hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Mar 08, 2015 9:44 am Post subject: Washer bottle valve dissasembly *SOLVED* |
Hi guys,
Does anyone know if i can dissasemble the valve in the washer bottle?
it seems to be stuck or clogged. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Mon Mar 09, 2015 4:29 am Post subject: |
I emagine if it stuck or clogged it could be remidied by soaking it in some sort of non faris solvent for awhile and clean it out. if it is clogged that may mean it has some sort of filtration element and in that case I emagine it could be opened somehow. if it is stuck you may want to wait until someone can give you a definitive anser. I would not attempt to do seriuos work to it without knowing for sure since they dont make them anymore and prices for good used ones will be outrageous. you can always convert to a 12v version and have the luxury of being able to replace parts. sorry I could not tell you what you want to know. |
Posted: Mon Mar 09, 2015 4:59 am Post subject: |
Plenty of used ones avalible, i was thinking about converting to electric, but if i can fix this one i will use the orriginal. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Sun Mar 15, 2015 8:30 am Post subject: |
Turns out it was fine, just needed a little WD40, put 45Psi on it and now it works like a champ! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
