andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Mon May 25, 2015 7:24 am Post subject: 86B and valve hitting..?? |
So i've got:
Stroker AA's 90.5
CB 82mm crank
1.1mm deck.
CB 044, not fly cut
40x35 valves
BP 1.4s which are 1:1.42 so not bad.
valve lift on the intake is 13.83mm or 0.5445in
Dots on the cams and crank gear are lined up, cam gear is on so the slot is alined with the bolt hole (IE the right way)
And i'm turning it over, and it jams, if i back off the valve adjuster a fair way it will turn over.
at first i thought it was rockers jamming on the head, but having just plasti the piston top i can see its the valve hitting the piston.
I wasn't expecting this with this cam and build?
Have i done something wrong here? maybe i need to measure exhaust lift to double check thats the same..? _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
Posted: Mon May 25, 2015 7:42 am Post subject: Re: 86B and valve hitting..?? |
Bet the retainers are hitting the valve guides, or the springs are binding. Check these first.
If the pistons are contacting the valves it will be close to 5-10 ATDC. Spring and/or retainer problems will be around 80-100 ATDC. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Mon May 25, 2015 8:08 am Post subject: |
Hi John
That was on my list
But this little mark is from the valve
Alstrup wrote: |
56vwoval Samba Member
Joined: March 21, 2010 Posts: 186 Location: nowhere USA
Posted: Mon May 25, 2015 8:29 am Post subject: valve hitting head |
Clay the pistons. That will tell you the amount of valve relief you will need. _________________ Remember guys and girls, you can be right or you can be happy with your significant other! You decide which is right at that time! |
Posted: Mon May 25, 2015 8:33 am Post subject: Re: valve hitting head |
56vwoval wrote: |
Clay the pistons. That will tell you the amount of valve relief you will need. |
tried that, thats how i know its hitting, along with the mark on the pistons, problem is i cant go a full rotation thought to see how much i need...?
oddly enough the intake are OK, which surely would be either the same or other way around? _________________
Alstrup wrote: |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Mon May 25, 2015 8:42 am Post subject: |
Degree the cam, something is out of time. You would have to flycut the heads a lot for that to happen with a 86b. I had no problem with a 86C. You have to check everything including what John said.
Dan |
Posted: Mon May 25, 2015 8:46 am Post subject: |
raul arrese wrote: |
With that lift you shouldn't be hitting the piston , are you sure of all your specs ?? |
It is not the lift that does it but the timing of the lift. |
mark tucker Samba Member
Posted: Mon May 25, 2015 9:00 am Post subject: |
thats exhaust so...your probably retarded. always degree befor checking squat.or...your just pissing in the rong side of the fan like clearancing the case with rods not in correct position. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Mon May 25, 2015 9:04 am Post subject: |
Put a .060 barrel shim in for mock up, then clay the piston and deduct the .060 to get your number. Or like a customer of mine was told " just retard the cam more". Which to me is a retarded way of fixing it. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Mon May 25, 2015 9:34 am Post subject: |
Check the cam timing. I have the 86B with a tighter deck, and slightly higher ratio rockers, and no interference. Something isn't where it's supposed to be |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7214 Location: Videbaek Denmark
Posted: Mon May 25, 2015 9:35 am Post subject: |
Dan Ruddock wrote: |
Dan |
X2
T |
Posted: Mon May 25, 2015 10:20 am Post subject: Re: 86B and valve hitting..?? |
did you degree the cam? It's probably advanced...... _________________ It's just advice, do whatever you want with it!
Posted: Mon May 25, 2015 10:23 am Post subject: |
The quick and dirty way is the intake and exhaust should be open about the same amount @ TDC overlap, if there not something is wrong. Who knows cam grinder could of made a mistake or the crank keyway cut is wrong and other possibilities.
Dan |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Mon May 25, 2015 10:28 am Post subject: |
I just did this with my 1679cc with an 86b and 1.4's. The heads are flycut .180" and the deck is .038". As tight as everything is the intake only barely touches the piston- it'll cut the clay but the crank will still turn over no problem. The exhaust had around .055" clearance. Maybe your cam gear is off a tooth?
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Mon May 25, 2015 11:12 am Post subject: |
Dan |
wrong!!!~ the quick was is to DEGREE IT. then if needed cut valve knotches in the pistons in the right place's and depths. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Mon May 25, 2015 11:52 am Post subject: |
Before you do anything setup adjuster alignment at half lift and then recheck. Having a pushrod too long can cause you "that grief". It's a fine line.
This engine has 574 lift with 44 intakes. No notching. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Mon May 25, 2015 11:55 am Post subject: |
You sure the rockers aren't alien oversized to plus 1.48? Even so, you should still have room. Check the cam gear to see if you accidently put it 180. You can also turn the engine sideways and put a screwdriver in #2 exhaust lifter to see if you are on true #1 tdc compared to cam relation. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon May 25, 2015 12:16 pm Post subject: |
I think you have cam timing issue.... Is gear really on cam in correct position...
Posted: Mon May 25, 2015 1:12 pm Post subject: |
Dale M. wrote: |
Dale |
Correct, the 86b just does not have enough duration for there to be a problem. Something is wrong.
Dan |
