FRNKNSTNGHIA Samba Member
Joined: March 05, 2010 Posts: 411 Location: Kissimmee, FL
Posted: Thu Apr 30, 2015 5:34 pm Post subject: Cause everyone loves a build thread.... 1956cc |
So after some thought and advice I have updated my parts list:
After reading numerous threads, and looking at build sheets using these parts I feel that they will suffice for my 100hp build.
9.0:1 compression (93 octane)
AA SP heads with S/S valves, chromoly retainers, single HD springs. Intake ports opened to 31-31.5mm and exhaust ports opened to 32mm.
CB Rocker Shafts with 1.25 rockers only on the Intake side, stock rockers on exhaust side
Engle W100 Cam
AA 90.5mm Pistons B piston
AA I-beam rods 5.5 Rods
AA 76mm crank
AA L/W flywheel with gland nut
Dellorto FRD 34mm carbs (29mm venturies and jets to match)
CB performance Weber ICT Linkage and Manifold kit, modified to fit Dellortos
MST Serpentine Pulley System
Spring Loaded pushrod tubes with Silicon Seals
1.5" Sidewinder Exhaust
Pertronix Flamethrower III SVDA Distributor
Petronix Flamethrower 3ohm Coil
26mm pump with full flow
External cooler with fan and 180 thermostat (brand undecided)
All new engine tins (36hp shroud with no heat)
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Apr 30, 2015 6:10 pm Post subject: |
You can't decide on a compression ratio before you select a cam. It doesn't work like that. 9.0:1 on a really low duration cam could require race fuel or with a high duration, 9.0:1 could be ridiculously low and need Only 87. Also, the more intake restriction you have, the more "safe cushion" you'll need. You'll want to keep compression conservative for the cam you'll select.
I won't talk you out of using SP heads, but since your top end will be limited to 5,000 RPM or lower, you should choose a cam with a matching powerband. If your selected cam makes power to 6,000, but your heads won't flow that high, you'll have a combo that leaves bottom AND top end power on the table. Another thing is 35mm intakes won't flow too much over .420"-.440" of lift. Lifting any higher will be a mechanical waste. A cam like the SCAT C20 or Engle 100 is about as big as you could go. If you end up upgrading to duals and better heads, there won't be huge gains with that small cam. You'll need to use a different cam or go with ratios.
Ooooor, you could use a FK7 with 1.1 rockers, which puts you near .400" lift with the SP heads, then swap to 1.4 rockers with the L5s. That would actually be a good compromise. 150-160? Definitely no. Maybe 125. It's going to be nearly impossible to find a cam that will work well with both heads. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Thu Apr 30, 2015 8:25 pm Post subject: |
bugguy1967 wrote: |
Ooooor, you could use a FK7 with 1.1 rockers, which puts you near .400" lift with the SP heads, then swap to 1.4 rockers with the L5s. That would actually be a good compromise. 150-160? Definitely no. Maybe 125. It's going to be nearly impossible to find a cam that will work well with both heads. |
I agree. This combo is on track either make a good bus engine with small cam and the small carbs or a totally different beast with other cam and carbs, and of course heads. Compression matched to the cam. Are you asking for advice? Build it to be a torquey driver or pump it up now for that 150 hp mark you are looking for. Slapping different heads and carbs is not going to transform a mild single port in a weekend. 10:1 compression on a single port without knowing the cam? No way. Why are you set on single port while talking such big numbers? 1+1 is not going to equal 3, no matter how much you want it too. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
modok Samba Member
Posted: Thu Apr 30, 2015 8:45 pm Post subject: |
Sp heads have limits
IMO cam max 240 degrees at .050, max cr 8.5-1 average
Of course, the compression will be too high. It could be brought down by 4 hours of work to the chambers but I hav3e a feeling you don't want to do that eh?
set deck as usual but use copper gaskets to space out the deck and drop the CR down, then later on can swap heads without upsetting the rings. |
Posted: Fri May 01, 2015 7:59 am Post subject: |
I wasn't implying that I knew what Compression Ratio I was going to run, more so that I could run up to 10.1:1 if I could, since I have access to 93 and 100 octane easily.
Also for single port heads not flowing, Alstrup clearly has dyno-proven setup in the Engine Build stickies that Single Port heads ported to his spec with stock valves and 9-1CR making peak power from about 4500-6100 RPMs.
That setup from what I can see was using 34mm dual carbs, 90.5 pistons, and I assume stock crank. And that was using stock heater boxes with a bugpack 1 3/8" header.
Motor made peak 94hp at 5500RPMs and about 113ft lbs at 3760RPMs.
So I think with the 76mm crank, larger exhaust with J-tubes, should easily make similar numbers with most likely a better powerband.
So I would like a cam and rocker setup that would take me to atleast 6k RPMs but doubt it would see that range. |
modok Samba Member
Posted: Fri May 01, 2015 4:29 pm Post subject: |
Sp heads do have a few advantages often overlooked.
-Minimal manifold volume allows single carbs to work well.
-intake charge is not heated as much compared to DP
-smooth powerband due to different VE curves for front VS rear cylinders.
-the heads are slightly more durable
-with dual carbs "kadron idle" effect is also crude cylinder de-activation system for boosting MPG
CONS
-can't handle long duration cams due to charge robbing
-flows 15-20% less than DP heads
-engine runs unevenly
So, they flow poorly and can't use big cams..........so lets make it bigger and turn more RPM???
(Al Borlen sound effect) I don't think so tim |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Fri May 01, 2015 5:09 pm Post subject: |
150 hp out of sp heads, yea right. Just dyno'ed a 2110 with clyde berg heads, matched tall manifolds, 44 idf's, 1 5/8 merged header at 8.8:1 c/r. made 155 at the crank _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri May 01, 2015 6:28 pm Post subject: |
He never said he wanted 150 out of SP heads. You need to re-read his OP.
FRKNSTNGHIA, it takes a lot of work to make his heads flow well. Alstrup might even have flow bench access. All the power, in his case, came from headwork. If he would have bolted on a stock unmodified set, the numbers could have been over 20 HP lower. Home porting heads could go either good or bad. I'd try to contact him and find out where and how to port them.
Also, more CCs doesn't always mean more power. The heads on that 1776 will come close to perfectly complimenting his combination, whereas if those heads were bolted onto something else, the combo might not work as well together.
Hopefully, you can dyno the engine when finished. That's the only real way to know. Even I don't know what 100 HP feels like, and I've built all sizes of engines. I couldn't get it any one car and say that the car "felt" like it made x-amount of HP. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sat May 02, 2015 3:25 am Post subject: |
mcmscott wrote: |
150 hp out of sp heads, yea right. Just dyno'ed a 2110 with clyde berg heads, matched tall manifolds, 44 idf's, 1 5/8 merged header at 8.8:1 c/r. made 155 at the crank |
Slightly O.T.
Steady pull or rpm climb ? Water brake or induction ?
There are often more than one way to get to the goal. But if high performance is sought with sgl port heads you really need split cams. Then they can actually deliver quite well, as I have also written about earlier.
T |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sat May 02, 2015 9:17 am Post subject: |
modok wrote: |
I would not br that generous.
Stock cam with high ratio rockers or the CB cheeter cam. SP heads are worthless waist of time and money unless you are into the vintage thing.
Dan |
Posted: Sat May 02, 2015 9:35 am Post subject: |
Not nessessarily. You just have to think different. Something we more or less forgot in our quest for "easy power" |
Posted: Sat May 02, 2015 10:21 am Post subject: |
Dan Ruddock wrote: |
I would not be that generous.
Dan |
Alstrup wrote: |
Line bored AS case.
Good used stock crank.
215 mm Flywheel, stock weight
Stock 215 mm clutch. All balanced.
Silverline main Bearings
Mahle rod & cam bearings
CB Unitech rods. 550 gr.
26 mm Shadek oil pump w. full flow system. Stock late model oil cooling + a thermostatic controlled steel cooler from a 34 hp engine, located between the struts under the car. (opening temp needs to be raised to 80 d. C. because the engine doesnt really get warm here in early spring)
CB Thin line oil sump. 1,3 qrt.
Engle W100 cam installed on 106 ILC.
CB lightweight lifters.
90,5 mm Mahle cylinderset.
Sgl port cylinderheads, ported, chambers altered to a compact wedge style. Stock valve size. Intake flow 120 CFM at 0,500” and 25”. 9-1 CR.
Manton push rods.
Bolted CB rocker shafts w. 1,25/1,1 rockers.
34 mm PDSIT dual carbs from an early 1700 bus engine. Modified. CB sgl port manifolds w. 20 mm extensions to get more plenum area and also get a better intake length. 60 mm home made intake stacks, bus type hex bar linkage, modifiead to fit in a type 1 set up. When we were done they flowed 115 CFM @ 25” hooked to the heads.
Bosch 205 SVDA distributor from a type 4 bus engine, rebuilt and altered curve to fit the type 1 engine.
Older Scat 30 hp fan housing with doghouse and venturi ring, and large fan.
Stock heater boxes. Bugpack 1 3/8” header with twin Citroen BX 16 mufflers.
T
Not so worthless or a waste of time, and mine will have a 76mm crank so the powerband should be overall better. Oh and 153.2Nm equals roughly 113 ft lbs. |
modok Samba Member
Posted: Sat May 02, 2015 11:20 am Post subject: |
FRNKNSTNGHIA wrote: |
I rather like Sp engines, but what worries me is this statement.
Why do you think your example engine has en engle 100 cam???
Big duration cams don't work! Overlap past 25 and "intake valve overlap" past 50 just serve to blow more fresh charge out the front exhaust ports.
To make more power and/or rpms the heads need work above all. If it was DP engine you could just use a engle 120 cam.... but a SP you can't (or rather you can but it won't work well)
Alstrup put quite a bit of work into the heads and intake manifolds, take note!! You should be asking what diameter and dimensions to make the intake manifolds and how to get more flow from the intake ports!
what does a stock SP head flow?? 80-90 cfm probably. you have to improve that!
Cam is easy IMO. fk-41, web 218........or engle 100
a scatter cam would be best but the gains would not be hugely impressive. Perhaps 8% at most |
Posted: Sat May 02, 2015 11:51 am Post subject: |
Did not say it could not make some power but to drive something like that day to day with an obnoxious idle and as smooth driving as 80 grit sandpaper is not my idea of fun. I know I built some engines like that back in the late 70's when I did not know what I was doing.
I would be embarrassed to drive a car that idles like that. The hydrocarbons that a big cam sp engine puts out at idle pegs the meter. Two of the cylinders fuel mixture are so off at idle that it won't even fire the mixture. Gross polluter!!!
There is more to an engine than what it's peak torque it makes at high RPM.
Two way to fix it, separate each banks manifold runners from each other or do what VW did which was put in a very mild cam.
In a race car it does not matter because it's at wot almost all the time and if the rules say sp heads, why not.
VW's were designed to be cheap and a sp steel intake manifold was cheaper than the dp three piece setup.
Dan |
vwsb74 Samba Member
Posted: Sat May 02, 2015 12:08 pm Post subject: |
You should buy my low mileage 77.5 dpr crank and my mahle 90.5 stroker p/c 1991cc . I made almost 130hp at 5.5k rpm with 256@50 duration 106 lobe center. I bet it make more hp With 86b. _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Sat May 02, 2015 12:22 pm Post subject: |
I have been communicating with Alstrup for quite some time. Wish he was stateside, so that he could build my motor. For now his advice is GOLD. He has informed me of the dimensions to port the intake and exhaust, I would also have the manifolds port matched as well. FRDs will most likely get bigger venturies and jets.
Rough idle, if its 1k or less, no problem.
Gas pollutant, Florida has no SMOG test, and Alstrup's 1776cc SP at WOT had AFR of 12-13:1, perfect range from my experiences. Meaning off WOT it shouldn't be wasting fuel.
Car will be properly tuned on the dyno, if that is not a possibility it will be tuned with a Wideband AFR with data logging capability. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Sat May 02, 2015 1:18 pm Post subject: |
Along with Modok, I do like a nice little single port, but just don't get your hopes too high.
I spent a ton of time putting together a 1915sp. I have a flow bench in the garage, and I spent about a month of evenings getting my stock valve heads to right at 130cfm. It wasn't easy, and they are pretty much maxed out with the 35mm intake valve. I also moved the intake studs, and converted to a standard flange on the intake. I ran kadrons on custom built tapered manifolds.
I used a 218/119 split cam, and I can now say I wouldn't do it again. I wouldn't go past [email protected]. The idle is pretty rough.
Overall it's a good little engine, it makes some power, and it looks great, but for the time and money I would have been way ahead with the exact same engine but dual port heads and a set of 40mm idfs.
modok Samba Member
Posted: Sat May 02, 2015 1:40 pm Post subject: |
I have a 1904cc sp in my buggy, single dellorto, cb2233 cam
The idle is pretty funny. It idles like a V8 with a hot cam.....lopety lopey, but it lopes along quite happily at 1000 rpm. Never stalls even when cold.
I just made a new intake for it and now it idles better WITHOUT a balance tube for some reason.
But....runs strong and a joy to drive. Throttle response is predicable and instant, and it will pull WOT from 2500 rpm!! it's quieter than any dual carb engine I've heard. TOrque curve like an electric motor, which is preferable for a lot of offroading purposes. |
vwsb74 Samba Member
Posted: Sat May 02, 2015 2:42 pm Post subject: |
Brian_e wrote: |
My old engine was idling 900rpm dead steady. It had 256@50 duration _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
Posted: Sat May 02, 2015 3:30 pm Post subject: |
I did a sync and tune on a mustang GT350 once with four ida carbs. Once I was done there was no rupity rupity and idled like glass even though it had a stout cam in it.
A V8 with a 4 Barrel carb and hot cam IMO is embarrassing and shows lack of tuning skils.
The V8 people could learn a few things from us and we could learn some stuff from them.
I like engines that run properly.
Dan |
