mitch5 Samba Member
Joined: October 17, 2019 Posts: 136 Location: phoenix
Posted: Mon Oct 26, 2020 9:56 am Post subject: Amadelle: The 2WD to Syncro swap |
This thread might as well serve as an intro, i have observed this site for awhile and finally decided that sharing this build is worth it. Per the thread title, I’m already in the process of converting my 2wd westy to a syncro westy, opting to do a drivetrain swap onto the westy. This thread will be unique in that I will outlay all the costs involved, people should be warned what puts the $ in $yncro.
Untitled by mitchmarkulis, on Flickr
Background:
My partner and I bought Amadelle w/ 120k miles in 2017 in Tucson, at the time i had limited knowledge of vanagons but knew i would only buy a van with zero rust. The van having no rust was about the best thing going for it, it had an ej22 swap but it was half complete and half assed. Stickwelded 1x1 engine mount, rear mounted subaru radiator and ofcourse a blown head gasket.
Here is the previous work done on the van to bring it up to today,
-ej22 with arp studs and mls gaskets(fixed the hg issue), new clutch ,timing, ect
-converted the van to a proper watercooled setup using the stock front rad setup with stainless pipes.
-Shortened the oilpan after I smashed it offroad
-built a skid plate, installed the RMW Subaru mount
-built a tubular exhaust for it
-ran new battery cables and upgraded the starter
-mounted some bfg tires on the 16 in clk wheels
-Fab a rail mount for rack system
Fixing previous owners work
Van by mitchmarkulis, on Flickr
Rail mount
Headers
Why a Syncro swap??
Since doing most of the work the van has been enjoyed the past few years, during this time the van has been riding on almost all the original suspension. It handled fine on the highway but was miserable off road, the westy needed a complete suspension refresh. With the westy I increasingly found myself going offroad and getting into dicey situations. While the rear weight bias of the van helps its 2wd capability immensely, the lack of low gear and an open diff make anything with a steep grade tough. A syncro swap will solve all that.
A normal person would probably sell the van, go buy a 4x4 truck and stick a slide in camper in the back and call it a day. We however had fallen for the vanagon and decided to undertake the conversion. Its no secret how expensive/rare/desirable a syncro is, let alone a camper. I had a solid camper with a sorted motor, but all original suspension. A rusty syncro needs everything, so clearly if I going to replace all the suspension on the westy I might a swell convert it to a syncro. The decision was made to buy a beat up but running syncro and cannibalize it for all the parts.
Buying “The Dumpster”
It’s got no title, a locking rear diff, terminal rust and is missing almost everything that isn’t syncro specific. This may not be the perfect donor but is the best running unit I could find within driving distance. Buying a running van let me know exactly what needed replacing and rebuilding, the other option was a non runner where you have to assume everything could be bad.
This van had been listed for awhile in Colorado, having no title and rust made it a non seller to most. Working with the owner who ofcourse had multiple vans, we worked out a deal where he could take any good parts of the van to keep the price down. That included the door. The price for the beauty? $6500.
My brother and I flew to Denver for 50 bucks and drove it all the way back to phoenix roadkill style. We bought tools in Denver, preparing for the worst but the dumpster made it all the way back in about 15 hours. We never even got pulled over, by the 10 plus cops who must of passed us.
Proof that the syncro is beyond saving
C by mitchmarkulis, on Flickr
Starting the Swap
The first step of this swap was to sell all valuable parts first, this meant selling the 2.1 wbx in the syncro and the 2wd drive trans out of the westy. Both are now sold.
2wd Trans w/ linkage $900
2.1 motor $1000
Extra 2wd core $400
The next step was to start pulling all the parts off both vans and send the trans off to Arizona transaxle exchange for a rebuild. Some people do the swap in sections but I opted to get everything off my westy so I can do body color raptor liner underneath.
I am fortunate/smart enough to not live in an HOA and have room to park both vans inline on the side of my house.
Here are some pics of the setup so far
Starting to pressure wash off a non factory undercoating that was done and covered everything.
C by mitchmarkulis, on Flickr |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Sodo Samba Member
Joined: July 06, 2007 Posts: 9613 Location: Western WA
Posted: Mon Oct 26, 2020 10:23 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
I'll be reading along too.
Funny that you got it to drive for 15 hours.
Headers are a pretty good DIY effort.👍🏽
Could work on a street 2WD but don't put it on a Syncro....🤣🤣 _________________
....KTMs, GasGas, SPOT mtb |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17154 Location: Retired South Florida
Posted: Mon Oct 26, 2020 10:38 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
I recently did this to a 90 automatic camper. I was expecting the front to be the challenging part and it ended up being the easy part.
The challenge was to locate the transmission mounts. I had the drive train in and out a few times. Once I centered the transmission, I transferred the bracket holes to the chassis and drilled them through. Despite all the ways I found to get nuts into the chassis, I found I was able to make 2 nut plates and fish them into the chassis from one of the oval cutouts. I then bolted the nut plates into place and rosette welded them from below. This ended up being very clean and I didn't need to remove the interior to cut the floor for access. So it is possible.
I was posting in this thread, but there didn't seem to be any interest. Its quite common now. https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=80
If you run into a snag, feel free to reach out to me. Mark _________________ ☮️ |
mitch5 Samba Member
Posted: Mon Oct 26, 2020 12:16 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
The headers should work fine with the syncro setup, its hard to see in that pic but they sit well above the skid plate when installed. i will need to redo the mounting though to account for the drop in height when i installed the drivatrain in the synco position.
Regarding the mounting, ya thats going to be tough. I have an aircooled model and from my rough measurements i will need to cutout and weld in a new section where the heating duct crossed through the member. Ill cross this bridge when i get the tranny back.
Similar to the option you considered in your build
I may end up making a jig like you suggested though. I just need to figure out some datum points that are identical between the two vans.
If the syncro one wasnt so rusty i would just transplant it
Here is a picture of the aircooled crossmember
Posted: Mon Oct 26, 2020 12:22 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
Ouch, that’s a pretty substantial difference. There was a recent thread where someone replaced a rusted out section of that cross member on a syncro. He found a repair piece on line.
You’ll need to use the r/s as your attachment point and then fabricate the l/s where the cutout is. If you look at the thread I linked, I used a laser to center the trans to the front differential. _________________ ☮️ |
mitch5 Samba Member
Posted: Mon Oct 26, 2020 12:30 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
do you know if any of the mounting holes are identical between the 2wd and syncro? The laser will be great to align it all. I really trying to avoid taking the trans in and out repeated times, it sucks with a jack stand setup. |
Posted: Mon Oct 26, 2020 12:39 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
The 2wd cross member has 2 sets of transmission mount holes. Depending on transmission one set or the other is used. The syncro has the majority of the holes in the same location, but a couple are covered with the driveshaft protection mounting tabs. Those need to be drilled off and transferred as well. I added those last. I used the bars and engine protection to locate them after the fact. _________________ ☮️ |
mitch5 Samba Member
Posted: Mon Oct 26, 2020 12:41 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
So im looking for some input on the suspension, here are my current plans
-use stock springs
-use the burley kit listed here for all bushings https://burleymotorsports.net/product/the-complete...m-bushings
-install zerks in the upper control arms
- burley balljoint package, it list everything as febi. Im all to familiar with the german suspension companies. Im into older bmws and have gone through mayhle, lemforder, ect. Whats the good setup for a vanagon? i have had crappy parts from all three on my bmws
Shocks is the tough one for me, the GW full adjustable seem like the cats meow but i dont need all that adjustment and thus dont want to pay for it. Not to mention im not very impressed with the fox quality. There is also the non adjustable option from GW for $1200
I do a good amount of offroad driving, lots of wash board forest roads. So ext. reservoirs for rear and going non adjustable. Debating doing the semi custom Bilstein route using off the shelve components. Im thinking about getting similar valving to the GW XHD setup but with a higher quality Bilstein shock. Like the 5100 series
Anyone have feedback on Bilstein's with a camper? |
Posted: Mon Oct 26, 2020 12:59 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
I spent my money on cv boots, bushings, and hardware. So I could replicate the syncro, I reused the stock springs arms etc. I did spring for new shocks, but not at the same time. I did the front shocks when I transferred the front suspension. They are not easy to swap out.
It’s a ton of work. My advice is get your syncro camper built and then decide on upgrades. This requires tons of measuring and remeasuring. Why add variables? _________________ ☮️ |
ajdenette Samba Member
Joined: February 15, 2009 Posts: 768 Location: Hope Valley RI
Posted: Mon Oct 26, 2020 4:43 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
based on the condition I would inspect the rear springs I have had springs on 2 vans that have had broken tails on both sides I found them on my 90 based on the strange noise when hitting bumps that turned out to be the broken ends bouncing around. _________________ 1985 2wd Westy with 2000 Subaru 2.2 current driver
https://www.thesamba.com/vw/forum/viewtopic.php?t=685635
1986 Syncro Doka Project next in line
https://www.thesamba.com/vw/forum/viewtopic.php?t=732777
1990 Vanagon Syncro Base awaiting body work |
mitch5 Samba Member
Posted: Fri Oct 30, 2020 1:23 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
So first item i decided to start looking into was brake upgrades, there are obviously lots of bolt on kits out there. A majority of them seem to use oem calipers off other applications. Having experienced 2wd brake fade i really want the upgrade so vented rotors can be used. The syncro also uses a more traditional hub and rotor arrangement so the conversion is made even simpler.
Research showed quite a few DIY options.
-Audi 5000/100 calipers per this link http://www.syncro.ca/tech/audibrakes.htm
-Audi A8 brakes using a g60 caliper i believe, these are 312 mm, a little big in my opinion https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
-Audi A4/Passat 288mm rotor, this is the option i have decided to go. Parts are very available and the size is decent. This setup should require the least effort effort to get on my car. Basically redrilling one hole and adding a spacer. HANSJ has the best pictures of the fitment here https://www.thesamba.com/vw/forum/viewtopic.php?t=500180
I set off to the yard and pulled a complete set of a 2002 A4 1.8T, i was surprised how many vw/audi owners use wheel locks! 2 out of 6 possible cars had them.
Either way the set i pulled has the wrong carrier, although the piston seems identical and the rotors are 288mm. The first clue seems to be the ones i pulled are aluminum while all the other i have seen are steel. The spacing is to far and it would require a 3/4 spacer to work. heres a pic, the syncro is the rusty one
Untitled by mitchell markulis, on Flickr
Looking at used calipers online it appears there are different carriers used between models. I'm going back to the yard to pull the correct set. Does anyone know which vw/audi model should contain the steel type carriers? Im bringing my impact this time to get wheels off. |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 777 Location: Out exploring
Posted: Fri Oct 30, 2020 5:07 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
Following along! Looks like a great project.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
mitch5 Samba Member
Posted: Thu Dec 31, 2020 12:38 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
Been making some good progress, most of the major mounting points are swapped over.
-Front subframe mounted
(using all 6 bolts per side), pretty straight forward.I choose to makes all my cuts to the frame, cut plates them mock the subframe up. One i had it all straight i tack welded the plates then drilled them in place.The rearward threaded bars were so rusty that i thought i was going to need to fab some up. Then i discovered gowesty sells a kit! worth the 50 bucks
Steering rack-
I swapped over the syncro rack and opted to weld it in place, this gives a closer to oem look. The syncro came with power steering and my 82 had manual. I plan to run manual steering, the shafts are different ofcourse. Not sure if there was ever a manual syncro but i plan to cut and splice my shaft to work. Getting the rack out was made easier with a plasma cutter but drilling out all the old spot welds sucks. Heres what ended up with
Transmission mount-
So converting an aircooled vanagon to a watercooled then swapping that to a syncro brings a new set of challenges. Mainly the trans mount, the aircooled has about half the geometry correct, the other half has a big hole for for heater piping. My inintial plan was to cut out the syncro mount and weld in my westy. Well removing the syncro frame section revealed the rust was way beyond repairing.
Plan 2 was to use the syncro frame to build a jig using the inner most holes for the tranny mount to act as a datum, all in all it took a full day to complete this. If i had a lift this may have gone alot faster, welding on your back slows things down.
At first i debated replicating the factory construction but settled on overlapping plate being stronger and easier then doing a bunch of butt joints with backing. all in im pretty happy with the results, there seems to be enough slop in the brackets/tranny that fitment shouldn't be an issue. I welded nuts on the backside of bolt, to achieve this i simply cut a hole in the upper(thinner metal) section of the member. Once i was done i stitched it back in.
jig
cutting
final product
i finished the middle brace but did not take pictures, next up is seam sealing everything underneath before spraying the entire underside with color matched raptorliner. |
mitch5 Samba Member
Posted: Thu Dec 31, 2020 12:42 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
I have a question about the clutch slave? I didnt pay much attention to this when dropping the engine out of the donor. It seems i can run some braided stainless hose(burley) and junk the plastic setup. |
Posted: Thu Dec 31, 2020 7:50 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
Memories. Nice progress. I can't believe you are doing this on th through. I had intended to swap the cross beam, but didn't want to bue floor. I had a lift and at my age, it was still a lot. My van was an automatic, and I just swapped all the parts from the syncro donor for the clutch.
We make up steel braid hoses all the time. The quickest place to get the parts is Summit Racing. I like Earl's, but there are other companies that make AN fittings. You'll likely need an adapter for the connections to the master and slave. I personally wouldn't run steel braid the entire length.
I would buy some bulk metal tube and use tube nuts that attach to the AN hose ends. That said, if Burley has a drop in solution, that makes sense.
You will need to address the cross beam where the driveshaft where the drive shaft runs forward. Rather than butcher the stock floor welding in the syncro cross beam, I modified the 2 WD crossbeam. Someone would spot it, but oh well.
I also decided to fabricate a fuel tank bracket rather than swap it. The factory design collects a lot of dirt and moisture. I made a jig to transfer the 2 strap attachment bolts, and rather that weld the bracket to the van, through bolted it behind the seat careful to not have bolts that could puncture the tank in an accident. Not my design. I copied it from another member on the Samba.
I figure the entire project is around 200 hours labor. I didn't keep track though. _________________ ☮️ |
4Gears4Tires Samba Member
Posted: Thu Dec 31, 2020 7:53 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
Sure why not. I've always thought the plastic was a little scary to use.
Why ditch the power steering? If you are trying to ride the sidewall and then up and out of a rut, manual steering is going to be a bit less than optimal. _________________ '87 Syncro
tjet Samba Member
Posted: Thu Dec 31, 2020 9:24 am Post subject: Re: Amadelle: The 2wd to Syncro swap |
That "Dumpster" van looks just like my current '87 Syncro. I think VW sold a bunch of them in the North East. I had 2 matching Syncro's at one point. Both came from the same dealership from PA. The VIN #'s were fairly close together.
https://www.thesamba.com/vw/gallery/pix/1809524.jpg
I plan on doing a similar conversion (Syncro-to-Westy) when I find a rust free one. My van is a driveable "storage unit" of Syncro parts Thank god for all the plastic pieces on my van. They are in good condition vs anything metal.
I agree with 4Gears about the power steering, but I'm also running 31x10.5R15 tires.
I also bought a Burley R&P conversion rack mount to use when I do attempt a conversion.
What engine do you plan on using?
I will be bookmarking this thread alongside all the other Syncro conversion threads I've saved |
mitch5 Samba Member
Posted: Thu Dec 31, 2020 12:41 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
Thanks for the pictures of your swap, I already modified the middle crossmember. I basically took some flat stock and replicated the syncro geometry. I plan to do something very similar That you have shown for the gas tank but tig it from aluminum.
I should have expanded on the clutch Line, I have the factory line going up to the trans cross member. I just think the position in my 82 will interfere with the gas tank. Either way I’ll just wait till the end to get to that, for now I have the line tucked behind.
Reason for ditching the power steering is simplicity to get the van on the road and avoid scope creep. I would need a power steering pump for the Subaru, I’m guessing some new lines/fittings also the lines from the donor are pretty rusty. The 82 has a large Steering wheel so Hopefully it isn’t bad.
I plan on keeping my ej22 setup, i did a top end recently and it’s a solid motor. It makes good power but not to much for the o so delicate transmission.
This build is bordering on almost a full underside restoration. Refreshing every axle, bearing and bushing in the driveline will probabaly push me over the 200 he mark. |
mitch5 Samba Member
Posted: Thu Dec 31, 2020 12:54 pm Post subject: Re: Amadelle: The 2wd to Syncro swap |
Another update on suspension.
Shocks/springs
After looking at all the options I decided to do a semi custom setup, I like to drive off-road but can’t justify 1900 bucks for fully adjustable fox shocks or 5k for the burley setup. I like bilstein and their support but didn’t want to deal with custom valving so here is my setup, best part is it’s only set me back $600
Setup
Front-bilstein 16inch syncro 24-247245
Im planning stock ride height, not a whole ton of personal feedback i can find but they are supposedly valved stiffer to deal with the increased weight of the 16' syncro. Right now these can be had for $110 per shock,
Rear-remote res 7100 series Bilsten
Collapsed Length (IN)14.29
Extended Length (IN)24.31
Collapsed Length (MM)363.0
Extended Length (MM)617.5
Compression @0.52m/s 80
Rebound @0.52m/s 3800
For springs I plan to run the stock syncro in the rear and the 2wd westy in the front. The valving for the rear should work well for my westy, the front is kinda an unknown but should be stiffer than the 14 inch wheel shocks. |
