Shoebox DigiTool
Page: Previous  1, 2
Letsgo
Letsgo is offline
PostPosted: Fri Mar 06, 2015 7:25 am    Post subject: Reply with quote
What does the OG before the ECU(engine control unit) stand for?
Tom Powell
Tom Powell is offline
PostPosted: Fri Mar 06, 2015 7:28 am    Post subject: Reply with quote
OG Original German - Term used to describe a vehicle, part, or characteristic (such as paint) in original condition.
from the Technical section:
Aloha
tp
Letsgo
Letsgo is offline
PostPosted: Fri Mar 06, 2015 7:38 am    Post subject: Reply with quote
Thank you Sir.
Gunldesnapper
Gunldesnapper is offline
PostPosted: Tue Mar 10, 2015 5:58 am    Post subject: Reply with quote
Going to be a long day at work, my Digitool showed up last night. Meetings and a ton of work need to get done before i get to play. Sometimes being an adult sucks.
1990 Vanagon Carat "Pig"
USN RET
Tom Powell
PostPosted: Tue Mar 10, 2015 8:49 am    Post subject: Reply with quote
Do you also have an ECU wired for the digital?
Aloha
tp
Gunldesnapper
PostPosted: Tue Mar 10, 2015 10:20 am    Post subject: Reply with quote
I do not, i will be using mine.
USN RET
Tom Powell
PostPosted: Tue Mar 10, 2015 11:49 am    Post subject: Reply with quote
You'll have to wire your ECU to accept the cable from the ECU to the digitool. Do you have the cable?
Aloha
tp
Gunldesnapper
PostPosted: Tue Mar 10, 2015 12:11 pm    Post subject: Reply with quote
I do, the kit i bought had everything except a wired ECU. I have a soldering iron and the rusty skills to use it. Probably going to leave work early to get this ball rolling.
USN RET
MarkWard
MarkWard is offline
PostPosted: Tue Mar 10, 2015 1:09 pm    Post subject: Reply with quote
Post up pictures or it never happened. Good luck.
Gunldesnapper
PostPosted: Tue Mar 10, 2015 6:25 pm    Post subject: digitool reading question Reply with quote
Well the wired ECU is in (my solder skills are super rusty) and I took some readings. The thing that has stood out is the Battery Voltage. Sitting it is at a steady 12.28V. While running (warm/cold/30 MPH) it oscillates between 0-13V. This doesn't seem right and I wouldn't know why it would do this.
Another thing is my 02 ground. Instead of 0V I get -.03V sitting. While running it sits from .24V to .53V. Tomorrow I'm going to read it out and see what I get.
Advice? Knowledge to be shared? The engine issue I have is a rough idle in park, loss of power under load with shuddering. Stalling when I slow down at stop lights, starts right up though.
USN RET
Tom Powell
PostPosted: Tue Mar 10, 2015 6:35 pm    Post subject: Reply with quote
We assume you have this.
http://www.van-cafe.com/shop/images/ecumanual.pdf
There have been posts about the O2 sensor ground wire shorting out. I don't know if that's your problem, but do a search and see what others have said and done.
Aloha
tp
Gunldesnapper
PostPosted: Tue Mar 10, 2015 6:41 pm    Post subject: Reply with quote
I do, thanks Tom. The battery voltage is the part that really baffles me though.
USN RET
Page: Previous  1, 2
Page 2 of 2
