clutch squeek?
-Zodiac-
-Zodiac- is offline
PostPosted: Wed Jun 03, 2015 4:47 pm    Post subject: clutch squeek? Reply with quote
So my car got rained on and I took out some carpet - noticed there was a bit of rustyness on the pedals. I sprayed some white lithium wd-40 on them, drove it around the block and there's an awful squeek/ rubbing noise when I push down on the pedal, and when I let off. Tried some grease - nothing changed. to be clear - It didn't make any noise before, and the clutch works fine..
any help is much appreciated.
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
c21darrel
c21darrel is offline
PostPosted: Wed Jun 03, 2015 5:20 pm    Post subject: Reply with quote
nothing to worry about, my knees make the same noise Wink
If it makes noise when cable moves...follow the cable. Unless you have a zirk fitting on the pedal cluster you cant effectively grease it w/o disassembly...altho sprayed wd-40 should temporarily quiet a squeek. Does noise come from tunnel? or where?
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Thu Jun 04, 2015 10:49 am    Post subject: Reply with quote
Well.. It fixed itself overnight lol.
It was so loud yesterday that I thought something must have been messed up - oh well, today was a good day Cool
