Ian Samba Moderator
Posted: Thu Apr 16, 2015 10:18 pm Post subject: 2000 Jetta Mk4 2.0L P0134 |
From time to time I help my friends (girls) out with their Jettas, it's the nice thing to do you know . Anyway, my friend brought her 2000 mk4 in with these faults:
Address 01: Engine Labels: 06A-906-018-AEG.lbl
Control Module Part Number: 06A 906 018 JJ
Component and/or Version: 2.0l R4/2V MOTR AT V01
Software Coding: 00033
Work Shop Code: WSC 20111
VCID: 73EFC0AF41FEB5B963D-4B0E
9 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
17663 - Engine Coolant Temp Sensor (G62)
P1255 - 35-10 - Short to Ground - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-10 - No Activity - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
Readiness: 0000 0100
I know about the immobilizer, she uses her valet key. Engine coolant temp sensor has been whack for awhile, but I'm thinking the O2 sensor just shit the bed. Would a bad O2 sensor give the misfires too? She had a new CAT put in last year, and I checked, it's still there. She also mentioned that when the surging/dieing happens the exhaust smells, so I really think the O2 sensor ist kaput. Going to have at it tomorrow. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Apr 16, 2015 11:00 pm Post subject: |
Yup, replace the CTS and O2 sensor. Then clear codes and see what comes back. How old are plugs and wires? What does measuring block 32 show? Sometimes MAF's cause misfires w/o throwing a lean/trim code. |
Ian Samba Moderator
Posted: Fri Apr 17, 2015 5:05 pm Post subject: |
So far, new oxygen sensor (before CAT). New CTS. The vacuum line from the electric solenoid to the SAI combi valve was totally broke and unhooked, replaced that. Vacuum line from the manifold to the FPR was also broken in half, replaced that. Fixed a shorted out fuse that was turning her driver's side tail light off and making the cluster lights go out (parking light wire was shorting as the bulb holder got busted off long ago). She said she had the plugs done 4-5 years ago? It definitely needs a tune up (plugs, wires, coil pack) but she's moving to Hawaii and the Jetta isn't priority.
Fun little car. _________________ All your Buses are belong to us.
