LEE 64 Samba Member
Posted: Mon Apr 13, 2015 7:39 am Post subject: 1971 clutch wont go into neutral ? or shift easy |
Hi I can't get my my bus to shift clutch cable felt loose from front of bus how do tell how loose or tight it should be ? how do I adjust clutch cable ?
Thanks |
thach Samba Member
Joined: March 13, 2008 Posts: 143 Location: santa barbara
Posted: Mon Apr 13, 2015 4:29 pm Post subject: |
theres a wing nut on top of the transmission you can tighten or loosen to adjust it |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Apr 13, 2015 4:55 pm Post subject: |
Has this happened suddenly?, or gradually crept up on you? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Mon Apr 13, 2015 5:12 pm Post subject: Clutch Free Play |
To link to this post
Code: |
[url=http://www.thesamba.com/vw/forum/viewtopic.php?p=7633309#7633309]Clutch Free Play[/url] |
Clutch Free Play
Disclaimer, this is if your, disk & pressure plate, throw out bearing, operating shaft & lever, clutch cable, Bowden tube, clutch cable lever, clutch pedal lever, clutch pedal lever support and bushings, are good.
Note: we loosen the clutch adjusting wing nut Not tighten it as the clutch disc wears out.
Good Luck
Tcash
LEE 64 Samba Member
Posted: Mon Apr 13, 2015 5:42 pm Post subject: . |
the clutch has about 3 inches of play in the pedal. I haven't had it long enough bus daddy or driven it enough to know if it happened all the sudden all I know is I was driving it up a steep wet grassy hill it was working then all the sudden I couldn't shift any more I couldn't reach the cable from the back because the bus is kinda stuck in a low place but I did grab the cable from the front and it was very loose |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Apr 13, 2015 5:47 pm Post subject: |
If you will be replacing the clutch cable, be aware that there have been many threads about new cables being the wrong length. Lots of clutch cable info available using Search. It's always a good Idea to have a spare onboard. They break in the winter and are no fun to change on the side of the road lying in the snow .
Aloha
tp |
Posted: Mon Apr 13, 2015 6:24 pm Post subject: |
If it used to sort of work and now doesn't at all it's very likely the cable has snapped, you can try tightening the wing nut a little (make sure the cable dosen't turn too, small vise grips on the cable end of the solid part usually help), if that doesn't make a difference it's new cable time.
As previously mentioned some new cables are the wrong length, also look at the lever on the bottom end of the pedal to confirm it's installed facing the correct way.
Sorry to hear it's stuck in a mud pit, better find a tow rope first, don't hook to a bumper. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
LEE 64 Samba Member
Posted: Mon Apr 13, 2015 6:31 pm Post subject: . |
who sells the right length ? and do you take slack out of the clutch cable with the wing nut? |
Tcash Samba Member
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Mon Apr 13, 2015 7:28 pm Post subject: Re: . |
LEE 64 wrote: |
Don't just buy a new cable. You also should get a new Bowden tube and a Clevis pin. Consult the Bentley for installation and those vids for proper adjustment.
Make sure you clean out the clutch cable tube with an air compressor before you install the new cable. And make sure you grease the new cable REALLY well when you install it. Also grease the Clevis pin pivot point. All important to smooth clutch operation. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Tcash Samba Member
Posted: Mon Apr 13, 2015 8:03 pm Post subject: |
Motorcycle chain lube works well.
Tcash |
Posted: Mon Apr 13, 2015 8:30 pm Post subject: |
To work on it where is sits it sounds like you will have to dig a trench under it. To access the tranny end up the cable I usually slide under the vehicle just in front of the left rear tire and then scoot back behind the tire. Maybe for you it would be easiest to dig a trench on the left side of the vehicle just to the inside of the left rear tire from the back. Not going to be fun or easy. You are also going to need access in the front, again this isn't going to be easy. If you can winch it to the top of the hill and then start it in gear and drive to a better location, that would be recommended.
It is also possible that the lever on the throwout shaft cracked or that the levers that push against the throwout arm broke off the shaft. |
LEE 64 Samba Member
Posted: Tue Apr 14, 2015 5:17 am Post subject: . |
your right wild things it is in a bad place i'm gonna haf to try and move it or dig a trench like you said |
Posted: Tue Apr 14, 2015 8:34 am Post subject: Re: . |
LEE 64 wrote: |
That sounds like a cable that was breaking strand by strand over a period of time, stretching, and then the last two broke. You can get the vehicle out of the low spot by starting the engine in first gear and turning the ignition off before you hit something. You don't really need a clutch at all if you have the skill to match the engine speed and the transmission while moving.
The place to buy the proper length cable varies with time. Do a search to get the latest info.
When you replace the cable tie a long piece of string to the end before you pull it out. Use the string to pull the new one back in and to guide it through the correct routing. The clevis pin in front and the bowden tube in back might need replacing also. Clutch cable repair is often a complete repair with all new parts front to back and a spare cable should be carried onboard.
Aloha
tp |
SGKent Samba Member
Posted: Fri Sep 25, 2015 10:04 am Post subject: |
Quote: |
steep wet grassy hill it was working then all the sudden I couldn't shift any more I couldn't reach the cable from the back because the bus is kinda stuck in a low place |
photo of where the bus sits would help _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
