Best way to go about this?
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Mar 25, 2015 12:33 pm    Post subject: Best way to go about this? Reply with quote
Just got a metal filter that's 1/4 inch - I think that's closest to my 5mm line. I am able to force the line onto the flare of the filter but is that safe? Would I be able to cut the flare off? Or should I just run some 1/4 inch hose?
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
c21darrel
c21darrel is offline
PostPosted: Wed Mar 25, 2015 12:38 pm    Post subject: Reply with quote
If you still have an inch or so ...id cut the flare end off. Shocked
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Mar 25, 2015 12:47 pm    Post subject: Reply with quote
I can't tell if you're forrealz or not Darrel Confused
I'll be driving it Friday, and want to get it done today or tomorrow Razz
c21darrel
PostPosted: Wed Mar 25, 2015 12:53 pm    Post subject: Reply with quote
im serious. The flare can foul your connection or damage the smaller hose (fighting it on with pliers) if you cant get it over and past it by an inch or so. If you still have plenty of length left after cutting flare off you will be fine. Be easy if nice metal 6mm filters were easy to find.
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Mar 25, 2015 2:25 pm    Post subject: Reply with quote
Thanks Darrel! All I needed!
Orderd three Feet of hose(not exactly 3')and had none to spare - the lines are pretty tight now, no slack.
c21darrel
PostPosted: Wed Mar 25, 2015 2:53 pm    Post subject: Reply with quote
Pictures and everything. Excellent!!
GhiaBuild
swavananda
swavananda is offline
PostPosted: Wed Mar 25, 2015 3:08 pm    Post subject: Reply with quote
Good on Ya! Next you can up your game on hose clamps Cool
I was doing "Van Life" way before there was ever such a thing.
https://www.thesamba.com/vw/forum/viewtopic.php?t=489454
mountainkowboy
mountainkowboy is offline
PostPosted: Wed Mar 25, 2015 5:32 pm    Post subject: Reply with quote
Yup...used those clamps and I went with a glass cleanable filter for mine. You can see when it needs to be cleaned! Smile
Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater"
-Zodiac-
-Zodiac- is offline
PostPosted: Thu Mar 26, 2015 8:00 am    Post subject: Reply with quote
Is there a plus side to using those hose clamps, or do they just look better?
And I've heard bad stuff about those glass filters Shocked don't know how much of it is true though!
swavananda
PostPosted: Thu Mar 26, 2015 10:49 am    Post subject: Reply with quote
Well,......... technically those clamps work better by applying more uniform torque around the hose. But really they are more important on high pressure Fuel injection system. So for a measly 3psi carb line, they are just for looks !
VeloMikey
VeloMikey is offline
PostPosted: Thu Mar 26, 2015 11:12 am    Post subject: Reply with quote
Where do you guys purchase those hose clamps?
'58 Ghia
didget69
didget69 is offline
PostPosted: Thu Mar 26, 2015 11:17 am    Post subject: Reply with quote
At your FLAPS... ask for 'fuel injection hose clamps'.
http://shop.advanceautoparts.com/p/autocraft-3-8-a...89016086-P
http://www.napaonline.com/Catalog/CatalogItemDetai...0006394100
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
didget69
didget69 is offline
PostPosted: Thu Mar 26, 2015 11:19 am    Post subject: Reply with quote
If the glass-housing fuel filters are not restrained/held down, they can flap around & potentially hit something nearby & crack/break. I run the metal canister fuel filter in nose of car, underneath the fuel tank, in conjunction with the tank strainer & filter screen in the fuel pump. No fuel filter in the engine bay.
bnc
mountainkowboy
PostPosted: Thu Mar 26, 2015 2:37 pm    Post subject: Reply with quote
Longer hoses and ziptied to the passenger hard breakline
Chuck in Socal
78 Honda CB750K
