tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Mon Apr 20, 2015 2:02 pm Post subject: Coil Wiring diagram |
I know this is in here somewere but after and hour of searching I am stumped.
I am rebuilding my engine and forgot to diagram the Coil and its wiring. Can someone direct me to how to tell which pole is which on the coil and what wires go to each pole. I have confused myself. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Mon Apr 20, 2015 2:22 pm Post subject: |
Plus is terminal 15, black wire coming from the ignition switch and then is tapped for things like the choke heating element (and idle cutoff solenoid and backup lights depending on the car) Negative is terminal 1 for the green wire going to the distributor condenser.
Posted: Mon Apr 20, 2015 2:36 pm Post subject: |
Thanks. Are there numbers printed on the coil below the male wire hook ups? _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Mon Apr 20, 2015 2:44 pm Post subject: |
Yes, there usually are.
15 +
1 - _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Posted: Mon Apr 20, 2015 2:48 pm Post subject: |
Yes, there should be. If it's a non-Bosch coil it may only say + and - though.
Posted: Mon Apr 20, 2015 2:49 pm Post subject: |
Thanks so much. I will work on this tonight. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Mon Apr 20, 2015 11:03 pm Post subject: |
From the Gallery "coil wires"
