MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Mon Mar 30, 2015 11:49 am Post subject: Link Pin Front End Issues |
I am restoring a 1958 Euro Ragtop and am having some issues with the front end. A little background; the car came with a 1960 front beam with 1960 trailing arms. Later I located a 58 beam and used the later trailing arms. I am in the process of installing the rebuilt spindles. On the passenger side I measured 8mm offset and shimmed accordingly, on the drivers side I measure 5mm which is out of spec. I see no damage to the trailing arms.
Is there any way to determine where the problem is? Any help would be awesome!
Thanks
Bruce
blue77bay Samba Member
Joined: February 11, 2006 Posts: 631 Location: Brisvegas Australia
Posted: Tue Mar 31, 2015 1:44 am Post subject: |
if you are sure its an early beam 5 mm is in spec _________________ I like hammers. Lots of hammers. Hammers and me go way back.
A large hammer collection is like an instant problem solver
Mark tucker wrote:,wack off as needed |
Posted: Tue Mar 31, 2015 6:11 am Post subject: Shim problems |
Actually using the later arms that take the dust shields the spec is 5.5mm minimum. I finally did solve the issue by removing the upper torsion bar assembly and turning it end for end. After re-installing the arms everything was in the 6mm to 6.5mm range.
Is there a left and right side for the torsion arms?
Bruce |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Mar 31, 2015 9:20 am Post subject: Re: Shim problems |
MeeferMadness wrote: |
Bruce |
Arms can be swapped side to side.
Sometimes on in install such as yours it's simply a matter of the grub screws not seating properly. I have seen them where you slip the arm off and slip it back on and it's suddenly back in the range of the chart.
I'm not sure exactly when the change came to the trailing arms for the dust cap and O-Rings. My 60 still had flat faced arms. So if your 60 arms are flat faced as well, they should be the same as the 58's I think. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Tue Mar 31, 2015 4:22 pm Post subject: Torsion leaves |
drscope: I believe you hit the nail on the head. By swapping the leaves end for end it slightly changed the geometry enough to bring things into spec. It could just be how the detents are drilled into the bars or how the grub screws set in. My trailing arms have the recess for the dust shields so they use the 8 shim stack instead of 10 shims.
Thanks for the help, I was really stuck on this for a while!
Bruce |
Posted: Tue Mar 31, 2015 7:34 pm Post subject: |
Those differences you found is the reason for the shims. They help square up the link pin carrier to the trailing arms regardless of the offset in the arm faces. _________________ Mother Nature is a Mean Evil Bitch! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
zbug Samba Member
Posted: Sat Jun 06, 2015 2:43 pm Post subject: Re: Torsion leaves |
Bruce |
sorry to but in. but 'Im having the same problem. after reading this I realize I have the arms without the recess for the dust shields. So I believe I need to go with the 10 shim set up. I have an offset of 5.5 on one side and 6mm on the other. The problem I have is, I have the big book thats from 1961 to 1965, and it only shows the 8 shim chart with the dust covers.
does anybody have the chart for the older car? Or do I just shim to fill the gaps.
This is a pic of what I have now when I was trying it with the dust covers. There's a good size gap at the bottom. Thanks
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Jun 07, 2015 5:14 am Post subject: |
_________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
