SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 629 Location: Central Florida
Posted: Fri Oct 21, 2022 7:37 am Post subject: Re: Hurst Shifter |
There is also a guy selling premade bottom plates in the classifieds for about $30 I think. I was told they are not hardened steel like original Hurst so you may need to do that prior to install though. |
Bruce Samba Member
Posted: Sat Oct 22, 2022 11:27 pm Post subject: Re: Hurst Shifter |
SLO-N-LO-69 wrote: |
.... I was told they are not hardened steel like original Hurst so you may need to do that prior to install though. |
There's nothing you can do to mild steel to make it hard. Mild steel can't be heat treated. _________________
Bruce Samba Member
Posted: Sat Oct 22, 2022 11:32 pm Post subject: Re: Hurst Shifter |
KarmannTed wrote: |
.... I think you are referring to the bottom plate (I do have the flat one mounted that came with the kit, no problems there). BUT, the one I'm referring to is actually within the shifter itself. It prevents from hitting reverse unless the trigger is activated. Here are some pictures from other posts, showing the correct /mounted piece, and a loose one (like the one I'm sadly missing since the PO didn't mind to keep it when it came loose (probably due to the lousy EMPI spot-welding?).
The reverse lockout wall extends to a height of 8mm above the bottom plate.
The foot of it is 15mm wide on the outside.
It's 48mm long.
The steel is 1.9mm thick. _________________
KarmannTed Samba Member
Joined: October 20, 2022 Posts: 3 Location: Mexico City
Posted: Sun Oct 30, 2022 9:06 pm Post subject: Re: Hurst Shifter |
Bruce wrote: |
KarmannTed wrote: |
It's 48mm long.
The steel is 1.9mm thick. |
Thanks everyone! I followed these exact dimensions, and worked like a charm since the 1st try. Reverse lockout is working great, no more confusion and effort to find the correct allignment for 1st and 2nd gear. Saved me from buying a brand new shifter! |
ROBST3R Samba Member
Joined: January 27, 2023 Posts: 4 Location: Netherlands
Posted: Fri Jan 27, 2023 3:36 pm Post subject: Re: Hurst Shifter |
Hi all.
I have a trigger shifter of empi and I see the spring is out and I don’t have a clue how to fit this. I can’t find a single picture.
I attached some pictures and hoping someone can tell me where to put the big spring.
[/img] |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Jan 27, 2023 3:47 pm Post subject: Re: Hurst Shifter |
Your spring is bent, at the top in your image.
If I remember correctly (IIRC), The spring fits over the dimple as seen in the image above. It presses against the shift ball, horizontally.
Welcome to the samba. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Jan 27, 2023 4:20 pm Post subject: Re: Hurst Shifter |
Thank you very much! Happy to be here.
So if I bend the spring back and put it on these two points it should ok?
I see nothing on the shifter ball where to put the spring on, so it can jump away now
Posted: Fri Jan 27, 2023 5:09 pm Post subject: Re: Hurst Shifter |
On mime there is a little nipple on that round piece above your bottom circle. The spring goes there. It is dirty but this shows it.
Posted: Fri Jan 27, 2023 5:34 pm Post subject: Re: Hurst Shifter |
^^^ This.
There's actually two balls on those shift levers. I meant the upper one, of course. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Mon Jan 30, 2023 3:00 pm Post subject: Re: Hurst Shifter |
[quote="67rustavenger"]
There's actually two balls on those shift levers. I meant the upper one, of course. |
Thank you for the replies. What I also noticed is that the bal is out of the plastic plates, does anyone know how to get it back in? This is the reason the spring isn’t attached anymore.
Hope you have an answer/solution
It is really special that the ball can be out, because the middle diameter from the ball is wider then the hole
EDIT: I think I have to get the upper plastic plate off by drilling the rivets off, then put the ball in the lower plate and put the upper plate over the ball again
All the best
All the best
Posted: Tue Jan 31, 2023 12:59 pm Post subject: Re: Hurst Shifter |
Something isn't right there. The ball should seat into the white pieces and only have one set of holes in it. Personally I would get another shifter and keep that one around for parts. |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Fri Feb 03, 2023 8:59 am Post subject: Re: Hurst Shifter |
[quote="ROBST3R"]
67rustavenger wrote: |
All the best
All the best
I believe the nylon block goes on after the shifter ball is in place. That's what holds shifter down. _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
