c21darrel Samba Member
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Wed May 20, 2015 4:58 pm Post subject: |
c21darrel wrote: |
Quote: |
And as far as motors go I never trust the " I just had it rebuilt" phrase
Well, it was running when I parked it. |
Yeeeep another one you never trust....lol _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
Posted: Thu May 21, 2015 9:04 pm Post subject: |
So I am slowly searching for the correct parts for the stock motor.I have attached pictures below of the manifold that came on the car. Can anyone tell me if this is the correct manifold for the motor? It is the one that came on it but what is throwing me off is the little tube under the carb mount.I searched the part number and I found one thread that mentioned the part number and another that said it was for a DP motor. It is obviously not a DP manifold. I have really no knowledge of what is correct when it comes to 40H motors, until now I have never built a stock motor.
Here is a link to the thread I did find, but as you can see it was not very helpful.
http://www.thesamba.com/vw/forum/viewtopic.php?t=542668&highlight=113+129+701m _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13953 Location: Southampton U.K.
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri May 22, 2015 6:31 pm Post subject: |
I think you want the D manifold, not the M |
Posted: Mon May 25, 2015 10:47 pm Post subject: |
Well moving right along. I got a set of rebuilt rods and installed them on the crank. This build is still fighting me, I moved on to cleaning the pistons up to see what I had. Come to find out that I have 3 stock Mahle pistons and one oddball piston of unknown origin. I bought a new ring kit, but I am going to have to search out a factory piston and cylinder. The three Mahle pistons are in awesome condition so I am going to try and find a single replacement. We shall see how that goes. No word from David's Machine shop on the condition of the heads yet. I contacted Keifernet about a rebuild on the stock carb, I have not heard back from him yet so I went ahead and disassembled the carb and now have it soaking in Chem-Dip.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Mon May 25, 2015 11:00 pm Post subject: |
FWIW, I'd suggest pulling the oil galley plugs.
Walnut shells are the right media for sure,
But,
It can be _real_ hard to get everything from way down deep in there if you blast a case.
Just $.02 from some guy on the Internet you don't know from Adam... _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Tue May 26, 2015 11:28 am Post subject: |
Yep I had planned to clean the oil galleys, just have not got that far yet, and I need to pick up a set of screw in plugs and the right tap if I do not already have them in my set.
Yep I got the email back from Keifernet, I tried searching for Volksbitz but no user is found. I let the carb soak in Chem-dip all night, it is definitely clean but it lacks that new look that the carb builders manage to get.
edit: found him spelled with two z's Volkzbitz _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Fri Jul 03, 2015 7:28 am Post subject: |
ConcreteAce wrote: |
now this is some bondo.....
Yep, that's some Bondo right there... _________________ Bus Motor Build
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Fri Jul 03, 2015 4:51 pm Post subject: |
Car is coming along great. Where did you get those red socket trays in your tool box? _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Posted: Fri Jul 03, 2015 5:01 pm Post subject: |
jpjohns wrote: |
Where did you get those red socket trays in your tool box? |
That is actually a set that came from craftsman. It had its own case but I pulled the drawers out and they fit perfectly in my tool box so I threw the case away. I like it because its easy to tell if I have tools missing and if I need several sockets I just pull the individual draw out and set it next to me while I am working, here is the set I bought.
http://www.craftsman.com/craftsman-258-pc-mechanic...ockType=G5 _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Fri Jul 03, 2015 10:03 pm Post subject: |
That's cool, I've been looking for some sort of organizer system for my drawers. The foam ones are way too expensive given they are only foam. _________________ -Jared
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Jul 04, 2015 5:46 am Post subject: |
A car I purchased seems to have Bondo under the entire paint job that was done about 12 years ago. I been using abrasive wheels to remove the paint and Bondo, taking it down to bare metal.
Have you found that the sheet metal is wavy, or has low spots ? _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
543fold Samba Member
Posted: Sat Jul 04, 2015 9:14 am Post subject: |
CiderGuy wrote: |
Have you found that the sheet metal is wavy, or has low spots ? |
Yes wavy, damaged, warped. Basically the blue you see in the pics are low spots. _________________ https://www.instagram.com/w.a.r._wills.auto.restoration/
______________________
....even the rust has rust!
How "NICE" do you wanna spend?
W.A.R.
Will's Auto Restoration |
Posted: Sat Jul 04, 2015 9:32 am Post subject: |
c21darrel wrote: |
Yep, But more bondo than rust...Thats a good trade off
Hope you are wearing a mask and enjoy the smell of old powdered bondo Somebody get the broom. |
Ha! Actually I had big fans blowing down the side of the car....so instant dust elimination _________________ https://www.instagram.com/w.a.r._wills.auto.restoration/
W.A.R.
