Powdercoat or rollon truck bed liner on custom hitch/bumper?
vanis13
vanis13 is offline
PostPosted: Tue Apr 07, 2015 2:32 pm    Post subject: Powdercoat or rollon truck bed liner on custom hitch/bumper? Reply with quote
Powdercoat or roll on truck bed liner on custom hitch/bumper?
So the quote is $150 for the hitch and bumper to powder coat. Includes all prep which is nice buts its probably more than the materials I have into the assembly.
Seems like truck bed liner is used successfully for the lower part of the van by many so why not the hitch?
Thoughts?
Thanks,
Andrew
I can send you the capacitor to Fix/prevent Vanagon Syndrome and/or smooth out idle - See here - http://www.thesamba.com/vw/forum/viewtopic.php?p=5445671#5445671
djkeev Premium Member
djkeev is offline
PostPosted: Tue Apr 07, 2015 2:49 pm    Post subject: Reply with quote
Powder coat has moved itself into the coating of choice for the 21st Century.
Be this good or be this bad? It is totally your choice to decide.
I've yet to embrace the process preferring to stick with quality paints that have been PROPERLY applied on a properly prepared surface.
In my book, a quality Single Stage 2 Part Auto Paint is just as good if not better than powder coat.
Powder coat tends to be hard and chips fairly easily, once chipped..... Moisture gets in and lifts the powder coat off in sheets.
With paint, just touch it up, yearly maintenance.
But this is just me voicing MY opinion.
Nothing at all wrong with a tough bed liner product if applied correctly. Most have texture which will collect dirt.
Only You know what to do.
The key to any product is to follow directions and properly prepare the surface.
Dave
Ghia
Vanagon
Beetle
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Tue Apr 07, 2015 3:49 pm    Post subject: Reply with quote
Hi,
I'm at the same situation, aluminum bumper build pretty well ready for paint. I'm leaning to bedliner for a couple of reasons:
Might provide a bit of a non slip surface on the top of the bumper ( stepping on the bumper)
Might be easier to touch up the inevitable scrapes and scratches
Don't need to surface finish bumper as much.
Hope you'll let us know your choice and show some pics,
Cheers
Alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
vanis13
vanis13 is offline
PostPosted: Tue Apr 07, 2015 3:59 pm    Post subject: Reply with quote
will do. you post pics/decision too. If I had alum, i might not even paint it.
BTW - custom bumper/hitch for my situation may not be completely accurate.
I used the word "custom" to indicate it was not OEM.
I have a gowesty steel bumper and fabricating the hitch portion (which is avail from them). My work may require that the bumper also gets new paint. FWIW, the GW paint has some texture so standing on it works well.
newfisher
newfisher is offline
PostPosted: Tue Apr 07, 2015 4:08 pm    Post subject: Reply with quote
Here at our body shop we paint, spray truck bedliner using LineX product and also send out raw parts for powdercoat. In my experience, bedliner on a bumper isnt a good idea unless you never hit it against anything. The product can separate from the metal and create a pocket for moisture and bubble. If powdercoated or painted, it will most likely dent or worst case dent and chip. At this point you can touch it up vs. having the area repaired at the bedliner dealer. I would also pass on diy roll on stuff for outdoor bumper abuse. If you like the GoWesty powder coat, contact them about refinishing what you have?
highsierra
highsierra is offline
PostPosted: Tue Apr 07, 2015 6:12 pm    Post subject: Reply with quote
My experience with powder coating (bicycle frames and car parts) is that it adds dimension which could cause problems for your mounting hardware as well as inside the hitch receiver. Also, I find that powder coating can chip off over time in high use/stress areas. Bedliner also would add dimension but it'd be more controllable, more durable over time and easy to touch up. YMMV
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Apr 07, 2015 6:34 pm    Post subject: Reply with quote
I love the flexibility of the brush on bedliner I've been using on an off brand project lately. It's sets up tough as nails, and really hides imperfections exceptionally well. Powder coating seems perfect for smooth objects that won't see repeated contact or road debris, but the bedliner just takes a lickin' and keeps on tickin' from my experience.
Casey--
Volkswagens powered by Volkswagen
Oly Bulli
ragnarhairybreeks
PostPosted: Tue Apr 07, 2015 7:23 pm    Post subject: Reply with quote
Im leaning towards the brush on bedliner. as the bumper is made of aluminum I don't have the rust concerns.
A lot of the stuff we make at work (aluminum) is powder coated and yes we do have to make allowances for the few thou of paint build up. Those parts get the royal Powdercoating experience... Washing, blasting, multiple coats of powder etc. but they go out to sea and I nver see them again Smile
Zeitgeist's comment about the thick brush on hiding imperfections is music to my ears.
Alistair
Phishman068
Phishman068 is offline
PostPosted: Tue Apr 07, 2015 8:16 pm    Post subject: Reply with quote
Upol Raptor spray on bedliner.
You can do it yourself, it touches up nicely, doesn't fade, and is without a doubt a level above the normal "Roll On" crap.
I've put it on a few bumpers, it works.
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
vanis13
vanis13 is offline
PostPosted: Tue Apr 07, 2015 8:27 pm    Post subject: Reply with quote
U-pol raptor seems to be about $120/gal (may include spray gun) like all of these, may be sprayed, rolled or brushed.
http://www.u-pol.co.uk/product-cat/250/raptor.htm
if roll-on which would you chose and why?
Epoxy/rubber @ $80/gal
http://www.rustoleum.com/product-catalog/consumer-...-liner-kit
or Polymer @ $40/gal
http://www.rustoleum.com/product-catalog/consumer-brands/auto/coatings/truck-bed-coating
Zeitgeist 13
PostPosted: Tue Apr 07, 2015 9:04 pm    Post subject: Reply with quote
I fully expect to be drawn and quartered for this, but my current project has absolutely no budget for name brands, so I've been required to search far and wide for out of the box solutions. I opted for this stuff called Iron Armor, which is found at Harbor Freight (gasp, grab the torches!). Turns out that it's made in the US, and I'm currently on my second 1 gal can of it over the last year and a half @ ~$45/can. Without a doubt there are better solutions for more money on the market, but I simply can't complain about the performance for the price.
Casey--
Oly Bulli
insyncro
Banned
insyncro is offline
PostPosted: Tue Apr 07, 2015 9:44 pm    Post subject: Reply with quote
Monstaliner
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue Apr 07, 2015 10:12 pm    Post subject: Reply with quote
Imron
T.K.
WLD*WSTY
WLD*WSTY is offline
PostPosted: Tue Apr 07, 2015 11:35 pm    Post subject: Reply with quote
Monstaliner
'82 SyncroWesty, the first ever conversion.'06 Subaru 2.5L
Terry Kay
Banned
PostPosted: Wed Apr 08, 2015 6:31 am    Post subject: Reply with quote
U-Pol Raptor
T.K.
vanis13
vanis13 is offline
PostPosted: Wed Apr 08, 2015 6:51 am    Post subject: Reply with quote
Terry Kay wrote:
Imron
Terry Kay wrote:
U-Pol Raptor
Make up your mind Wink
options or does entry #2 supersede entry #1 and if so why?
dkoesyncro
dkoesyncro is offline
PostPosted: Wed Apr 08, 2015 6:52 am    Post subject: Reply with quote
monstaliner
Terry Kay
Banned
PostPosted: Wed Apr 08, 2015 6:58 am    Post subject: Reply with quote
There is more than one answer.
The Industrial Imron is tough , and very repairable.
The U-Pol Raptor is really tough, and kinda repairable, but not as easy to overcoat.
I could toss in Delthane, but then I'd be confusing you guys.
Used them both, repaired them both.
6 of one, half a dozen of another--name your poison & get it done.
T.K.
MarkWard
MarkWard is offline
PostPosted: Wed Apr 08, 2015 8:04 am    Post subject: Reply with quote
When I fabricated my custom hitch, I had originally planned to just paint it with a rattle can. It came out so nice, I decided to treat it to a powder coat job instead.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
Terry Kay
Banned
PostPosted: Wed Apr 08, 2015 8:24 am    Post subject: Reply with quote
Nothing wrong with powder coating when it's first applied.
However, if it starts chipping , and due to the fact that there is zero primer under it, it will rust under the top coat beyond the chips-- the rust will travel under the surface real easy.
Last winter I had the displeasure of grinding the entire hood, fender's , cab, & frame of a Terex 30 yard off road dump truck--and if you have no idea what a Terex off road site dump truck is--well it's as big as most folks home.
It was powdercoated from the factory, started chipping & rusting under the top coat--and was hell to remove to get a coat of zinc chromate on it, and refinish in Imron.
Look at the fenders, the top of the hood, cowl you can't see , nor the top of the cab---the garbage powercoat was rusting off the same way as the fenders.--
Phooey.
Urethane paint is the way to go, is very rock mark proof--oops I missed the receiver, forgiving, and easily repairable.
You guys can use what you want, but being down the crap powder coat refinishing mode more than once--I'd side step this thought.
It is truely garbage.
T.K.
