My project Doom Buggy
Page: Previous  1, 2, 3, ... 12, 13, 14  Next
cdnltded
cdnltded is offline
PostPosted: Sat Apr 18, 2015 11:48 am    Post subject: Reply with quote
EVfun wrote:
The older cast pedals look nicer and would be appropriate for your frame. I know the clutch cable location was moved inside the tunnel at least once. How far in from the edge the tube is located is the only critical dimension. If it is the same as both of your pedal assemblies then the one to use is up to you. I can say from experience that using a roller pedal in the early pedal assembly is a bit uncomfortable on long drives.
thanks for the info i will keep that in consideration
cdnltded
cdnltded is offline
PostPosted: Sun Apr 19, 2015 9:29 pm    Post subject: Reply with quote
so another little update. got the rear portion of the lip cut of and welded back up. as well as the heater tube thing
havent got them ground back down maybe tomorrow. the removal and welding took longer then i thought it would
ammocan
ammocan is offline
PostPosted: Mon Apr 20, 2015 2:05 pm    Post subject: Reply with quote
You have quite the project on your hands. About the same rusty place I started. Looks good so far. I noticed your body mold is almost identical to mine. The only 2 places I see a difference is the dash and the spots molded for the headlights. If you happen to know or find out who made your body let me know. In the meantime keep up the good work.
skill comes by the constant repetition of familiar feats, not by one over bold attempt at a feat for which the doer is yet poorly prepared
cdnltded
cdnltded is offline
PostPosted: Mon Apr 20, 2015 6:28 pm    Post subject: Reply with quote
thanks
like i said your build has been my insperation
more work tonight i hope
cdnltded
cdnltded is offline
PostPosted: Mon Apr 20, 2015 6:32 pm    Post subject: Reply with quote
so my pedal dilema is solved. i took the newer base assembly with the factory roller assembly and put the older clutch and brake pedal on it. turns out all the shafts are the same size so i solved all my issues except the clutch and brake pedal return stop
cdnltded
cdnltded is offline
PostPosted: Mon Apr 20, 2015 9:43 pm    Post subject: Reply with quote
so i got one side floor pan cut out and just sitting in place. other side tomorrow night i hope
cdnltded
cdnltded is offline
PostPosted: Tue Apr 21, 2015 9:44 pm    Post subject: Reply with quote
got the right side floor cut and also go both of the tacked into place so i can move onto other things. and alos got my pedals figured out too.just need to figure out where to put the pedal stop bolt hole
cdnltded
cdnltded is offline
PostPosted: Thu Apr 23, 2015 6:33 am    Post subject: Reply with quote
so here is another question for all that have lots of experience.
can i use a older 1200 that is complete but seized as a engine to do all my fabbing around.
is there much difference in size to a 1500
cdnltded
cdnltded is offline
PostPosted: Fri Apr 24, 2015 6:30 am    Post subject: Reply with quote
does anyone know??
Crying or Very sad
heywebonya
heywebonya is offline
PostPosted: Fri Apr 24, 2015 6:40 am    Post subject: Reply with quote
For fabbing, there is no engine size issues to be concerned about. The layout of exhaust COULD be an issue.
Nice job so far.
If I knew what I was doing; I wouldn't be building a buggy!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Fri Apr 24, 2015 10:47 am    Post subject: Reply with quote
The only issue of difference is the exhaust. A 1200 is more narrow than a 1500/1600 at the exhaust ports by about 1 inch overall. So, if you have your final exhaust on hand, loosen the heads and spread them apart enough to get the exhaust on. You will need to loosen the intake and tins to do this.
It also will not have the dog house shroud if that makes any difference.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
cdnltded
cdnltded is offline
PostPosted: Fri Apr 24, 2015 11:53 am    Post subject: Reply with quote
thanks guys
cdnltded
cdnltded is offline
PostPosted: Tue Apr 28, 2015 9:28 pm    Post subject: Reply with quote
got the "hat" weld into place, just need to clean up the welds. thay look way worse then they are. next will be the rear portion then the mount for the steering column
cdnltded
cdnltded is offline
PostPosted: Thu Apr 30, 2015 9:46 pm    Post subject: Reply with quote
got some work done at the batwing tonight, just welded in some vertical pieces, that later i will attach some wider more supportive metal
this metal work takes longer then one would expect. a couple of hours a night just doesnt seem to be enough
cdnltded
cdnltded is offline
PostPosted: Wed May 06, 2015 9:43 pm    Post subject: Reply with quote
started to do the fab work for my gm/buick steering column
this is from the underside trying to get things into place
just got the column held in place with a strap need to make the uprights for it yet
cdnltded
cdnltded is offline
PostPosted: Thu May 07, 2015 9:41 pm    Post subject: Reply with quote
so i got the stand alone steering column mount all tacked up and in place tonight. at this rate i will be doing final welding for a week straight.
here is some pictures
cdnltded
cdnltded is offline
PostPosted: Sat Jan 23, 2016 9:26 pm    Post subject: Re: My project Doom Buggy Reply with quote
well almost a year later i am working on this again
got my gas tank modified for the buggy. going to us a remote fill
pictured here
also got mt driver seat mounts figured out. i am using rzr seats with only adjust on the left from a mazada rx7
cdnltded
cdnltded is offline
PostPosted: Fri Jan 29, 2016 8:34 pm    Post subject: Re: My project Doom Buggy Reply with quote
seat all the way back
seat all the way forward
gas filler hood off
and under the hood
i think i am going to still add a bracket to the steering column support
cdnltded
cdnltded is offline
PostPosted: Thu Feb 04, 2016 10:24 pm    Post subject: Re: My project Doom Buggy Reply with quote
got my passenger seat mounted. but i think i put it too far forward
cdnltded
cdnltded is offline
PostPosted: Sat Feb 13, 2016 2:54 pm    Post subject: Re: My project Doom Buggy Reply with quote
go the support for the filler neck welded in place as well as got the steering column support all welded to the final
Page 2 of 14
