dismantling engine tin type IV
newrider
newrider is offline
PostPosted: Sat Apr 25, 2015 9:58 pm    Post subject: dismantling engine tin type IV Reply with quote
Are there any sites that will help dismantle my 1800 type IV engine tin and cooling ducts? Question
Wasted youth
Wasted youth is offline
PostPosted: Sat Apr 25, 2015 10:11 pm    Post subject: Reply with quote
What kind of help are you looking for? If you're just removing all the tin, a large box and ziploc bags for screws, a roll of tape and a Sharpie for labeling, and finally a digital camera to take a bunch of pictures of how all your newly labeled tin pieces go... that's pretty much it.
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
timvw7476
timvw7476 is offline
PostPosted: Sat Apr 25, 2015 11:23 pm    Post subject: dismantling engine tin type lV Reply with quote
don't forget an impact driver tool, driven by a nice big hammer-
& the thick slotted bit, if it's 1800cc, they used slotted screws and
they will be quite tight. Regular screwdriver(s) & wrist(s) won't get you far. :l
Wildthings
Wildthings is offline
PostPosted: Sun Apr 26, 2015 3:43 am    Post subject: Re: dismantling engine tin type lV Reply with quote
This problem is best solved by throwing out the slotted screws as you remove them and using hex head screws. I still have one or two phillips head screws in select places just because they are easier to start using a long screw driver than a hex head would be with a long extension.
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Apr 26, 2015 6:22 am    Post subject: Reply with quote
These screws work pretty well for not huge money....
http://www.mcmaster.com/#92005A422
