fccperdiem Samba Member
Joined: August 16, 2005 Posts: 107 Location: Ellsworth, Maine
Posted: Wed May 27, 2015 6:33 am Post subject: CB Gen4 EFI Released |
I have no doubt that CB's Gen4 EFI is going to be badass, but $2800? Is it assumed that throttle bodies, injectors, etc are not included? _________________ Eric
Beard Fire Metalworks
Ellsworth, ME
207-242-0016
www.beardfiremetalworks.com |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3467 Location: Charleston, SC
Posted: Wed May 27, 2015 7:40 am Post subject: Re: CB Gen4 EFI Released |
fccperdiem wrote: |
I have no doubt that CB's Gen4 EFI is going to be badass, but $2800? Is it assumed that throttle bodies, injectors, etc are not included? |
I'd guess the TBs and hardware are all included, considering the "Turbo" option adds another $1200 to the purchase price (which would be about right for CB's turbo, manifolds and exhaust). _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4848 Location: sanger ca
Posted: Wed May 27, 2015 7:44 am Post subject: |
I assume everything is included as a basic kit. Meaning it has provisions for a ton of options, like 4 wide band o2 sensors to monitor individual cylinders, but you would have to buy the extra 3 sensors.
I do know the thing is bad ass. I was helping Pat Downs with his pro-stock car at Bugorama last weekend, he started with his base map due to a dyno problem earlier in the week. The decision was to run it to the eighth then cost rest of the way and check the data logger. Car went 9.84 shutting down at the 8th. Went to check data and it was forgot to get turned on(Duh!). Next pass with the same tune running it out got a 9.41, remember the official pro-stock record is a 9.60 something. So yes, this ecu is bad ass _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed May 27, 2015 7:51 am Post subject: |
I hope it is a kit. Unfortunately, the product description is vague with regard to included hardware. I see Stripped66 is exactly right about the turbo configuration price increase... Maybe CB can fix the write up without too much hassle. _________________ Eric
Ellsworth, ME
207-242-0016
Pat D Samba Member
Posted: Wed May 27, 2015 7:57 am Post subject: |
$2795.00 is for a complete N/A kit including throttle bodies, linkage, fuel system, electronics, etc. The kit does not include any ignition pieces or add on's like IAC motor kit, boost control hardware, water/meth kit, extra 02 sensors, egt's, etc.
The turbo kit is $3,995.00 and includes the same pieces as the N/A kit but also all of the turbo components. _________________ Pat, Im too fast slow me downs! |
Posted: Wed May 27, 2015 8:01 am Post subject: |
Thanks for the clarification, Pat. Looking forward to it! _________________ Eric
Ellsworth, ME
207-242-0016
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Wed May 27, 2015 8:05 am Post subject: |
any chance the controller will be available by itself? _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Pat D Samba Member
Posted: Wed May 27, 2015 10:12 am Post subject: |
58Dub wrote: |
any chance the controller will be available by itself? |
Yes, Retail cost on the ECU is $995.00 _________________ Pat, Im too fast slow me downs! |
58Dub Samba Member
Posted: Wed May 27, 2015 5:12 pm Post subject: |
Pat D wrote: |
58Dub wrote: |
Yes, Retail cost on the ECU is $995.00 |
Thanks Pat! _________________ 58 Beetle (now just a pile of parts in the corner)
Blake R Samba Member
Posted: Thu May 28, 2015 7:41 pm Post subject: |
Pat D wrote: |
The turbo kit is $3,995.00 and includes the same pieces as the N/A kit but also all of the turbo components. |
So I'd need to buy the pn2092 kit to make it a ready to run package? |
