Gauche1968 Samba Member
Posted: Tue Apr 28, 2015 11:46 am Post subject: Front Bearings Installed Backwards? |
Is this even possible or would the taper of the races in the discs prevent one from making this stupid mistake? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue Apr 28, 2015 11:50 am Post subject: |
Anything can be installed backwards if forced hard enough
Not likely with bearings |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Tue Apr 28, 2015 12:08 pm Post subject: |
I saw it once in a mk3 rear drum. Don't know how they did it, but they did and it is possible to get it wrong. Only a tiny bit of common sense is required to get it right. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Terry Kay Banned
Posted: Tue Apr 28, 2015 2:17 pm Post subject: |
Almost totally impossible, unless you had a set of real dark welding glasses on when you did the install. _________________ T.K. |
Posted: Tue Apr 28, 2015 5:15 pm Post subject: |
hans j wrote: |
I saw it once in a mk3 rear drum. Don't know how they did it, but they did and it is possible to get it wrong. Only a tiny bit of common sense is required to get it right. |
Ah, the things we see from time to time.... _________________ 1984 Vanagon GL
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Tue Apr 28, 2015 6:54 pm Post subject: |
Actually, it is quite easy to put a RACE in backwards. In fact, even tempting as backwards you have a nice wide edge on the race to hammer into the hub. What you'd then do with a bearing would be another matter, but if someone had enough threads on their spindle, even this is possible. I'd be fascinated how long something like that would last. I'm thinking coffee shop and back. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
