John Palmer trailer question
ackackadak
ackackadak is offline
PostPosted: Thu Apr 23, 2015 2:54 pm    Post subject: John Palmer trailer question Reply with quote
Talking to trailer builder about building something similar to the John Palmer trailer... question came up regarding 4" drop dovetail w drop axle. How much road clearance does that leave? Concerned about dragging going up my driveway w slight incline. Builder wants me to go w/o dovetail and jack up trailer when loading. Thoughts please? Thanks.
hitest
hitest is offline
PostPosted: Thu Apr 23, 2015 4:13 pm    Post subject: Reply with quote
I'll bite, what the hell's a John Palmer?
Is it a trailer with Iced Tea, Lemon and Whiskey?
FU#5
Richard Roth
Richard Roth is offline
PostPosted: Thu Apr 23, 2015 7:49 pm    Post subject: Reply with quote
I'll see John at the Bug-In in May.
I will ask him then.
The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier
ackackadak
PostPosted: Fri Apr 24, 2015 4:48 am    Post subject: Reply with quote
Thanks.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Apr 24, 2015 7:48 am    Post subject: Reply with quote
They convert old Haynes etc double axle horse trailers to end dump trailers.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Richard Roth
PostPosted: Sat Apr 25, 2015 10:42 am    Post subject: Reply with quote
Just received this from John;
The dove tail does not scrape because the axle is mounted close to the rear.  It was copied from a flat bottom ski boat trailer.  The center of gravity is at the jack mount on a ACVW, so that is the load center that will be put on the trailer, and you need to have enough tongue weight to make it tow good when loaded.  Most common trailers tow poorly when a ACVW is loaded, which is why many are put on backwards.
The problem you have with a low car, is that the car scrapes when you drag it up "on a high trailer".  You have several options.  Longer ramps reduce the angle but are harder to carry, dove tail on the end of the trailer reduces the angle, but is low.  A "lower deck" height lowers the deck, but then the front of the trailer is low.  I have seen nicely built flat trailers, with a super low deck that look good and address the loading issues.
If I were to build another VW dedicated "open trailer" it would be a small tilt bed trailer much like a Jim-Glo design.  The problem is, a rear engine car has much different weight centers than a front engine car.  The front engine Jim-Glo trailer design would require much redesign to make it work well with a "weight heavy" rear engine car.  I discussed this with the original owner/designer of Jim-Glo many years ago, and he told me he ran into the same problem trying to build a trailer for a SCCA 356 sports car guy.
John Palmer
1966 Empi GTV MKIV
IN2VWS
IN2VWS is offline
PostPosted: Sun Apr 26, 2015 3:31 pm    Post subject: Reply with quote
I recently purchased a new trailer for my cars. My previous trailer required the ACVW's had to go on backwards to get the correct ball weight.
This new one, I can drive the cars on and still have the correct ball weight.
As you can see, the deck lowers (no ramps). If you need to work under your car, you can raise the deck higher to get under your car. It raises to 800mm.
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³
ackackadak
PostPosted: Fri May 01, 2015 8:07 pm    Post subject: Reply with quote
Jeez, what a great response. Thanks guys. I was ready to go with what was being recommended by my trailer guy. Special thanks to Mr. Palmer for his time and effort to put this altogether for me. I will be printing this thread out and taking with me tomorrow along with my car that barely makes it across the threshold of my garage w/o scraping. I can fix this but I am extremely thankful I will not be buying a trailer which I suspect I'd never be happy owning which most likely couldn't be fixed. Thanks to Mr Roth for making it happen.
I hate to impose with a follow-up question but the article in HVW does not specify where to place the axle to make all this work. I suspect my builder will have an educated opinion but if Mr. Palmer could fill in this gap I would be able to sleep once I make my deposit.
My sincere thanks for all the help.
John Palmer
vegasSTEVE
vegasSTEVE is offline
PostPosted: Mon Oct 02, 2017 1:51 pm    Post subject: Re: John Palmer trailer question Reply with quote
Though this is an older post, I thought I'd throw this out there.... I now own the "Palmer Trailer" - if anyone is looking for dimensions or additional photos of the trailer... let me know...
56 Oval Sunroof
59 Ghia Coupe
68 Single Cab
Las Vegas Volkswagen Club-1997 (Founding Member) An Officially Licensed VWoA Club
