michla Samba Member
Joined: January 17, 2003 Posts: 331 Location: Wasilla, AK (yes, there's drag racing up here !)
Posted: Thu Apr 02, 2015 10:35 am Post subject: reverse gear key |
Building up a Type 1 IRS drag trans.
Early IRS trans had a keyed reverse gear and later (70's) has a splined reverse gear. I'm now using an earlier IRS gusseted case this season that will use the keyed reverse gear. I could use the later reverse gear with fabricated case adapter to contain the longer tube bearing reverse shaft spins in, but larger FTC gears don't permit enough clearance for a "spacer" or shims so forget that.
Obviously, no abuse of reverse gear in drag racing (unless shift lockout fails!) but is there any reason to avoid the keyed reverse gear other that less resistant to shear-failures than the splined gear? Opinions? Experience with failure?
Thanks |
mark tucker Samba Member
Posted: Thu Apr 02, 2015 3:16 pm Post subject: |
so... you dont do reverse burnouts to get the front tires stickey too sorry couldent rezist.kinda hard to see how vw came up with this reverse system and stayed with it. |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Thu Apr 02, 2015 3:59 pm Post subject: |
Yes, it will OK. I used this style of case for racing for years. The newer single side case is much stronger. I changed over to the 1976 and newer ones a few years ago and am happy with them. _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
michla Samba Member
Posted: Thu Apr 02, 2015 7:18 pm Post subject: |
bugguy076 wrote: |
Yes, it will OK. I used this style of case for racing for years. The newer single side case is much stronger. I changed over to the 1976 and newer ones a few years ago and am happy with them. |
Yes, I have several of the single side case too, thanks for the feedback. |
