dreamycat1 Samba Member
Joined: March 25, 2015 Posts: 4 Location: Knoxville tn
Posted: Wed Mar 25, 2015 3:28 pm Post subject: removing a wood headliner on a 71 westfalia bus |
I'm 17 and a girl and this is my first car and it's a 71 Volkswagen bus westfalia the headliner sheds on me,cause it's original and I'm wondering how I can't take it down to spray a seal on it and put in back up I took the screws off now what thanks in advance |
babysnakes Samba Member
Posted: Wed Mar 25, 2015 4:43 pm Post subject: |
If it is supported by the channels above the windows and not some hack, you should be able to push upwards on the sides about 1/4" to 1/2" to get it to pop out of the channel. Don't rush, and have someone to help you. |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Wed Mar 25, 2015 5:53 pm Post subject: |
FYI if you use the forum search engine on thesamba, highlight the word Forum on the top of this page, it will allow you to select Search in a drop down menu, when you get to the search page:
In the drop down box next to the word “Forum:” Select, Bay window Bus
In the drop down box next to the word “Search previous:” Select, Search title only
In the drop down box next to the word “Sort by:” Select, Replies
Then enter key words of what you are looking for in the “Search for Keywords:” field
You can use AND to define words which must be in the results, OR to define words which may be in the result and NOT to define words which should not be in the result. Use * as a wildcard for partial matches
With the search method above
Wood AND Headliner =
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Welcome to thesamba and good luck with your new bus :0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Last edited by Lionhart94010 on Wed Mar 25, 2015 8:28 pm; edited 1 time in total |
Tcash Samba Member
Posted: Wed Mar 25, 2015 6:06 pm Post subject: |
Welcome to TheSamba!
FlatfourFrenchy Samba Member
Joined: March 13, 2013 Posts: 297 Location: Boonville, MO
Posted: Wed Mar 25, 2015 6:34 pm Post subject: |
Mine had the falling white powder syndrome also. I pulled mine down carefully marking where the seams were with a sharpie on the side rails. I sanded mine down just to the wood under whitewash finish and put a coat or two of urethane on them making them have a nice warm color. I also glued and clamped any delaminated egdes while they were down.
_________________ 1971 Tin Top Westy Campmobile 70 |
Posted: Thu Mar 26, 2015 7:21 am Post subject: Headliner pics |
I can't figure it how to remove the rivets from the light and how I'd put em back in if I move this will it mess up light light works thanks btw
Tcash Samba Member
Posted: Thu Mar 26, 2015 7:45 am Post subject: |
I think the light pops out the rivets are holding the bracket.
Gently try and pry the light out. If it will not come out. Drop the panel and unplug it.
Good Luck
Tcash |
Posted: Thu Mar 26, 2015 6:23 pm Post subject: |
Gently push on one of the short side of the light, you might have to wigged it a bit, try to slip a credit card under the rim/edge of the light, pull down gently, if it does not work try wiggling it a bit to the other side(long ways) try pulling down gently with the credit card… you may have to play with it until you get the feel for it, if in the end if you break it, you can always get a replacement… we all have had to learn the hard way sometimes; you break things while learning sometimes ;0) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Supertramp Samba Member
Joined: September 11, 2013 Posts: 93 Location: England
Posted: Fri Mar 27, 2015 12:35 am Post subject: |
Looks exactly like my headliner, which I removed from a 71 Westfalia a few days ago. I'm replacing the ply however and wrapping it in vinyl.
If you push the edges of the headliner, starting at one side, then move to the other, I found it just eventually 'popped' out.
As for the light I disconnected it from above and took it out with the headliner.
Cutting the ply and reinstalling this weekend. |
Posted: Fri Mar 27, 2015 5:34 pm Post subject: Headliner light help |
Here's how the lights connected pulled down wood a tad to see what was under and how to disconnect it there's a whole bunch of insulation And I can't figure out how to unplug light the wires look like there soldered soldered on hmmm
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Fri Mar 27, 2015 5:52 pm Post subject: |
just pull them straight off.
use caution as the red wire has 12V at all times and if it touches the body bad things can happen.
unhook your battery to negate this problem. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Fri Mar 27, 2015 5:54 pm Post subject: |
And then I can just plug em back in? sweet ,thanks everyone! |
busdaddy Samba Member
Posted: Fri Mar 27, 2015 5:59 pm Post subject: |
Careful pulling them off, they tend to stick on the terminals and the plastic holding that up is brittle, supporting the metal part of it you are pulling it off of with needlenose pliers saves all sorts of trouble later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Fri Mar 27, 2015 6:34 pm Post subject: |
Spray the connectors with some WD-40 and give a little wiggle as you are pulling them off. As busdaddy posted needle nose pliers work well.
Tcash |
drakonis Samba Member
Joined: June 15, 2012 Posts: 251 Location: Granite Falls, WA
Posted: Fri Mar 27, 2015 8:02 pm Post subject: |
You allready have the pic if you cant remember when re installing the wires. taking pics while removing things is a huge plus! _________________ 71 Bay. "ketchikan" |
