Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Mon Apr 23, 2018 1:37 pm Post subject: Re: 1970 Convertible Rear Seat |
I guess 7 was hungry so it 8 9.
I'm here all week...
Great work Dave. I have an intact convertible seat bottom as well as a the matching back. I can take them apart and confirm your measurements if you think it will add value to the conversation. I can also draw a template in Illustrator once you are done measuring and upload it as a PDF that can be printed out at actual size.
...we're all in this together.
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32630 Location: Reading Pennsylvania
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
Posted: Wed Apr 25, 2018 2:10 pm Post subject: Re: 1970 Convertible Rear Seat |
djkeev wrote: |
The has been rebuilt by soneone using chip Board....... guess what water does to chip board?!?!
I think the chipboard was factory, my '73 and a '72 i stripped down both had chipboard.
d _________________ 1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe |
NoDents Samba Member
Posted: Wed Apr 25, 2018 3:11 pm Post subject: Re: 1970 Convertible Rear Seat |
Just a clarification to EVERYONE....
VW documentation refers to this as an "Emergency Seat", not a rear seat. I assume it was named as such to get around the fact that no seat belts are provided (DOT rules?)
BUT it also makes me wonder: What kind of "emergency" must it be to be OK to use this seat? |
Posted: Wed Apr 25, 2018 4:43 pm Post subject: Re: 1970 Convertible Rear Seat |
I spent 2.5 Hrs. today deconstructing my 70 Convertible rear seat back. It will take me a few days to get all the measurements drawn up and confirmed. I took plenty of pictures so I will upload those as well.
Things i can confirm so far:
- The front elevated edge on the back side of the seat IS made of particle board.
- The piece is held in place by 5 long staples inserted from the strip into the wood below.
- It is 1 3/8" (35mm) tall with a ~1/8 radius at the top edges, 1" (25mm) across the top, and 1 1/8" (30mm) across the bottom.
- The outer corners of the strip slope slightly curved downward. I traced the profile and will provide a 1:1 scale picture later on.
- The wood frame is constructed with press fit mortise and tenon joints and held together by the Masonite board stapled to it.
- The foam pad is stretched width-wise at the time of installation. It shrank about 1 1/2" once I removed it.
- The assembled wood frame is 36 1/8" wide. I did not get to measure the length today.
- The seat back retaining brackets are mortised into the side rails and held in place by machine screws threaded into T-Nuts.
That is what I have for now. I will have more information in the coming days. I need to measure all the rabbets, relief cuts, and mortise/tenon connections.
kiwighia68
Loren Samba Member
Posted: Wed Apr 25, 2018 7:27 pm Post subject: Re: 1970 Convertible Rear Seat |
These photos were from the rear seat I made for my 58 Ghia cabriolet, so some details will likely be different on later seats..
I made this seat for my Ghia by copying an original 58 Ghia cab seat and replicated the details as accurately as I could. It was a pain in the butt to make and I spent quite a while on the router table to get the details right. Here is another post on earlier cabriolet seat details, it might be of some assistance:
https://www.thesamba.com/vw/forum/viewtopic.php?t=373964&highlight= |
