Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Fri May 08, 2015 5:26 am Post subject: Billet T1 heads |
I saw this at the Maikäfer show last week. Presumably high output street heads.
I thought some may like it. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Fri May 08, 2015 5:46 am Post subject: |
very nice! Are these available? _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Posted: Fri May 08, 2015 5:54 am Post subject: |
Not yet, that single head was almost still warm from the mill...
Nice idea though - I like that layout better than JPM.
I think they should add the rocker support like JPM has though. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Fri May 08, 2015 6:18 am Post subject: Re: Billet T1 heads |
Boolean wrote: |
I thought some may like it. |
More and thicker fins = Better cooling?
Maybe someone should do that with a type 1 head _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Fri May 08, 2015 10:35 am Post subject: |
Should make for a pretty wide engine, in any application. They look like they are cut for semi hemi? Or the chamber is very small. The casting looks like a 10 pounder. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Fri May 08, 2015 11:04 am Post subject: |
Those are some deep heads. No need for manifolds just make intake bolt pattern in IDA and your good to go. _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
ArnoudH Samba Member
Joined: December 30, 2008 Posts: 162 Location: The Lowlands
Posted: Fri May 08, 2015 11:10 am Post subject: Re: Billet T1 heads |
Maybe someone should do that with a type 1 head [/quote]
Roy:that is a Type 1 head -with a type4 intakemanifold-pattern.
[/img]
It's all yours for 2490 Euro's |
Posted: Fri May 08, 2015 12:48 pm Post subject: |
That is the very same head I held in my hand! Someone asked me if I was going to make copies at home when I took several pictures of it. I won't by the way. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
Marv [UK] Samba Member
Posted: Fri May 08, 2015 1:32 pm Post subject: |
I'm not convinced by the fins around the exhaust port. They look restrictive to flow and counterproductive. There needs to be flow around the port and the fin spacing ought to be even around the circumference _________________ The opinion of the author as expressed does not always reflect that of the author nor does he extend any apologies or assume any liability or responsibility for its content or lack thereof or for any lack of humour of the reader of any content at all, anywhere, ever. The reader agrees to all risk by reading it and is advised that any ‘issue’ is theirs alone as they chose to read it. |
Posted: Fri May 08, 2015 2:11 pm Post subject: Re: Billet T1 heads |
ArnoudH wrote: |
Maybe someone should do that with a type 1 head |
[/img]
It's all yours for 2490 Euro's [/quote]
Ah ha!!! Now I see the type 4 intake and type 1 exhaust....pretty cool. $2800 huh? Yeah, I'm a little short this week, will you take an IOU? _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri May 08, 2015 2:51 pm Post subject: |
Those heads look ridiculously heavy. I don't see any advantage using them. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri May 08, 2015 3:26 pm Post subject: |
They were not ridicolously heavy. And they have much better ports than stock configuration.
You know, like they try to do in racing. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Fri May 08, 2015 3:47 pm Post subject: |
Extending the fins around the exhaust port is just going to conduct heat back into the head, and the extra fins below the ports aren't going to do much that's useful. Impressive bit of machining, but I think you need to have a competent engineer look at the design. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5410 Location: Holland, MI
Posted: Sun May 10, 2015 12:12 am Post subject: |
Quokka42 wrote: |
Extending the fins around the exhaust port is just going to conduct heat back into the head, and the extra fins below the ports aren't going to do much that's useful. Impressive bit of machining, but I think you need to have a competent engineer look at the design. |
X2. Looks like they were adding fins just for the sake of adding fins with no real regard as to their function. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun May 10, 2015 3:52 pm Post subject: |
Way cool!
Although I kinda agree. If they have made it so the tins won't fit, then there was no need to keep the fins stock outer dimension. Should have gone another 6mm bigger!! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sun May 10, 2015 9:32 pm Post subject: |
They should start producing matching cylinder tins to go with those too.... Is that an opening for the thermostat connecting rod? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Brian Samba Moderator
Posted: Sun May 10, 2015 11:12 pm Post subject: |
Yea, tins are a problem. Unless you have a baja, which wait no, it's still a problem.
Bugguy, these are race application heads, which need no flaps not thermostat. oh wait, they're marketed as street heads.
So constructive criticism: they need to be re-"engineered" _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon May 11, 2015 1:58 am Post subject: |
I think the holes through the middle is for air circulation, but I guess a thermostat rod could go through there too.
I'd say they would require much less tinwork than MS230/250. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
Posted: Mon May 11, 2015 3:30 am Post subject: |
Special 'tins'will be availible for stock fanshrouds as well as Porschestyle cooling.
The heads are only slightly heavier in weight and take stock rocker+shafts.
Valves are 45/40 or 45/38 Nimonic.
Btw.Edy Remmele(whom's outfit makes these heads)was quick to point out that these are prototypes.
He also makes type4 heads in various configurations-all his engines are built for driving beyond the quartermile mark. |
