Link Pin Pinch Bolt Torque
Bruce Amacker
Bruce Amacker is offline
PostPosted: Wed May 06, 2015 8:07 am    Post subject: Link Pin Pinch Bolt Torque Reply with quote
Hey guys, my early Bentley is terrible at giving torque specs. Does anyone know the pinch bolt torque for the link pin pinch bolts?
Thanks!
Many times I have to go to a later Bentley for bolt torques..... Rolling Eyes
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
PostPosted: Wed May 06, 2015 10:26 am    Post subject: Reply with quote
I didn't look it up but I bet it's in one of these books
http://www.thesamba.com/vw/archives/manuals/withoutguesswork.php
Edit: Weird, I don't see it in there for Bug, only Bus, which are 29-32 ft. lbs for M10. Are they M10? It's probably the same.
rockerarm
rockerarm is offline
PostPosted: Wed May 06, 2015 10:43 am    Post subject: Reply with quote
Hello Bruce. Per the, yellow, VW Without Guesswork, 1960-1970, "Clamping bolt link pin to torsion arm" 10mm bolt, the torque is 32lb/ft for a type 1 and 29-36 for the type 2.
Hope this helps, Bill.
Bruce Amacker
PostPosted: Wed May 06, 2015 2:18 pm    Post subject: Reply with quote
Thanks, guys. I appreciate it!
Very Happy
'66 Deluxe Bus
'65 Standard Bus
Build threads:
rrcade
rrcade is offline
PostPosted: Thu Aug 06, 2015 5:42 pm    Post subject: Reply with quote
10mm??? Those bolts take a 17mm socket
mukluk
mukluk is offline
PostPosted: Thu Aug 06, 2015 7:03 pm    Post subject: Reply with quote
Bolt sizes are determined by the diameter of the shank, not the size of the bolt head.
61SNRF
61SNRF is offline
PostPosted: Thu Aug 06, 2015 7:22 pm    Post subject: Reply with quote
Indeed, as are their respective torque specifications Smile
-Bruce
An ounce of prevention is worth a pound of cure.
rrcade
rrcade is offline
PostPosted: Fri Aug 07, 2015 11:07 pm    Post subject: Reply with quote
Who sells replacement bolts with correct shoulder length?
ninfelise
ninfelise is offline
PostPosted: Sun Dec 20, 2020 3:56 pm    Post subject: Re: Link Pin Pinch Bolt Torque Reply with quote
Sorry to dig up an old post but do you guys know if there are any washers, flat and/or lock, on the nut side of the pinch bolt? I'm putting my beam back together and noticed my old hardware consists of only a nut and bolt. Intuition is telling me to put a lock washer under the nut.
61SNRF
61SNRF is offline
PostPosted: Sun Dec 20, 2020 5:02 pm    Post subject: Re: Link Pin Pinch Bolt Torque Reply with quote
Yes, looks like they should have a split ring lock washer. #13 as shown in the obsolete parts catalog...
http://oacdp.org/type1part/4001.png
...and in the WW catalog as well...
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111405100
-Bruce
ninfelise
PostPosted: Sun Dec 20, 2020 5:05 pm    Post subject: Re: Link Pin Pinch Bolt Torque Reply with quote
Thanks Bruce!
61SNRF
61SNRF is offline
PostPosted: Sun Dec 20, 2020 5:12 pm    Post subject: Re: Link Pin Pinch Bolt Torque Reply with quote
You're welcome!
Sometimes us mechanics have to take a peek into the parts dept for answers to our questions Laughing Wink
-Bruce
