 times very firmly.
Mark |
Paulbeard Samba Member
Posted: Thu Apr 13, 2017 11:58 am Post subject: Re: Turn signals not working |
Hmm, didn't try that. I pulled the wiring off that socket, sprayed with contact cleaner, greased and replaced them all. No love there. Starting to think it's the switch itself but I don't know how to confirm it. Pulling the connector and testing the terminals from the switch seems the most reliable way but I don't have the patience for that today. I'll see if I can find a pinout for the switch that might help. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Thu Apr 13, 2017 2:25 pm Post subject: Re: Turn signals not working |
crazyvwvanman wrote: |
Huh. They work if the headlight switch is off, they don't work if the switch is in either position…I worked it a bunch of times, nothing changed. So what does that point to? A bad turn signal switch? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Thu Apr 13, 2017 3:12 pm Post subject: Re: Turn signals not working |
I replaced that bulb (l/f) not long ago and didn't use a dual filament bulb.
Now all is well. Of course the rear on that side decided it needed attention as well, so I have R&R it with some dielectric grease.
If only they were all this easy… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Thu Apr 13, 2017 5:39 pm Post subject: Re: Turn signals not working |
make sure that the bottom metal contact has a good connection with the bulb(s) by bending it up a bit.... |
mad.macs Samba Member
Joined: August 17, 2007 Posts: 230 Location: Woolwich Maine
Posted: Wed Jul 22, 2020 4:26 pm Post subject: Re: Turn signals not working |
I had a similar issue.
Right turn signal worked.
Hazards worked.
Left turn signal would Buzz the relay.
Turn the lights to any position, No blinkers.
Used a jumper to bypass the turn signal switch. Left turn signal still buzzed.
Removed the left front bulb holder, Corrosion city. I’m going to order 2 since the right one does not look any better.
New lenses too I guess. The passenger one is cracked, I’m not sure how moisture is getting to the one on the right though.
I’m also going to get some LED bulbs for it. _________________ '84 Rivi Vanagon Auto Trans, Stock WBX |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Wed Jul 22, 2020 7:08 pm Post subject: Re: Turn signals not working |
mad.macs wrote: |
I’m not sure how moisture is getting to the one on the right though. |
Check the rubber boot. If it's old and dry, it doesn't adhere to the the wires properly, and moisture/water drops can seep inside.
For the LED, look into "switchback" models. They look really cool! _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Wed Jul 22, 2020 8:39 pm Post subject: Re: Turn signals not working |
Yah, I'm going to spend some time with some silicone when the new bulb holders and Lenses come in. _________________ '84 Rivi Vanagon Auto Trans, Stock WBX |
