metropoj Samba Member
Posted: Mon Apr 06, 2015 7:49 am Post subject: I would say R&P is shot, yeah? |
My 2WD 4sp tranny has been making a whirring noise since I bought it.
Not loud when you are coasting, no noise at all when you put in the clutch. Tied to vehicle 'speed' and not to gearing.
Looks pretty worn to me 486,000 kms on this one.
Opinions if this is just because it is well used and worn or maybe was low on oil or ?
Vanagon was also towed behind a motorhome for about 50,000 kms of its life but I don't think that should have had any difference than just regular driving. It's not like an auto tranny....
So, it is a loss for a core but I will save it because the PO did the 3/4 slider in it not that long before i got the van and although my used replacement tranny was all rebuilt and stuff, you just never know.
Stuff it in the corner of the garage ....
Now to wade through the numerous gear oil threads to see what to fill the next one up with, lol. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Apr 06, 2015 8:17 am Post subject: |
What am I looking for? I don't see any chunks missing. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Apr 06, 2015 8:30 am Post subject: |
I thought maybe a trained eye on the teeth themselves may reveal more than my completely untrained eye.
I didn't see chunks out of anything but it just looked generally worn. |
Zeitgeist 13 Samba Member
Posted: Mon Apr 06, 2015 8:34 am Post subject: |
I think you'll want to closely inspect the pinion gear _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Apr 06, 2015 8:50 am Post subject: |
I would measure the backlash with a dial indicator. Did it make the same noise in all the gears? _________________ ☮️ |
Abscate Samba Member
Posted: Mon Apr 06, 2015 8:57 am Post subject: |
Quote: |
no noise at all when you put in the clutch |
Isn't this pointing away from the R&P on this car?
The R&P turn at wheel speed, independent of clutch.
Ill edit that. If the noise comes and goes on float (matching engine to wheel speed) then I agree its R&P
It will disappear on clutch disengaged since you are then on coast _________________ .ssS!
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Apr 06, 2015 9:02 am Post subject: |
You're showing us the coast side of many teeth on the ring gear (which likely WOULD have a bit more wear than normal due to many miles of towing). Wear on this side might make noise during coasting.
But you say it's quiet while coasting, which suggests that you hear your noise when on throttle .. so show us a close up of the DRIVE side PINION teeth.
The whirring noise may not be your R&P at all .. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Merian Samba Member
Posted: Mon Apr 06, 2015 11:06 am Post subject: |
I also see no obvious problems - a good, well-focused pic with a macro lens could help. Or take it to a trusted person for inspection.
Or measure... Like the man said: "when you measure... you know... something." (Wm. Thompson, Lord kelvin) |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Mon Apr 06, 2015 3:16 pm Post subject: |
I had whirring noise from 30mph to 75mph.
Put in neutral at 60mph, noise still there.
therefore, not engine related.
Not much difference turning right or left.
Turned out to be drivers side rear wheel bearing.
Easy fix. now all it quiet. |
Posted: Tue Apr 07, 2015 4:31 am Post subject: |
Interesting stuff I am reading here.
This was my thinking:
The noise happened under 'load' when clutch is out, like during acceleration but if I let off the throttle I don't notice it. Same with clutch in, no noticeable noise.
Clutch in and a rev of the motor doesn't change anything.
Was tied to wheel revolutions and didn't change with any particular gear selected.
I had ruled out in my mind that if it was rear wheel bearings then the noise would be constant all the time but I may have missed the boat on this. Everything is well worn in on this van ( maybe worn-out is better description )
I'll have to look more into this as suggested as I'm curious now. |
Posted: Tue Apr 07, 2015 4:33 am Post subject: |
pdm777 wrote: |
Interesting. I also have all new non China bearings to do the rear end while I'm putting in the new engine and tranny. I just didn't hear the whirr when the tranny wasn't under load. |
Posted: Tue Apr 07, 2015 4:47 am Post subject: |
I don't think Ive ever heard a rear wheel bearing change noise under float/load.
You could jack car up and drive wheel and listen to noise outside, isolating bearing and R&P by location.
The good news is R&P can be noisy for a long time before they impede utility. _________________ .ssS! |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Tue Apr 07, 2015 6:13 am Post subject: |
Abscate wrote: |
A overused wheel bearing can change noice under load/fload.
I was there. |
RicoS Samba Member
Posted: Tue Apr 07, 2015 7:09 am Post subject: |
I'd say, check the pinion bearing. The bummer is that you have to go deep to do it.
I once had a queefed out pinion bearing and more than one expert said, "DEFINITELY the R&P" from the unnatural sound the X-axle made under load.
Even after I pulled the trannie and checked the backlash it seemed OK. But, when I finally got to the naked pinion, it could be shifted axially at least 1/8" (3mm for you metricphiles) within its bearing and all questions were answered.
Richie |
Posted: Tue Apr 07, 2015 8:10 am Post subject: |
Waldi wrote: |
Abscate wrote: |
I was there. |
Waldi - do you mean on accelerate and coast?
A wheel bearing will definitely go noisy/quiet on side-to-side load, but I haven't heard one change on accelerate/coast
Just educating myself, not trying to be a sch****kopf (literal translation) _________________ .ssS! |
Posted: Tue Apr 07, 2015 8:54 am Post subject: |
I'm with Rico. My Syncro tranny made that same noise pattern. R&P was fine but it was the pinion bearing race moving, and the main bearing race moving. The R&P is worth having measured so you know. No way to use your eyes to judge unless you are a pro yourself. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
gears Samba Member
Posted: Tue Apr 07, 2015 11:10 am Post subject: |
Abscate wrote: |
.. impede utility. |
I like that term, Abscate. Thanks ..
Although the OP has determined his issue, continued discussion of the R&P is obviously worthwhile.
It's virtually impossible for a mechanic to know if R&P noise is because the bearing is failing, the bore has wallowed and/or the bearing nut has loosened. The noise generated is still an R&P that isn't in proper mesh at least part of the time.
And it's often difficult to sort out by just removing the bell housing and measuring, as even OK R&Ps are typically running with backlash larger than specified by the factory after 150K. Sometimes, full disassembly is required before the cause reveals itself.
Anyhow .. glad this story had a happy ending for the OP. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Tue Apr 07, 2015 11:50 am Post subject: |
gears wrote: |
Anyhow .. glad this story had a happy ending for the OP. |
I don't think it has yet? Perhaps you read the post by pdm777 and thought it was the OP? _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
gears Samba Member
Posted: Tue Apr 07, 2015 12:57 pm Post subject: |
Quote: |
Perhaps you read the post by pdm777 and thought it was the OP? |
Doh !
Better close up photos might help us .. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Tue Apr 07, 2015 6:23 pm Post subject: |
"It's virtually impossible for a mechanic to know if R&P noise is because the bearing is failing, the bore has wallowed and/or the bearing nut has loosened. The noise generated is still an R&P that isn't in proper mesh at least part of the time."
Really, really good point I did not realize. Thanks for that one! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
