fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Thu May 21, 2015 11:47 am Post subject: Aluminum Crank Pulley Fretting |
Have you guys seen this before? It seems my aluminum pulley started slowly wondering forward and aft on the crank snout. It was making contact with the VR sensor mounting bracket. When I pulled it all apart, I found the crank pulley also had some rotational play... maybe 5 degrees. The strange part is that the crank bolt was tight! The dark greasy-looking material is a combination of anti-seize compound from installation and aluminum dust from the fretting.
Should I chalk this up to a bad pulley, or a crappy install job (by me ), and install a steel pulley?
[/img][/url] _________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Thu May 21, 2015 12:06 pm Post subject: |
Some aluminum pulleys (SCAT for example) do not have (or hold...) an interference fit on the crank. The crank bolt torques tight because it is bottomed out in the snout. You need a spacer on the backside of the pulley. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Thu May 21, 2015 1:51 pm Post subject: |
Stripped66 wrote: |
Some aluminum pulleys (SCAT for example) do not have (or hold...) an interference fit on the crank. The crank bolt torques tight because it is bottomed out in the snout. You need a spacer on the backside of the pulley. |
I have this same problem with 'mostly Scat' pulleys, make sure you have the correct spacer and always use a very strong washer under the head of the bolt. The washers that come with most pulleys bend into the pulley when are tight. Good Luck and have Fun |
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Thu May 21, 2015 4:09 pm Post subject: |
Make sure you check your crankshaft end-play before going back together. _________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
Posted: Thu May 21, 2015 4:55 pm Post subject: |
50 miles through traffic and two hours later... New pulley in hand, with spacer. Will jump on the install shortly.
BTW... The CB Crank Fire pick-up wheel is mounted between the crank bolt and the pulley. I torqued it to 35 ft lbs (whatever the Bentley stated) when I installed the system. The bolt is considerably longer than stock, as to secure the timing wheel to the pulley. I made sure the bolt didn't bottom out before everything was seated and snug. Do you guys think the torque value should increase for the additional loading and grip length of the crank bolt? CB's instructions do not specify...
Thanks everyone! _________________ Eric
Ellsworth, ME
207-242-0016
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Fri May 22, 2015 5:02 pm Post subject: |
^^^^ NO _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
modok Samba Member
Posted: Fri May 22, 2015 6:10 pm Post subject: |
It's amazing this doesn't happen more often.
The torque can be upped but the stock washer (or empi chromed POS washer) will just bend out of the way. need a stronger washer. That size bolt can withstand 100 ft-lbs. |
Posted: Sat May 23, 2015 4:13 am Post subject: |
Everything is installed. I used an anodized Scat pulley (only one available locally). The pulley went on snug, with a light film of anti-seize inside the hub and key way. I used the crank bolt to draw the pulley on. I torqued the assembly down to 40, then 45, then 50... Up to 70 ft lb. everything went together great, and feels nice and tight. I'll run it a couple hundred miles today, then recheck the torque.
Thanks for the input, everyone! _________________ Eric
Ellsworth, ME
207-242-0016
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sat May 23, 2015 4:34 am Post subject: |
Don't be surprised if you've beaten it. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sat May 23, 2015 6:47 am Post subject: |
fccperdiem wrote: |
The pulley went on snug, with a light film of anti-seize inside the hub and key way. |
Are you running an oil filter? If not, remove the pulley and clean off that anti-seize. _________________
66brm wrote: |
Bodacious wrote: |
Posted: Sat May 23, 2015 9:17 am Post subject: |
It's full-flowed with a filter. Good call, though... The labyrinth seal does act like a screw. _________________ Eric
Ellsworth, ME
207-242-0016
Posted: Sat May 23, 2015 10:25 am Post subject: |
fccperdiem wrote: |
It's full-flowed with a filter. Good call, though... The labyrinth seal does act like a screw. |
The labyrinth seal is not going to prevent anti-seize that built up on the back of the pulley's hub or in the keyway from getting into the oil... _________________
66brm wrote: |
Bodacious wrote: |
