CV Axle replacement
vandoka
vandoka is offline
PostPosted: Sat Mar 14, 2015 12:29 pm    Post subject: CV Axle replacement Reply with quote
I was replacing the CV axles on my 2wd. Vanagon. When I took one axle off I found a thin film of an old gasket pasted to the mounting surface of the axle shaft. Does anyone have info. regarding this part? It seems pretty thin. And I have not seen it referred to in any posts or in parts kits.
msewalson
msewalson is offline
PostPosted: Sat Mar 14, 2015 12:51 pm    Post subject: Reply with quote
Does it look like this?
http://www.van-cafe.com/home/van/page_594_1241/drive-flange-cap-p594.html
Matt
87 Syncro w/EJ22
vandoka
vandoka is offline
PostPosted: Sat Mar 14, 2015 12:59 pm    Post subject: Reply with quote
No, it was on the wheel side of the axle between the face of the CV joint and the Axle Shaft. I did see a picture of it in the Bentley, in section 42.7
msewalson
PostPosted: Sat Mar 14, 2015 1:00 pm    Post subject: Reply with quote
Post a pics if you can.
Matt
87 Syncro w/EJ22
Wildthings
Wildthings is offline
PostPosted: Sat Mar 14, 2015 1:11 pm    Post subject: Reply with quote
There have been a variety of parts added to CV's over the years and then discontinued. I suspect your gasket it one of them.
vandoka
vandoka is offline
PostPosted: Sat Mar 14, 2015 1:18 pm    Post subject: Reply with quote
this shows what I believe I am looking at. It was so destroyed when I took the axle off I could not identify what it was.
If folks are not in the habit of adding any such part when they re-grease and re-install CV's then I am not concerned to go without it..?
IdahoDoug
IdahoDoug is offline
PostPosted: Sat Mar 14, 2015 1:29 pm    Post subject: Reply with quote
Yes, you can safely ignore it and proceed. It was later deemed superfluous.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
furrylittleotter
furrylittleotter is offline
PostPosted: Sun Mar 15, 2015 10:40 am    Post subject: Reply with quote
They are remnants from a time long past. Proceed.
Neil2
