suebug Samba Member
Joined: April 13, 2006 Posts: 1152 Location: The OC, SoCal, with my olympic cats
Posted: Sun May 10, 2015 5:47 pm Post subject: How do I take off my Type 3 dash cover? |
Hi y'all. I can't seem to find the info in my manual on taking the dash cover off my '67 squareback. I took off all the screws along the windshield. Now what? Any help would be appreciated. _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
grandpa pete Samba Member
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4190 Location: Pasadena CA/DTLA soon China
Posted: Sun May 10, 2015 6:06 pm Post subject: |
1. Remove all screws under windshield
2. Remove under dash chrome thrim
3. Remove glovebox
4. Remove grab handle
5. Remove all three gauges
6. Very carefully, lift off
I have removed and installed dashpads with the windshield on, but it is a lot easier with the windshield off. You must tilt it really high to pull it off.
hope this helps.
Martin
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
suebug Samba Member
Posted: Sun May 10, 2015 6:40 pm Post subject: |
Thanks, that is perfect. All I needed to know for removing.
If I take that off will I get any access to all my dash wires, to 9-pin box,
and headlight switch, etc. or is it a waste of time? _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Sun May 10, 2015 6:44 pm Post subject: |
suebug wrote: |
and headlight switch, etc. or is it a waste of time? |
The pad is just a cover for the metal dashboard. You get access to all that stuff by going up from underneath, not from on top. |
suebug Samba Member
Posted: Sun May 10, 2015 7:17 pm Post subject: |
sjbartnik wrote: |
suebug wrote: |
My manual is wrong then! Thanks for averting a removal disaster. My cover is brittle and I was worried any manipulation would break it into pieces. Back to sitting upside down. _________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun May 10, 2015 7:20 pm Post subject: |
suebug wrote: |
Taking the gauges out will help with the switch, but no reason at all to remove the dash pad. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bobnotch Samba Member
Posted: Mon May 11, 2015 11:50 am Post subject: |
suebug wrote: |
sjbartnik wrote: |
suebug wrote: |
My manual is wrong then! Thanks for averting a removal disaster. My cover is brittle and I was worried any manipulation would break it into pieces. Back to sitting upside down. |
Removing the dash pad does nothing for accessing the wires. Working upside down is normal for these cars. For the headlight switch, removing the fuel gauge cluster (unplug the black piece from the gauge itself), fusebox, and the light switch, will get you most of the way out from under the dash. As for the 9 pin relay, you'll probably have to work under the dash for that one. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
