chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Sat Mar 14, 2015 6:41 pm Post subject: |
You have probably checked, but could it be a slightly sticky driver's side brake caliper? I had a squeak last year and that was the cause. _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
Tcash Samba Member
Posted: Sat Mar 14, 2015 7:06 pm Post subject: |
Start spraying individual parts with silicone spray, one at a time. This will help you isolate the problem.
Good Luck
Tcash |
chabanais Samba Member
Posted: Sat Mar 14, 2015 10:05 pm Post subject: |
I sprayed Lithium Grease on the two places where the driver's shocks attach to the suspension amd squeak is gone.
I think the lower mount is the culprit as it is a more complex joint.
Wonder if a bushing can be replaced or not.
Thanks for everybody's help. _________________ "I spud therefore I yam." |
busdaddy Samba Member
Posted: Sat Mar 14, 2015 10:27 pm Post subject: |
Did you adhere to the recommendations in the big green book when installing them?, they have to be tightened on the bottom first in a tilted back position IIRC. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Mar 15, 2015 12:05 am Post subject: |
busdaddy wrote: |
Did you adhere to the recommendations in the big green book when installing them?, they have to be tightened on the bottom first in a tilted back position IIRC. |
I trusted a shop that turned out to only get 80% of jobs correct because they're dumb, sloppy, or apathetic despite being an established place well known by the VW community.
I'll look in my Bentley on Monday...thanks for the tip. _________________ "I spud therefore I yam." |
Tcash Samba Member
Posted: Sun Mar 15, 2015 9:02 am Post subject: Bushings |
busdaddy wrote: |
Good point Busdaddy.
Just an fyi. This is done to adjust the bushing to its rest position. This position would be with the vehicle on its wheels and at rest.
Note, it is best to snug suspension bushing fasteners first. Lower the vehicle on its wheels and then torque the fasteners. If this is not possible, snug fastener, jack up the wheel to load the suspension (making sure vehicle is secure on jack stands) and toque the fasteners.
Hope it helps
Tcash |
Tcash Samba Member
Posted: Sun Mar 15, 2015 9:13 am Post subject: |
chabanais wrote: |
I sprayed Lithium Grease on the two places where the driver's shocks attach to the suspension.
You might want to clean the Lithium grease off. I have seen some shock bushings swell from having oil on them. So all are not formulated to be safe for petroleum products.
They can. But not necessary. I would say, have the shop clean them and install them correctly.
Posted: Sun Mar 15, 2015 11:26 am Post subject: |
Tcash wrote: |
I would say, have the shop clean them and install them correctly. |
This is the plan. Now that I know where the noise originates. I'm still working on restoring my horn which hasn't worked for 14 years so I'm adding it to the list.
It's amazing how one tiny little area can make your Bus sound like Wild West whore house beds after cowboy payday! _________________ "I spud therefore I yam." |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Mar 15, 2015 12:21 pm Post subject: |
Good luck with the horn. Second to ball joints. It hate horns the worst. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
brainwash Samba Member
Posted: Sun Mar 15, 2015 1:27 pm Post subject: |
aeromech wrote: |
I ruined my hearing on Pink Floyd |
Could you repeat that?
Pink Floyd had to be listened to loud and was the quintessential music when shopping for speakers. |
Tcash Samba Member
Posted: Sun Mar 15, 2015 5:23 pm Post subject: |
I was told there was a rubber grommet I needed.
Maybe I should get a locomotive horn. They have their own button I could put under my horn button and then people would REALLY get out of my way!
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sun Apr 22, 2018 7:53 pm Post subject: Squeak is gone! |
I had an incredibly annoying squeak coming from under the front cab for over a year. It got worse on bumpy roads, so I assumed it was related to the suspension.
So I did a Samba search using just the keyword "Squeak" and checking the "Title only" box, and VOILA!... this answer presented itself:
chabanais wrote: |
I sprayed Lithium Grease on the two places where the driver's shocks attach to the suspension and squeak is gone.
Thanks for everybody's help. |
It worked! I drove 20 miles afterward, and the squeak was completely gone!
However, now that it's quiet in the cab, I notice the smaller rattles and squeaks, but I'll address them one at a time.
It's just GREAT to drive Chloe without the constant squeaking.
Thanks Chabanais! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
