chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Tue May 19, 2015 7:26 pm Post subject: head gaskets means new heads? |
got the report i was expecting today, head gasket seepage on one side. mechanic, who has always done me right, says you need to replace the heads as well as they become pitted, making the sealing surface unsealable. is this the general consensus? it turns a $1500 repair into a $3100 repair, at least at this guy's shop. _________________ '74 transporter panel
'91 vanagon carat NAHT |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2236 Location: Olympia, Washington
Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1684 Location: Fort Collins Colorado!
Posted: Tue May 19, 2015 7:32 pm Post subject: |
Corwyn wrote: |
Might as well. They're not too expensive and new one just FEEL good! |
By not too expensive you mean double the price? _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
Corwyn Samba Member
Posted: Tue May 19, 2015 7:34 pm Post subject: |
Sir Sam wrote: |
Corwyn wrote: |
By not too expensive you mean double the price? |
Was that a constructive response, or just another question? _________________ '90 White Westy ("Knarr")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Tue May 19, 2015 7:44 pm Post subject: |
the head surface that the small green o-ring seals on the side of the cylinder wall to the head cannot tolerate any imperfections. the small diam of the green o-ring requires a perfect surface...
makes the heads junk, unless you are handy with both a TIG and a flycutter milling machine/lathe
$3k+ air cooled and WBX rebuilds, a reason I've taken an alternate engine path. but that's another topic discussion. _________________
Abscate wrote: |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Tue May 19, 2015 8:02 pm Post subject: |
When I did my heads recently, I replaced Rings, and Water Pump, and Thermostat Housing and the Rear Main Seal and a few more things that I don't recall. But I paid 1600 just for parts and did all the work myself. It sure does look nice with shiny new heads. The heads were only about 450.00 each, so the gaskets and other stuff just adds up. 3100 does not sound like a lot. I spent nearly 1 entire day on the Engine assembly, and another full 10 hour day putting it in and tuning, bleeding, etc.
Just my angle on this.
Tony _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Posted: Tue May 19, 2015 8:11 pm Post subject: |
Corwyn wrote: |
Sir Sam wrote: |
Corwyn wrote: |
Was that a constructive response, or just another question? |
The OP has a price to replace the seals at $1500. Then the OP has a price for the job with new heads at $3100.
So when you say they are not too expensive, you of course mean that double the price at $3100 they are not too expensive.
And $3100 over $1500 just FEELs good, right? _________________ '91 Carat Westy
hdenter Samba Member
Joined: October 14, 2008 Posts: 2753 Location: San Luis Obispo, CA
Posted: Tue May 19, 2015 8:35 pm Post subject: |
Well... The labor and related materials are the same for a re-seal regardless which heads are used. In my book, $1500 is a little steep for a new set of heads. GoWesty sells a reworked set of new AMC heads for $1000. Van-Café sells rebuilt heads for $800 a pair. For that much more there could almost be some 2.2 pistons in there. JMHO...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Tue May 19, 2015 9:21 pm Post subject: |
My '88 had a leaking head for sometime. Very slow leak. Of course it got worse. My reputable mechanic, swapped it out with a good used head. Price was very reasonable, under four bills.
That was about five years ago. All good at this point. If the one head is not leaking, and you're not in a position to do both, you might be ok just doing one. Mine was the passenger side (US). If yours is the other side, you may want to change out the water pump, while you're there. I had app. 140k miles when mine was replaced.
Otherwise do both, and change the water pump. Peace of mind comes at a price. You might want to change out some hoses since you're there. New radiator ? |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue May 19, 2015 9:37 pm Post subject: Re: head gaskets means new heads? |
chachi wrote: |
got the report i was expecting today, head gasket seepage on one side. mechanic, who has always done me right, says you need to replace the heads as well as they become pitted, making the sealing surface unsealable. is this the general consensus? it turns a $1500 repair into a $3100 repair, at least at this guy's shop. |
Pitted heads can still be reused IF the pits are not too bad. The jb weld technique filling the pits is pretty effective. The real problem with used heads is cracks, valves and guides. If the valves/guides are good and the heads have no cracks in the usual places, just jb weld the pits, sand smooth, reseal and be on your way. Thats the cheapest. But if your paying a mechanic to do that he may not be interested in the jb weld tech because he can't warranty that work. At $3100 repair bill i would be looking at a new power plant or diy the job. Good luck! |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Tue May 19, 2015 10:04 pm Post subject: |
I was able to get 5 years out of a set of pitted heads, I filled the pits with a JB equivalent and then did a normal assembly with new upper and lower seals and rings.
After doing mine ,most people who have done the same thing say that you should not use the filler as it just introduces an non compatible compound and that your best bet is to clean out the pits with a Dremel tool and a balled and and put it back together.
Most shops will not do this because they do not want the possible warranty,but if it was running fine besides the head leak and money is tight then put it back together and go on with your life.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Terry Kay Banned
Posted: Tue May 19, 2015 10:07 pm Post subject: |
Or have the pits welded up , and the mating surfaces milled--
If the heads are still in decent shape--no cracks.
And as long as you have them off, might as well do the valves & guides be done with it all. _________________ T.K. |
Posted: Wed May 20, 2015 12:51 am Post subject: |
How many miles are on the engine? If the mileage is getting up there, say 140K miles then you aren't very far from a rebuild. If so it would be a waste to just redo the heads and it would make more sense to go ahead with a full rebuild. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed May 20, 2015 2:01 am Post subject: Re: head gaskets means new heads? |
chachi wrote: |
... you need to replace the heads as well as they become pitted, making the sealing surface unsealable. |
I would treat the mechanic's advice as being "... you may need to replace the heads as well if they are too badly pitted, making the sealing surface unsealable."
I would inspect them once they are removed and then decide what to do based on the condition - if they are badly pitted then replace them or if they aren't then reuse them.
But first I would get alternative quotes for both options because your mechanic seems a bit pricey. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
Posted: Wed May 20, 2015 3:29 am Post subject: |
Using or not using the original heads becomes a Personal choice up to a point.
Read up and educate yourself about the various view points.
Bad cracks by the Valves will make this decision for you, it now becomes a I must replace statement rather than a should I replace question.
Surface pits, some say fix em with JB weld, some say weld and mill, some say clean and use.
The cylinder seal into the head is critical, pitting here will cause a combustion chamber leak.
When you are paying labor, I'd be surprised if your shop installs your pitted heads with ANY out the door warranty.
Used parts, especially used damaged parts offer no peace of mind about their ability to serve you long term. Very few shops will stand behind this repair.
The rebuilt heads from Bus Depot? I bought some..... They were so bad that I returned them! Very poor milling quality, sloppy the workmanship varied from head to head.
For the few extra hundred dollars, go with the new AMC heads on the market.
Now, just to muddy your waters..........
Do read up on their provided Exhaust valves though. You will need to decide to run them or replace them.
Will you buy the Heads with the valves already replaced?
http://www.thesamba.com/vw/forum/viewtopic.php?t=583560&highlight=heads
Ghia
Vanagon
Beetle
morymob Samba Member
Posted: Wed May 20, 2015 4:46 am Post subject: |
Do your research, as u already see opinions here run from one extreme to other end. I f reasonable minor pitting they will run indefinitely. My 2nd one over 330 k/ 12+yrs after a brng,ring etc to start, one even had the 'Bently ok crack in it, had a lot of hwy miles too. If it still in cond to get eng normally warmed up i would do a hot oil press test, see if bottom needs attention (brngs etc) if over 100k never hsd one apart that still had good brngs. If a long time keeper, big decision time. Get more than one opinion, search some local owners 4 a dependable shop, u can easily get a good screwing on these engines from a quick buck shop. |
Posted: Wed May 20, 2015 8:50 am Post subject: |
If it isn't leaking all that bad, add some Subaru Coolant Conditioner to the coolant and keep on driving. |
chachi Samba Member
Posted: Wed May 20, 2015 11:05 pm Post subject: |
Wildthings wrote: |
this seems like the plan for now. the $3100 question is, what is "all that bad"? i lose about a half the reservoir in 2-3 weeks of regular, non-commute, daily driving.
i have considered a foreign power plant before but i can't shake years of watching subaru drivers have to get new head gaskets at ~160k; if i have to get head gaskets either way, i'd rather stay original. plus the only way it makes sense for me cost wise is DIY and i don't have the time. maybe in ten years.
the cost is probably shoppable, i may save myself a few hundred but i want to get it done right and do as many things as i can while i'm in there. rings? i'm shying away from the bottom end, frankly. _________________ '74 transporter panel
Posted: Thu May 21, 2015 2:27 am Post subject: |
The head gaskets on my '91 started leaking when I had about 120K miles on them and I used stop leak for many miles until I took the engine out of service at around 180K because the rod bolts were stretching. All the naysayers claim these rigs will die a quick death if you use stop leak, but it worked for me and now over a decade and a hundred thousand plus miles later, I still run the same radiator and front heater core in this rig. |
Terry Kay Banned
Posted: Thu May 21, 2015 4:42 am Post subject: |
And in life, there are folks who manage to get away with running with bailing wire, duct tape, & latex house paint jobs.
Is it right?
Depends on what neighborhood you live in I guess.
How many guys from Warsaw does it take to put a light bulb in?
10.
One to hold the light bulb, 9 to turn the ladder.
Who stole the Keeshka? _________________ T.K. |
