Westfalia interior help/confusion
wasabiVdubbin
wasabiVdubbin is offline
PostPosted: Tue Mar 17, 2015 11:49 am    Post subject: Westfalia interior help/confusion Reply with quote
What does the missing piece here look like? Not the cabinet door but the small circle.
Where can I find this vent?
My sliding door handle does not feel or open right does anyone have advice on how the true adjustment is to be set?
Bleyseng
Bleyseng is offline
PostPosted: Tue Mar 17, 2015 7:33 pm    Post subject: Reply with quote
This is the pushbutton lock with cover for the seat/bed
This is the vent for the refer
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
obieoberstar
obieoberstar is offline
PostPosted: Tue Mar 17, 2015 9:19 pm    Post subject: Reply with quote
I used the Bentley manual to try and adjust the sliding door handle. It seems that the manual does not cover the late bay models.
The day before I lubed all pivot points, lubed the upper and lower rollers, the pivot linkage. The plastic block on the sliding door was ok with no cracks.
The door closed really well, much better than before. Minimal effort to get it to shut. Not as easy as a Vanagon, but very close. Cable adjustment really did not seem to be adjusted.
I would recommend cleaning and lubricating everything before going after the sliding door cable.
I wanted to get it perfect using the Bentley only to find that it covered sliding doors with 2 cables.
Tcash
Tcash is offline
PostPosted: Tue Mar 17, 2015 9:36 pm    Post subject: Reply with quote
Thanks to Mayor Ratwell
Sliding Door
Owners Manuals
Good Luck
Tcash
