FullFender Samba Member
Posted: Mon Apr 06, 2015 5:40 pm Post subject: Ball Joint boots |
Does anyone know of a place that sells replacement ball joint boots for a 67 bug?
-Thanks |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Apr 07, 2015 7:04 am Post subject: |
Thank you, it is much appreciated. |
planenut Samba Member
Posted: Tue Apr 07, 2015 7:04 pm Post subject: ball joint boots |
While the subject is up, does anyone know where to buy the tool to put the boot rings on with. Not sure about the ball joints, but also the tie rods. I wound up using safety wire, but would like to have the tool to put the rings on with. |
ThorpS18 Samba Member
Joined: November 19, 2009 Posts: 160 Location: So. California
Posted: Tue Apr 07, 2015 7:22 pm Post subject: Re: ball joint boots |
planenut wrote: |
Maybe this is the tool you are looking for:
http://www.amazon.com/Lisle-30800-Boot-Clamp-Plier...clamp+tool _________________ Success is never final, failure is rarely fatal, and courage is always necessary. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Tue Apr 07, 2015 9:09 pm Post subject: Re: ball joint boots |
ThorpS18 wrote: |
planenut wrote: |
http://www.amazon.com/Lisle-30800-Boot-Clamp-Plier...clamp+tool |
That tool is for axle boots and is not the same at all.
I just take the securing ring and work it around the boot, I carefully open it a bit ( like a slinky ) and go around it slowly working it on the boot and into the groove that the boot is in to secure the boots. A LOT harder to describe than to actually do, just go slow and be careful not to poke any holes in the boot if you have to use a screw driver to assist you. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Wed Apr 08, 2015 5:43 am Post subject: ball joint boot |
I'll have to go look, but I think I saw it in the Bentley manual. It's a round, tapered cone type of set up, and one end does the big rings, and one end does the small ones. The tool fits over the boot and you slide the ring. It expands it as it moves, then it snaps over the end, onto the boot. Neat tool, but haven't seen anyone sell it. |
Posted: Wed Apr 08, 2015 6:29 am Post subject: Ball Joint Boots |
OK, went out to the shop and in the '66 Bentley manual, Front Axle section, Pg 21, Fig 38, it shows the conical sleeve for the ball joints. It's labeled as 'VW 780'. There must be a different size for the tie rods. Great looking tool, just haven't found one. I could never get the rings on the tie rods, so I used safety wire. |
