My project Doom Buggy
Page: Previous  1, 2, 3 ... 9, 10, 11, 12, 13, 14  Next
cdnltded
cdnltded is offline
PostPosted: Thu Apr 19, 2018 6:21 am    Post subject: Re: My project Doom Buggy Reply with quote
oprn wrote:
I like it!
It’s almost like the new Plum Crazy Purple.
Hopefully it looks ok in the sun. Like not being able to see the lines as this stuff cane from a cattle can.
Firebuggy
Firebuggy is offline
PostPosted: Thu Apr 19, 2018 12:22 pm    Post subject: Re: My project Doom Buggy Reply with quote
I like it too. Gonna look great in the sun! Cool
W1K1
W1K1 is offline
PostPosted: Thu Apr 19, 2018 1:22 pm    Post subject: Re: My project Doom Buggy Reply with quote
if you really want flake, this is what I do.
base color
flake of whatever color and a flake cannon ( easy to build ) and a can of clear.
i used a princess auto cheap disposable gun on my last project with a quart of inexpensive sherwin williams 2 part clear from the local auto supply, way cheaper than buying rattle cans
spray clear wet a couple square feet, flake cannon the clear, move to the next dry spot. then once you're done you'll have to lay a couple coats of clear to bury the flake.
some video after laying the flake on the sidecar
https://www.instagram.com/p/BThndVyA8mI/?taken-by=mark_witwicki
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
cdnltded
cdnltded is offline
PostPosted: Thu Apr 19, 2018 3:34 pm    Post subject: Re: My project Doom Buggy Reply with quote
base color
great idea
but i am using a product caled protectdip, it like plastidip but cheaper, if i dont like i will peel off and paint with real auto paint
oprn
oprn is offline
PostPosted: Thu Apr 19, 2018 8:37 pm    Post subject: Re: My project Doom Buggy Reply with quote
Got my engine in but there is lots of wiring to sort out and an exhaust to build. The race is on to see who its the pavement first!
cdnltded
cdnltded is offline
PostPosted: Sat Apr 21, 2018 12:03 am    Post subject: Re: My project Doom Buggy Reply with quote
Paint is done.
I don’t think it’s gonna win any beauty contests. But I am ok with the results.
I really like the color and how the flake turned out
oprn
oprn is offline
PostPosted: Sat Apr 21, 2018 4:46 pm    Post subject: Re: My project Doom Buggy Reply with quote
I wonder if that clear coat will buff up a bit once it has cured well? It looks a wee bit flat ( well more like semi gloss), mind you the flat look is kind of "in" just now.
And once it's all dressed up it will look different too! Smile
cdnltded
cdnltded is offline
PostPosted: Sat Apr 21, 2018 6:36 pm    Post subject: Re: My project Doom Buggy Reply with quote
No it won’t buff up. It’s a rubber type based removal paint. It’s shinnier now then it was. Can’t wait to get it back together and out in the natural light
oprn
oprn is offline
PostPosted: Sat Apr 21, 2018 9:08 pm    Post subject: Re: My project Doom Buggy Reply with quote
It will be just fine!
cdnltded
cdnltded is offline
PostPosted: Mon Apr 23, 2018 4:50 pm    Post subject: Re: My project Doom Buggy Reply with quote
Ok i need some of the knowledgeable guys help
its almost time to mate the body back to the chassis for the last time. i have heard many talk about you need to seal the body to the chassis.
Is that true? or does it really matter?
and if true what is the best recommendation?
slalombuggy
slalombuggy is offline
PostPosted: Mon Apr 23, 2018 5:22 pm    Post subject: Re: My project Doom Buggy Reply with quote
Buy a roll of stock VW body gasket rubber. The stuff they used Beetles and Ghias. CIP1 carries it. Glue it to the pan with some Permatex Right Stuff urethane sealant, tape it down to hold it in place and let it set up, then bolt the body down. Don't glue the body down just put it on the bare rubber.
brad
cdnltded
cdnltded is offline
PostPosted: Tue Apr 24, 2018 11:47 am    Post subject: Re: My project Doom Buggy Reply with quote
One rear rim done. I like how it has turned out. Now I wait for the parts to show up. Then rims and tires will be out on as well as the body for good
cdnltded
cdnltded is offline
PostPosted: Tue May 01, 2018 9:04 am    Post subject: Re: My project Doom Buggy Reply with quote
have to stay with a narrower tire in the rear, not much clearance.
got the new snubbers installed too
front tire mounted
and the "rollbar" is all ready too
Hot Air
Hot Air is offline
PostPosted: Tue May 01, 2018 11:33 am    Post subject: Re: My project Doom Buggy Reply with quote
That is way to close on the rear rim. The tire is going to flex when taking corners and is going to rubbbbbbbbb. what is the offset on the rim ?
73' Bug
85' Porsche 911 Carrera 3.2
cdnltded
cdnltded is offline
PostPosted: Tue May 01, 2018 5:24 pm    Post subject: Re: My project Doom Buggy Reply with quote
Not sure. Custom made I bought from a guy. I have some tires mounted on the rims. Gonna try them in a day or 2. Might have to get some spacers and longer nuts. 🤞🏻🤞🏻
57BLITZ
57BLITZ is offline
PostPosted: Wed May 02, 2018 11:27 am    Post subject: Re: My project Doom Buggy Reply with quote
Swap the axles!
1967 axles/tubes will give ya about an inch and a half more room right where ya need it!
'68 axles/tubes can also be used if you get some spacers for the axle nuts.
Do it now before ya get everything assembled!
Jesucristo es mi Señor y Salvador!
cdnltded
cdnltded is offline
PostPosted: Wed May 02, 2018 11:50 am    Post subject: Re: My project Doom Buggy Reply with quote
well i tried them, with the 275/60R15 on the wheels.
NO GO
so now i am gonna try some 255 and maybe some 245 if i can find a set of used
57BLITZ wrote:
Swap the axles!
if i changed the axle and tubes that requires removing them from the tranny correct. and 67 still has the wide 5 pattern correct
57BLITZ
57BLITZ is offline
PostPosted: Wed May 02, 2018 12:37 pm    Post subject: Re: My project Doom Buggy Reply with quote
cdnltded wrote:
. . . if i changed the axle and tubes that requires removing them from the tranny correct. and 67 still has the wide 5 pattern correct
YES and YES . . .
As I mentioned, 1968 axle/tubes can also be used with your "wide-five" drums if you buy a pair of these . . . http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D22%2D5281%2D7
Remove the transaxle and it will take a couple hours to swap the axles . . . MUCH, much better than super long studs with super thick wheel spacers!
cdnltded
cdnltded is offline
PostPosted: Thu May 03, 2018 1:46 pm    Post subject: Re: My project Doom Buggy Reply with quote
57BLITZ wrote:
YES and YES . . .
so if i can find a set of 68 axles.
can changing the axles be done without removing the tranny? i know it would be easier out
second this spacer you mention it just goes between the nut and the drum allowing me to use all my existing backing plate and brake setup?
cdnltded
cdnltded is offline
PostPosted: Wed May 09, 2018 11:58 pm    Post subject: Re: My project Doom Buggy Reply with quote
Started reassembling tonight
The rear rims are just for moving the buggy around
Page 10 of 14
