brainwash Samba Member
Posted: Sat Mar 07, 2015 12:46 pm Post subject: What am I Missing Here? Big gaps in Exhaust? |
My 78 bus has some large gaps entering the fan shroud here. Are these normal? Is it missing a top piece? TIA!
grtfldan Samba Member
Joined: December 06, 2007 Posts: 141 Location: Maryland
Posted: Sat Mar 07, 2015 1:44 pm Post subject: |
theres covers that look like this:
_________________ 79 Bay 2.0 Fuel Injection
79 Bay project |
Tcash Samba Member
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Sat Mar 07, 2015 2:22 pm Post subject: |
Not exhaust, part of the heating system. The lower flaps and covers are missing. So you have cooling air dumping to the outside without doing any cooling in the heater boxes and without feeding hot air forward to the cab. I'm just installing mine if you want to see the pics. |
Posted: Sat Mar 07, 2015 2:56 pm Post subject: |
Hey, thanks everyone! Appreciate the correction as well as all the pics and diagrams. PITA Pan, I'll also take you up on the offer to see your pics of the installation you did. |
Posted: Sat Mar 07, 2015 3:08 pm Post subject: |
brainwash wrote: |
It's in progress. I'm doing a molded gasket instead of a paper one, so I have been documenting that. I'll take pics of the next two steps in the process, than that will make sense.
SO far this is the setup for molding the gaskets. The molding material will be grey RTV silicone. The insides of the covers have been sandblasted and then small silicone discs have been stuck down to establish the gasket thickness.
The next step is to glop on the silicone and bolt them in place on the motor. The silicone cures then they come off, get trimmed, and the final install with the flaps. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Mar 07, 2015 3:20 pm Post subject: |
Nice! You can also dilute RTV, build clay or tape dams around the area and pour the RTV in. Ray |
Posted: Sat Mar 07, 2015 3:24 pm Post subject: |
That's quite the project you've got going there, PITApan! Quite impressive. I'd have no idea how to do that, but will take some lessons here. |
Posted: Sat Mar 07, 2015 3:36 pm Post subject: |
raygreenwood wrote: |
I have some two part RTV. KISS. Also, this gives me a very close capture of the opposing surface.
I did this routine on the rocker covers on another engine. I was tired of weepy gaskets and replacing them. I used red RTV but too soft. It's holding up so far, and weep free, but will have to see how many remove/replace cycles it will take. These things come off every 15 years if the engine is good. |
Tcash Samba Member
Posted: Sat Mar 07, 2015 4:02 pm Post subject: Heat exchanger Fan shroud Air inlet cover plates and gaskets |
Google these part numbers.
021 256 321 D/ LEFT COVER PLATE, L, EXHAUST PREVENTS HEAT LEAKS
021 256 322 B/ RIGHT COVER PLATE, R, EXHAUST PREVENTS HEAT LEAKS
Thread on subject.
Non-return Flap Pins
Gaskets:
Thanks to Mayor Ratwell
Making Fan Shroud Gaskets
Good Luck
Tcash
Posted: Sat Mar 07, 2015 4:04 pm Post subject: Re: Heat exchanger cover plates |
Tcash wrote: |
/snip
There is a nice post on making the gaskets. But I cannot find it.
Good Luck
Tcash |
'cause I haven't finished it yet. |
Tcash Samba Member
Posted: Sat Mar 07, 2015 4:14 pm Post subject: Re: Heat exchanger cover plates |
PITApan wrote: |
Tcash wrote: |
/snip
Good Luck
Tcash |
GET ER DONE |
Posted: Sat Mar 07, 2015 4:22 pm Post subject: |
These are the holes you've noticed and the holes with the covers on. On the holes notice the ears with the bores for the flap pins. Rights then lefts.
Posted: Sat Mar 07, 2015 4:54 pm Post subject: |
I will repeat my method here as it is easy and works well. I use high temperature copper silicone and lay a bead on the cover and then let it skim over well but not fully set. I then install the cover and tighten it until the silicone makes a good contact with the fan shroud and heater box. If the skin breaks in a few places then so much the better as it will help lock the heat exchanger cover to the fan shroud and prevent wear between the two, but since most of the silicone stays skimmed over the cover is still readily removable and can be reinstalled using a minimal amount of new silicone. |
Bleyseng Samba Member
Posted: Sat Mar 07, 2015 7:59 pm Post subject: |
The real gaskets are available guys instead of RTV. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sat Mar 07, 2015 8:03 pm Post subject: |
Bleyseng wrote: |
The real gaskets are available guys instead of RTV. |
Yes but RTV will do a much better sealing job on old deteriorated surfaces. |
Tcash Samba Member
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Sun Mar 08, 2015 2:41 am Post subject: |
I did this a few months back. I used a sheet of cork gasket material and the diagrams from Ratwell's site.
http://www.ratwell.com/technical/Heating.html#gaskets
To be honest, I had my wife do the work. She's much better at that type of thing that I am. I don't have the patience/attention for small detailed work. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Sun Mar 08, 2015 7:44 am Post subject: |
oscarsnapkin wrote: |
To be honest, I had my wife do the work. She's much better at that type of thing that I am. I don't have the patience/attention for small detailed work. |
I made them too from cork/ Ratwell. I used RTV to seat and seal them as well. Easy and straightforward _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
VW Addict Samba Salesman
Posted: Tue Aug 18, 2015 2:35 pm Post subject: Re: Heat exchanger Fan shroud Air inlet cover plates and gas |
Tcash wrote: |
Thread on subject.
Gaskets:
Good Luck
Tcash |
Is (Right) side considered passenger side? |
