cjonesak Samba Member
Posted: Sat Apr 04, 2015 10:57 am Post subject: What do I do now? Broken Diesel oil filler tube. |
On my inline 4 conversion I broke my diesel oil filler neck. I know stupid thing to do since they are NLA. I have already read on here what others have done when they've done this. Things like having one custom built which is an option. Or getting a block off plate which is what I already did. But what I am really curious about is will any other version from any other Vanagon work? If not why not. My broken one mounts up to an elbow bracket coming right off the oil pan which is what some of the ones I looked at did. Is the air cooled/water cooled/gas version shorter? Longer? Is it the dipstick in the cap? What is the difference? I don't know I'm just not getting this. Can someone enlighten me please. |
dave Friday Samba Member
Joined: July 13, 2013 Posts: 60 Location: Southern Spain
Posted: Sat Apr 04, 2015 11:08 am Post subject: |
Have a look on www.brickwerks.co.uk _________________ 1992 t3 syncro jx 1.6td leisure drive camper van
Now with " sb" engine |
?Waldo? Samba Member
Posted: Sat Apr 04, 2015 12:29 pm Post subject: |
NONE of the non-diesel oil filler tubes will work with the diesel pan, because they don't fit... With the right skill set and tools you can MAKE one fit, though.
I made a custom one for a conversion I did that had A/C. I don't recall if I started with one from a WBX or an air-cooled, but I chopped it, changed the angle and welded on a flange with the correct bolt pattern. It was certainly a little tricky but it works it doesn't leak, nothing ever rubs and oil is easily added without emptying the hatch area.
None of the filler tubes other than the '82 (only) diesel filler tube use the dipstick in the tube. The '82 mounting system/trans places the engine 1.5" rearward relative the body of the vehicle. Because of that, none of the other diesel filler tubes have the correct angle to work with the '82 diesel mounting system. With adapting any other filler tube, you would need to relocate the dipstick to use a curved tube and enter the block in the 'normal' diesel dipstick hole. |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Sat Apr 04, 2015 8:51 pm Post subject: Block off plate it is... |
Cool thanks for making that make sense Andrew Libby. You earned an A in diesel oil filler necks. At this point in time welding is above my pay grade until something more necessary to my vans survival breaks. Then I"ll buy a welder. In the mean time I'll either slow drip or I'll run the block off plate until my brother who lives in the homeland scores me the right one. I know he'll ship to the U.S.
Cheers |
Posted: Sat Apr 04, 2015 10:09 pm Post subject: |
FWIW, that's a later style filler tube which is designed for the '83+ vans. It may physically fit, but the angle for filling at the license plate is wrong if installed on an '82. Dipstick redesign would also be required as it can't accept the dipstick in the tube. |
