Type 4 Injector question
shiningstar76
Samba Brewer
shiningstar76 is offline
PostPosted: Fri May 01, 2015 7:39 am    Post subject: Type 4 Injector question Reply with quote
I couldn't find anything in the search.......
Injection is all new to me so please bear with me as I may have some noob questions.
I just changed out the rubber fuel lines under in the engine bay, and noticed that the rubber line right off injector number 3 is leaking. Is that rubber hose pressed into the injector and not replaceable?
KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it.
busdaddy
busdaddy is offline
PostPosted: Fri May 01, 2015 7:45 am    Post subject: Re: Type 4 Injector question Reply with quote
It is replaceable, you can either get under those bell shaped cups with an xacto knife and cut the hose off lengthwise or split the bell with a dremel (I prefer the surgery myself), the injector has a hose barb on the end like anything else in the system, use new FI style clamps on the new hoses.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Fri May 01, 2015 7:55 am    Post subject: Reply with quote
You have to cut a slit in the metal band around the hose and spread it, and it will come off. Make sure to use fuel injection hose it has a higher pressure rating.
Good Luck
Tcash
shiningstar76
Samba Brewer
PostPosted: Fri May 01, 2015 7:57 am    Post subject: Reply with quote
Great. Thanks for the help.
KK4NTP
96 Tacoma
86 4Runner
